T-Rex Eyelids on a budget mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarinePhoenix2207, Jul 25, 2011.
  1. Jul 25, 2011 at 10:41 AM
    MarinePhoenix2207
    MarinePhoenix2207 [OP] Well-Known Member
    South Jersey (yes, there's a North and South)
    09 Double Cab TRD sport
    bug/debris deflector, hose clamp mod, G4 elite fold-a-cover, Westin black nerf bars, Weathertech floor mats, 285/70/17 Goodyear Wrangler Duratracs, MO951 black Moto Metals 17x9, Pop n' Lock w b/u camera, "TRD" third brake light mod, 13" black FA-series antenna, 20% front 5% rear tint, painted badges mod, rear diff breather mod, Thule 400xt Aero roof rack, Westin Sportsman black grille guard, silver pinstripe removed, Tacoma short bed bedmat, 3" Toytec Bilstein adjustable lift kit w 5100 shocks and 2" lift AAL, Redline Tuning Quicklift Plus, Rockford Fosgate sound system w/ Kenwood h/u
    So after really wanting t-rex eyelids and not wanting to spend the $45 to buy them, I found a way to get the same results while spending less than half of the cost.
    Tools needed:
    - flexible foam sheets (~ $0.89 per sheet at craft store), I found ones that were about 1/8" thick to help when removing them after spray painting
    - flexible curve stencil ($3-$5 at craft store)
    - plasti-dip (~ $5)
    - scissors
    - painters tape (or any tape for covering non-painted areas and for holding foam sheets in place on headlight)
    - optional: black gloss spray paint for plastics (~$5), for finishing touches
    Step 1:
    Bend the curve stencil to the angle and shape you'd like. I used photos from other Tacos that had T-Rex eyelids in order to get the shape just right.
    Step 2:
    Tape foam sheet on headlight so that the bottom aligns with the top of the front bumper. Trace the curve onto the foam sheet.
    Step 3:
    Make sure the shape is what you want before you start cutting. If you need to retrace, do so now, or you could buy a few sheets and try again if you mess up. Tape the lower half of the foam sheet back onto the headlight into the same position it was before you cut. If needed, make small pencil marks beside the headlight in order to put the stencil back in the exact spot. Tape all around the headlight.
    Step 4:
    Spray multiple coats of plasti-dip over exposed portion of headlight. I used about 4-5 thin coats. Make sure you don't apply too heavy of a coat that it drips under the foam stencil.
    Step 5 (optional):
    After you're finished with your coats of plasti-dip, you may want to spray a thin layer of black gloss spray paint in case you feel the plasti-dip is too dull (thanks TankTodd). I also turned on my headlights to see if any light bled through the layers of paint/plasi-dip and covered those small areas up with the paint.
    Step 6:
    Remove tape and foam sheets and enjoy.
    Without gloss
    With gloss
  2. Jul 25, 2011 at 10:44 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I haven't decided yet whether or not this is really cool or really tacky... I am the god of plasti-dip so I figure I should approve :thumbsup:
  3. Jul 25, 2011 at 10:48 AM
    MarinePhoenix2207
    Would you have been able to tell the difference between this and a bought one if you had only seen the pics (despite the lack of color-matching)?
  4. Jul 25, 2011 at 11:00 AM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I probably would not have noticed the difference in shape or quality but to me the whole point of doing eyelids is to color match. But that's JMHO, YMMV, ETC, and like that.
    Do you have a pic of the whole front of the truck with finished result?
  5. Jul 25, 2011 at 11:00 AM
    memario1214
    Colton
    Missoula, MT
    Yes, I have a set of T-Rex eyelids that I rocked for a while, but couldn't seem to get the color right so I pulled them. They stick out a bit from the body. Your way looks better IMHO
  6. Jul 25, 2011 at 11:03 AM
    jonny
    jonny Betty White Edition Heep ZJ
    you get an A for effort. They aren't bad looking. kinda cool actually.
    if they get beat up...peel them fuggers off
    I used to hate how my trex eyelide stuck out from the headlight.
  7. Jul 25, 2011 at 12:06 PM
    MarinePhoenix2207
    Here's the whole front end. I think the black works well with the rest of the black. I dunno, just a simple project for the truck. How could I resist?
  8. Jul 25, 2011 at 12:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Nothing wrong with that; good job!
  9. Jul 25, 2011 at 12:47 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    I think you did an awesome job man, it looks great! :thumbsup:
  10. Jul 25, 2011 at 12:49 PM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
    i think it looks good! although i think it would look better w/o the bug shield. kinda looks like a mustache
  11. Jul 25, 2011 at 2:18 PM
    MarinePhoenix2207
    ^^ yea that def crossed my mind, i like to think that it actually works deflecting stuff, but it does look weird now
  12. Jul 25, 2011 at 2:21 PM
    xSectionxEightx
    xSectionxEightx Well-Known Member
    Josh
    Phoenix
    06 4x4 4.0L 6sp Access Cab
    Allpro LT powder coated black with Fox 2.5s. BAMF Sliders w/ kick outs. Allpro Expo leaf pack and Fox 2.0 RR. Brute Force hybrid bumper. BAMF Roofrack. Tepui Kukenam in Siberia Camo. CBI ditch light brackets. Cobra CB. Allpro skidplate.
    Agreed;)
  13. Jul 25, 2011 at 2:28 PM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    No with it above the "eyes" it looks like a unibrow.
  14. Jul 25, 2011 at 2:28 PM
    Smoove06
    Smoove06 Well-Known Member
    Alex
    North Phoenix
    05 SSM DCSB PreRunner
    Starting From Scratch....again
    Looks good! I was planning on doing the same thing but i havent had the time to make a template for it.
  15. Aug 4, 2011 at 8:55 PM
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
    Another way you could do it, that would keep it flush and color match would be just to rattle can the template with your color
  16. Aug 4, 2011 at 9:13 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Sweet, I should did that instead of paying $100 for my eyelids.
  17. Nov 9, 2011 at 10:36 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    NICE, been wanting to get some eyelids for a while now too. should have some dip left over from the last time.
  18. Nov 9, 2011 at 4:44 PM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    I say it looks really good and it is super cheap to do. Great work man
  19. Nov 9, 2011 at 6:48 PM
    wbr775
    wbr775 Desert Taco
    Weber
    Reno, NV
    06 stardard cab 4x4
    MRBP exhaust 3"lift charcoal filter removed from intake me behind the wheel! lol
    looks good!! will be doin this weekend! thanks for the good write up aswell.
  20. Nov 11, 2011 at 6:08 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Looks good. It might be better than the fiberglass lids that do no always sit flush with the lights. Instead of the gloss black you could color match it to the truck, but I understand you prefer the black. Options and personal preference/opinion is always good.
    :thumbsup:
