T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Sep 16, 2014 at 2:04 PM
    #241
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Yes I've heard of this TSB that revises the recommended air pressure settings on tires in order to match the tires the truck was sold with.
    We did have some 32 F and below weather here in central california last winter, but I don't remember hearing knocking/pinging. Hopefully someone who lives in a consistently colder climate can chime in.
  2. Sep 16, 2014 at 2:55 PM
    #242
    jokerj80
    jokerj80 Well-Known Member
    Jeremy
    O..H!!
    12 tacoma quad cab
    SS bull bar, K&N air filter, Pioneer avh8400, Kicker amp and sub, window tint, bug shield, T-Rex grille, Hella Ralleye 1000 behind grille, lund genesis bed cover
    A friend of mine told me that the knocking in cold weather is usually because the fuel is low in octane or there is ethanol present. He told me to run 93 octane and after a few fill-ups the ecu will adjust and knocking should go away. So this may be unrelated to this thread. I did call the dealership back and the service tech told me to bring the truck by and leave it for a day so they could cold start it but with the temps currently being in the 60's and 70's it might be a waste of time. I think I'll wait and see what happens this winter. It will still be under warranty then.
  3. Sep 16, 2014 at 3:46 PM
    #243
    gonathan85
    Nate
    Central California
    Sound decision.
  4. Sep 16, 2014 at 4:03 PM
    #244
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Well I had the TSB performed, and leaving the dealership going up the same hill there was no pinging present. We'll see how things go as I drive it more.
    Normally I run 89 octane fuel that's E10, but lately I've been filling up more with 87 No Ethanol from a small gas station by my house. Usually that'll mix with the 89 E10. The last two fill ups have been with 87 No ethanol so that was primarily what was in my tank at the time I noticed the ping. For purposes of consistency, I'll fill up the next two times with the same stuff. Gas mileage, I'll admit I don't go as hardcore in calculating it as some members do, but it's been in the 17-18mpg range thru out numerous fill ups. I'll see if I notice a change with that as well.
  5. Sep 20, 2014 at 6:27 AM
    #245
    gearcruncher
    Canadain bumper technician
    OK , so after reading through 220 posts , Here is another kicker .
    This TSB also fixes rough shifting on the automatics as it upshifts into fifth gear .
    The TSB was released in 2012 but older trucks are also having the problem . There is a huge post about clunky transmissions . This TSB seems to fix the issue up by delaying the shift points to alleviate such load on the engine .
    A big thanks to Rambone for bringing the technical service bulletin into the picture . That really helped . He deserves some points for this http://www.tacomaworld.com/forum/member.php?u=137211
    Double check your mileage before and after you have this TSB performed .
    Here are a couple related links
    http://www.tacomaworld.com/forum/2n...pressing-gas-pedal-mid-speed.html#post9134443
    And 84 posts here http://www.tacomaworld.com/forum/2n...-rough-shift-into-5th-gear-5.html#post9187426
  6. Sep 20, 2014 at 6:42 AM
    #246
    Rambone71
    Rambone71 Well-Known Member
    TJ
    North east
    2014 tacoma off road
    Also keep in mind that these are adaptive transmissions so if you ask the dealer to do a manual reset on the adaptive learn it makes a huge difference and feels like a new trans....
  7. Sep 20, 2014 at 6:44 AM
    #247
    gearcruncher
    Yup !!! I agree !!!!
  8. Sep 21, 2014 at 8:11 PM
    #248
    ThatguyJZ
    Jim
    TRIAD, NC
    Happy to report I took my truck through the mountains all weekend and didn't have a single issue on all the hills, switchbacks, and higher elevations.
  9. Sep 22, 2014 at 6:18 AM
    #249
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Just had the TSB preformed on my 13 TRD OR. Whoo hoo ! no more pinging. Here in Austin TX its over 90 most of the year. I would hear it all time time now after the TSB have not heard a single ping. The engine just seems more refined and more smooth hard to describe but defiantly an improvement. Waiting to see if the MPG is affected after a few tanks.
  10. Sep 22, 2014 at 9:07 AM
    #250
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    tried to have it done on my truck via oxnard toyota. Made appointment confirmed that if i showed up they were going to do it without issue.
    Showed up and the guy was like yeah i cant do it unless its pinging. (it was 68* out and my truck doesnt ping in the first place i want this tsb done for the smoother motor, preventative maintenance from pinging in the future and slightly different shift points) Then he goes and tells me, they just did this tsb on a previous tacoma and they ended up bricking the ECU and had to order a new ECU.... at that point i told him, you guys will never work on my truck, give me my keys back and thanks for wasting my time.
    i swear the dealers here in Ventura County are horrible.
  11. Sep 23, 2014 at 5:12 PM
    #251
    gonathan85
    Nate
    Central California
    I would file a complaint through corporate.
  12. Sep 23, 2014 at 5:47 PM
    #252
    nd4spdbh
    SoCal
    i have tried that shit before.... honestly for that its not worth my time... i fought with toyota corporate over a much bigger issue i had at Ventura Toyota and got a bed mat out of it.... but beyond that no thanks.
    Going to call thousand oaks toyota tomorrow and make an appointment to drop my truck off.
  13. Sep 24, 2014 at 5:59 PM
    #253
    gonathan85
    Nate
    Central California
    So you're trying another dealer?
  14. Sep 24, 2014 at 8:19 PM
    #254
    nd4spdbh
    SoCal
    yup, i actually sat there in the service area drop off for your truck and called another dealer in the area and got the scoop on if thousand oaks can do it, and they said they could but if they couldnt replicate the issue they would need to contact toyota cooperate to have it done and would likely be approved to do it. I gotta call them again and sort out details of giving them my truck for the day and making sure they actually do it.
  15. Sep 25, 2014 at 5:45 AM
    #255
    Brandon9281
    Brandon9281 Member
    Indiana
    2013 TRD Off Road double cab
    Softtopper, wet okole,
    Play them the sound clip I posted on page 5. My buddy could never get his truck to ping at the dealer so he played it for them and they did the tsb right there. If you want I can send you the clip.
  16. Sep 25, 2014 at 9:02 AM
    #256
    nd4spdbh
    SoCal
    good idea i will try that out when i talk to them. Im really in no rush.
  17. Oct 2, 2014 at 7:26 AM
    #257
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    2013 DCSB Baja, picked it up in March 2013 adn I have 33,000 miles on it.
    I started to notice the pinging last year when I was on my way back to New Orleans from NW PA. It came and went, so did not worry about it. I had my 30,000 done about 3 weeks ago @ 29,480 and then went up to Atlanta and I noticed it right out the gate esp as the route got a little hilly, between 1100 and 2000 rpm and figured that maybe they cleaned the MAF sensor at the 30K service, returned back to the flat land and jsut occassionally I would hear it. Went back up to Atlanta and it was back, but louder, to the point where I was creeping along in traffic and on every partial throttle application under any load it would ping, so I called the dealership that has done all my work and too it in last Friday. Went out with the tech and he noticed it a couple of times and put it up on the rack and checked for loose heat shields etc, but nothing and told me that it would have logged codes if it was pinging....It doesnt seem to matter what the temp is outside as it pings every morning around 0500 when I get off the interstate and go up a ramp under very small throttle openings.
    The tech also told me that maybe the throttle body needed cleaning.
    I have had this serviced religiously and all filters have been changed.
    Thanks for posting this TSB and I will get this done hopefully today.
    I am averaging 16.8 MPG and have tracked my mpg for 20K.
    We will see. :spy:
  18. Oct 2, 2014 at 8:21 AM
    #258
    gonathan85
    Nate
    Central California
    You're welcome. From your description, it appears like you're a good candidate for this TSB. I'm at 1000+ miles now after having the TSB performed, and so far, I haven't heard the pinging/thwacking noise return. It doesn't quite run as smooth now on 87 as it did on 93 premium, but I have no doubt that 98% of the problem has been corrected. I'm happy to be be back to running regular unleaded 87 fuel...:D $$$$ savings...
  19. Oct 2, 2014 at 2:37 PM
    #259
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Gotta wait till Monday to get this done....
    It will at least give me a chance to change my plugs this weekend
  20. Oct 4, 2014 at 4:55 PM
    #260
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I am getting this done on Monday, so why do you need to have the transmission manually reset? I know nothing about these things...
