T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Nov 17, 2014 at 3:08 PM
    #341
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I'm sure happy I found this thread. My truck started knocking about 4 months ago. I took it in to the dealer with a cold start knock. I could hear it sometimes at warm idle and low torque acceleration. The tech said it was normal, said that I would have to leave it overnight so he could check it in the morning. I even showed him a video that I taped of the truck that very morning. Said he would have to hear it for himself to diagnose. I documented it. I then had it's complimentary oil change done done. It seemed to lessen. I then reset the ecu by disconnecting the battery. It went away. It's back. I listened to the videos of this (ping) and its exactly what my truck is doing. Finally a path to a fix!!! I'll make a dealer appt tomorrow for the tsb and let everyone know how I fared. Thanks guys, a lot.
  2. Nov 20, 2014 at 10:40 PM
    #342
    TeeAreDee
    TeeAreDee Member
    Bonney Lake, WA
    2013 TRD Sport DCSB 4x4
    3" spacer lift, Bilstein 5100 rear shocks, 17x9 Fuel Formula - D559, Falken Wildpeak A/T3W 285/70/17, TRD Exhaust, WeatherTech mats front and rear, 13" flexible antenna, Kicker 40CS674 6-3/4" CS-Series Coaxial Speakers (front & rear), LED Interior lights, LED License Plate and Reverse Lights, AVS In Channel Vent Visors. I did the T-SB-0044-14 Reflash!
    My knocking issue began not long after my first oil change. Switching to 91 octane helped a lot but did not completely eliminate the knocking. When I read about this TSB I was happy there was a solution to the one thing I absolutely hated about my new Tacoma. Filled my truck with 87, printed the TSB from this thread and took them both to the dealer here in Guam to see what they would do. Well to my pleasant surprise they were able to replicate the knocking and said they would need to reflash the ECM as per the TSB. Well, I had that done 2 days ago and I am happy to report that the knocking seems to be gone. I am on my second tank of 87 octane so we'll see after a few more fill ups. I too have noticed that shifting seems a little smoother now or that the shift points seem to be different rpm as compared to before. So far I am happy with the reflash.
  3. Nov 21, 2014 at 7:49 AM
    #343
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Nice, I'm calling today to get mine in for that and the brake recall.
    So ridiculous to have to put 89 or 91 octane in to make it stop. I put 87 in yesterday and I started it up and left this morning... It sounds so terrible!!! Hopefully they will fix it.
  4. Nov 22, 2014 at 8:09 AM
    #344
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    I'm really glad I found this thread. I've saved the PDF and emailed it to myself with the TSB# in the subject. I am literally sitting in my dealer's customer waiting area right now as I dropped it off with this exact same headache. He said "pinging is normal in these engines so I don't know that they'll do anything about that."
    Pinging occurs well after warm up even after 20mi of highway driving. I'm running 91 all the time now (truck drives better so I like it better and the price difference is hardly noticeable if you do the math.) Mine kicked up a little after 30,000mi and I really noticed it when I did my first oil change off of service and used Royal Purple full synth 5w-30 as per the manual.
  5. Nov 22, 2014 at 7:01 PM
    #345
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Well, Took mine in today to have the TSB performed as a "goodwill" service as they labeled it. They performed it as graciously as I guess I could expect them to after I had to complain to even get this far. Instead of the 4hrs I waited last time to have nothing done, today took and and hour and 20 minutes with having TSB performed. They also placed the sticker under my had as well. Now onto the good part....NIGHT AND DAY difference, the truck is so much smoother and quieter in every regard I don't even feel like its the same truck. Shifts are smooth and engine power is up, Taco tick at idle and while driving has decreased vastly as well. Idle at stoplights is smooth as butter, I thought the truck wasn't even running. I will have to report back on the pinging once it warms up, supposed to get warm again next week here.
    With how much better the truck acts now, makes me wonder if running it 37k miles before the TSB has caused any premature wear or damage to the engine. Toyota should be performing this TSB for all who apply, the truck should of came like this from the factory.
  6. Nov 22, 2014 at 8:41 PM
    #346
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Hey just checking in on the thread...looks like continued good results from this TSB. I'm well over 3000 mile since it has been performed. So far my truck is running just like it did after the TSB. I'm still using 87 regular fuel.
  7. Nov 24, 2014 at 5:42 AM
    #347
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Well its in the 70's here today and it has always pinged from 60* upward, truck is just as silent and smooth as can be. I have also noticed two other issues that the TSB has seemed to fix for me, 40-45 pulsating is gone and it doesn't bump me as hard when the a/c kicks on while sitting at a stoplight. Idle is also much improved with the a/c on as well.
    clinteastside likes this.
  8. Nov 24, 2014 at 10:55 AM
    #348
    jareebz
    jareebz Well-Known Member
    TX
    2019 TRDOR DCLB
    At the dealership now to get mine done. Fingers crossed they do it and don't tell me it's normal.
  9. Nov 24, 2014 at 12:16 PM
    #349
    jareebz
    TX
    2019 TRDOR DCLB
    Aaand they did the TSB. Truck drives GREAT now. So happy I got it done.
  10. Nov 26, 2014 at 1:43 PM
    #350
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Getting the tsb done right now, had to pull some strings because they gave me the bs line of we have to replicate the problem.
  11. Nov 26, 2014 at 2:16 PM
    #351
    zeekevin
    San Diego
    And it's done. The truck drives a lot better, shifts smoother and idles better now
  12. Dec 2, 2014 at 5:48 AM
    #352
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    update since TSB: Traveled to the mtns with mine this weekend, put about 1,000miles on her. Pinging is still gone, used to be horrible going up the mtns. Fuel mileage is also up by 1mpg and highway smoothness is much better.
  13. Dec 2, 2014 at 8:09 AM
    #353
    zeekevin
    San Diego
    I gained about 1.5 mpg if I still use Cali 91 .5-1mpg if I use Cali 87. But no more knocking and the engine feels more alive
  14. Dec 2, 2014 at 8:40 AM
    #354
    gonathan85
    Nate
    Central California
    Hello again! I'm nearing 4,000 miles since having the TSB performed. I'm still using 87 regular unleaded fuel, and the truck is still running great with the pinging noises reduced by 98%. I think the engine/transmission ECU "re-learned" my driving style, and it doesn't drive quite as smooth as it did immediately after the TSB was performed. Even so, I do believe that it does drive/shift better than before the TSB was performed.
  15. Dec 2, 2014 at 5:56 PM
    #355
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Here is my update. +1mpg in the city and almost +2mpg highway. No knocking, although I only run 87 and with about 1000lbs of stone in the back coming home from GA, I got a little detonation when flooring it to pass today, but apart from that I have put on about 4000 miles since the update and and really happy. My truck is running really smoothly and the shifting is a lot better. With cruise off, it will pretty much hold OD at around 2000rpm up most hills.
    Anyway, for me this is the best thing that has happened to me Baja Taco since I picked it up...:cheers:
  16. Dec 2, 2014 at 6:03 PM
    #356
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ok thats it i need to get this TSB done.
  17. Dec 2, 2014 at 7:40 PM
    #357
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    It is worth it! My truck is a whole different vehicle now, my dealer was hesitant at first but I was persistent and they performed the TSB. Good luck!
  18. Dec 3, 2014 at 5:58 AM
    #358
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    One last note: with the stone in the bed, running 72->74 mph, I got 18.8mpg, which is really good for me.....
  19. Dec 24, 2014 at 9:59 AM
    #359
    gonathan85
    Nate
    Central California
    Hi Guys - Merry Christmas!
    5000+ miles since my TSB was performed - still running nice and strong, without unnecessary pinging chirping clunking noises :thumbsup:
    Have a great new year!
  20. Dec 28, 2014 at 2:31 PM
    #360
    zeekevin
    San Diego
    I just hit a record best 19mpg 90% hwy 10% city on 91 winterblend California gas before the reflash I was lucky to get 17mpg
