T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. May 7, 2015 at 7:04 PM
    #441
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    My truck started pinging badly this week now that the weather has warmed up. Its always done it a little bit but now it sounds like my engine is filled with marbles. I'm at 17,000 miles. Its going into the dealer tomorrow for the TSB work. Hopefully it fixes the problem but I am concerned about any long term effects this pinging may have caused to the engine. Does anyone know if this will shorten the engine life? I liked this truck when I first bought it and planned on keeping it for many years but its starting to become a POS and its only 9 months old.
  2. May 7, 2015 at 7:56 PM
    #442
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it won't shorten engine life at all, this TSB sets the PCM/ECU program that toyota should have set up
    in the ECU. it's a bugfix really. my 2013 runs super sweet and never pings anymore
  3. May 7, 2015 at 7:59 PM
    #443
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Did everyone get the sticker under the hood after having the TSB done, like it says in the TSB for the dealer to do?
    I didn't, but my experience with the dealership was beyond horrible, so I don't even want to go back for it. Does it matter for anything as long as I know it was done?
  4. May 8, 2015 at 12:27 AM
    #444
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    The dealer I went to performed the TSB, but didn't put the sticker on either. When I called in the other day to ask about recalls, they said there was one for the sticker under the hood. They are replacing the clear plastic guard on the lower part of the truck, so when I go in, I'll just have them put the sticker on. It's probably not a big deal if you don't get it, it's probably more for Toyota than anything.
  5. May 8, 2015 at 4:46 AM
    #445
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Any more info on this?
  6. May 8, 2015 at 5:30 AM
    #446
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  7. May 8, 2015 at 10:26 AM
    #447
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    What is the TSB for that "electronic brake work"?
  8. May 8, 2015 at 10:33 AM
    #448
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    not a TSB it's an actual safety recall
    if your VIN shows up as affected on toyota recall site your brake controller and VSC/Trac is reprogrammed
    https://www.tacomaworld.com/threads...y-recall-brake-actuator-reprogramming.324219/
    Now all it means is the truck may default to ordinary brake mode, (old skool like we learned back in the day) and not have the skid control ECU handle braking for you. So it is kind of a minor thing but statistics show the skid control/vsc/trac can save yer arse on many situations...this makes sure it doesn't crap out on you unexpectedly
  9. May 8, 2015 at 10:38 AM
    #449
    BaconPower
    Portland, OR, USA
  10. May 8, 2015 at 10:42 AM
    #450
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Call the dealership would be my guess.
  11. May 8, 2015 at 1:59 PM
    #451
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    here
    Toyota Recall Site
  12. May 8, 2015 at 8:22 PM
    #452
    Turd Ferguson
    Taxachusetts
    I had the TSB ECU update done this morning. The pinging seems to be gone. Hopefully it stays that way. Also they didn't put a sticker under the hood.
  13. May 9, 2015 at 12:05 AM
    #453
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    On the lower part of the door panel, there is a clear-ish film on the bottom part of the door that helps protect against rocks, etc. Mine is peeling a little, so they are replacing it. Basically, it runs from the crease in the door down to the lower part of the door. It looks like orange peel, but its a clear liner that protects the paint.
  14. May 13, 2015 at 1:05 PM
    #454
    BaconPower
    Portland, OR, USA
    Most dealerships stopped ordering these stickers years ago and are relying on reading the ECU firmware version directly instead. Less error-prone.
    Ripper likes this.
  15. May 13, 2015 at 2:47 PM
    #455
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Update. I had this tsb done around a year ago, and with the warmer weather, it has started to ping again, just not as long. It's not as bad as with the A/C on, but during the summer, I'm afraid I'm gonna "have a lot of pingin' goin on". Between the brake clacking sound and this pinging, I'm about to pull my hair out. :annoyed:
  16. May 13, 2015 at 6:01 PM
    #456
    zeekevin
    zeekevin Well-Known Member
    San Diego
    mine is doing the same thing also. I might pull the battery to reset the ecu
  17. May 13, 2015 at 8:59 PM
    #457
    Sledhauler
    Sledhauler Well-Known Member
    Derek
    MD
    13 DCSB TRD Sport 4X4
    I'm done feeding mine premium, it ran smooth on it but at 13-14 avg mpg it had to go. I'm now have a 4runner avg 17-18 and no pinging on the cheapest gas I could find. I also needed more cabin room with now a third along for the ride.
  18. May 22, 2015 at 4:35 AM
    #458
    Dr. Cornwallis
    Dr. Cornwallis Well-Known Member
    Flarrrrrrrida
    2016 Super White TRD Offroad 4x4 AC
    Fwiw, I think the pinging is caused by carbon buildup. I ran some sea foam through and it seemed to make it better, although not perfect. I may so a few more treatments of sea foam to see if I can flush everything out.
  19. May 26, 2015 at 9:12 AM
    #459
    BaconPower
    Portland, OR, USA
    TSB done. No more pinging and MPG went from 14 to 16.
  20. May 26, 2015 at 9:44 AM
    #460
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Great news!
