T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. May 26, 2015 at 3:37 PM
    #461
    Bob Schultz
    Bob Schultz Active Member
    Bob
    Ventura Co.,
    2013 Prerunner DC
    Had mine done this morning. DCH Toyota, Oxnard verified my vin and re flashed. Towing my 5000 lb trailer up to Redding and hope no pinging. Took 3 hrs but if no pinging was worth it.
  2. May 26, 2015 at 3:48 PM
    #462
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pre TSB 2012 here. Knocking and pinging have been present fom day one. Seemed to have went away some with the fuel pump replacement.
  3. May 26, 2015 at 7:58 PM
    #463
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Same issue here (2012, 4.0 L, 87 octane, 44k miles). Just got TCU done at dealership, and knock almost completely went away, almost. I'm thinking that both carbon buildup and poor stock tune are to blame for me, since the new tune significantly decreased my knock, but did not eliminate it. Might try sea foam and new plugs (doubt previous owner changed original plugs, bought at 40k). Probably going to run higher octane based on previous posts. Will update once done
    *UPDATE*
    Before I did any maintenance, I put in mid-grade (89 octane) gas and that completely eliminated what little spark knock I still had after the dealership ECU reflash. I decided to change spark plugs anyway, and sure enough it ran even smoother. I might try a bit of 87 octane to remove the octane variable and see if the flash and plugs solved the issue.
    Also, I used a borehole camera to check out my cylinders, and they weren't exactly pretty, they appeared to have both carbon buildup (not surprising) and be wet with oil (not standing oil, just wet). Not sure if this is normal, but it may contribute to the issue at hand. I'll start a different thread with pictures as to not hijack.
  4. May 27, 2015 at 9:25 PM
    #464
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Anyone here had any success getting a reflash on a pre 2012 tacoma and ending the pinging issue?
  5. Jun 2, 2015 at 4:06 AM
    #465
    sr5dude
    sr5dude Active Member
    california
    2013 Baja access w/TRD supercharger
    TRD supercharger
    I have a 2013 Baja with SC. It now has 30k on it. At the 15k service I experienced the same thing. Paint on zert fittings. I took the truck back, they were embarrassed that I caught it, immediately, and humbly took my truck in and lubed all items with jerk fittings. These ARE NOT lifetime, you don't need to lube u joints. They need to be lubed every 15k. I also purchased the extra service to 45k
    My second note is I believe the truck is running too rich. MPG between 15 to 18. No pinging. I have never seen 20mpg even pre SC. Tail pipe is very sooty.
  6. Jun 2, 2015 at 9:15 AM
    #466
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I have a feeling Toyota was only addressing the problem for the Gen 2.5 trucks and basically telling the rest of us to screw off. I consider this a pretty big latent defect on their end. My 2011, produced in June 2011, immediately pings in the RPM range described by TSB. It exhibits all of the same symptoms, yet there is no fix. That said, this hasn't affected my MPG. Its just embarassing that this truck sometimes sounds like the engine isn't maintained between the normal ticking and occasional pinging.
    I recently ran 2-3 tanks of 93, which muffled most of the pinging. I transported a bed full of mulch, and no pinging was audible. I dropped to 87 again for this week, and it immediately became noticable again.
    The only way to make it go away on your own is to get a piggy back ECU, and get the engine tuned to run on 87 octane.
  7. Jun 2, 2015 at 9:29 AM
    #467
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I agree, it is just a piece of the programming that is missing or has incorrect settings. mine used to ping every damn day, after the software update, it never ever pings. perhaps they don't want to tie up engineering on older trucks based on number of complaints-to-year
  8. Jun 2, 2015 at 9:37 AM
    #468
    mbrogz3000
    Northern NJ
    Agreed - I remember reading that that ECU updates that potentially affect Air to Fuel ratios need some level of requalification and approval by the EPA since there is potential impact to emissions.
    Does anyone, with 2005-2011 V6, know if the TRD supercharger and flash resolve the pinging?
  9. Jun 4, 2015 at 7:29 AM
    #469
    buckmark32
    buckmark32 Well-Known Member
    Christian
    Jacksonville
    14 Taco 4X4
    Stock
    Do any of you all know if this happens in the LATE 2014s? I have a 2014 4cyl 5spd... and I honestly dont know if this is happening. I have recently towed a dual axel trailer with a Yamaha Rhino and John Deere home lawn mower on it... I really didn't seem to hear or notice any issues. The haul was 3 hours to the hunt club. I am not sure of my build date, but all of your posts to concern me....
  10. Jun 4, 2015 at 8:10 PM
    #470
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I just purchased a 2012 TRD Off Road that has 44,000 on it. I haven't noticed any unusual pinging noises, but I'm not one to listen for them either. I just read every post on this thread and don't see any problems trying to get this completed if a dealer is willing.
    Since it is a software update wouldn't everyone who has an effected year benefit from this update if a dealer will do it? Or if there are no symptoms will they never come, or do we just hope they happen before the warranty expires?
  11. Jun 5, 2015 at 7:52 AM
    #471
    DouginNC
    DouginNC Well-Known Member
    Doug
    North Carolina
    2014 Double Cab TRD Sport
    Had this update performed today. Quick and easy, taking less than an hour at the dealer. I don't really notice any drivability difference, other that it may be shifting into a lower gear more readily than it did in the past. As far as knocking, mine would only do it under load going up a hill, and I only heard it twice before the update. Didn't hear it any today after the fix. I've been getting 21 MPG lately... time will tell if this update changes that.
  12. Jun 7, 2015 at 12:51 AM
    #472
    Jasper
    Jasper New Member
    Fair Play, SC
    Tacoma 4X4, Sport TRD
    2014, 11000 miles, 87 with NO Ethanol. No Pings.
  13. Jun 9, 2015 at 5:42 PM
    #473
    Tectonic
    James
    Tucson, AZ
    I would go ahead and request *demand* the dealership give you the reflash. I have basically the same truck with the same mileage and it just started pinging a month or two ago. They should do it for free like mine did, and you never know when they will just say the service is no longer covered for free.
    I think the pinging (since it seems to be spark knock) is likely associated with warmer temps, so posters who don't live in ungodly hot locations like I do may not have the environmental factor.
  14. Jun 11, 2015 at 6:42 PM
    #474
    mike15
    mike15 Well-Known Member
    PA
    2021 Tacoma Limited
    I have a very slight pinging. Is it worth having the TSB done?
  15. Jun 11, 2015 at 6:51 PM
    #475
    zeekevin
    zeekevin Well-Known Member
    San Diego
    It should be covered under the 60k powertrain warranty
  16. Jun 11, 2015 at 7:51 PM
    #476
    DouginNC
    Doug
    North Carolina
    Yes. You might as well have the most current software running your truck. It doesn't take long to have it done.
  17. Jun 11, 2015 at 7:59 PM
    #477
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    no
    it's covered under the 80,000 mile emissions warranty
    Norton likes this.
  18. Jun 11, 2015 at 8:00 PM
    #478
    zeekevin
    San Diego
    Even better
  19. Jun 12, 2015 at 3:32 AM
    #479
    Tectonic
    James
    Tucson, AZ
    +1 I found no change in performance, and it got rid of the pinging
  20. Jun 12, 2015 at 9:05 PM
    #480
    mike mudry
    mike mudry Mike in AZ
    AZ
    12 DC 4x4 Taco TRD Sport
    Billy's set at 2.5", Avid Offroad light bar, N Fab steps. Weathertechs. Rear view mirror relocation bracket. Rear sliding window bar. 265 70 18. Upgraded sound system.
    I completed mine a few days ago at 43k. For the last two years I've been running mid-grade fuel to minimize the pinging. Big Two Toyota, in Chandler AZ, completed it with no questions asked after I provided the TSB number to them. My truck runs a hell of a lot better now. I filled it up with regular unleaded and have rarely heard any pinging during the first 100 miles with the daily temperature between 90-102. Multiple tests of driving down the freeway at 55 with the RPM's at approximately 1800 and then punching it has given me immediate engine response. Prior to that the truck would hesitate slightly, ping, and then drop down a gear. Now it just goes. Lastly, the engine just seems to idle smoother. I don't know if this is the placebo affect, but regardless, I appreciate the prior posts and education.
