T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Aug 31, 2015 at 1:38 PM
    #521
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Over the past 6 months my truck had developed a knock under the conditions noted in this TSB. Lately its been pretty constant. I should have taken the truck in sooner but finally had it done today. At the dealership I went on a drive with the tech to show him the noise, the TSB, and he agreed. After it was completed we drove around and the knock had gone. It sounded and felt smoother running as well. Glad I got it done
  2. Sep 3, 2015 at 8:30 AM
    #522
    Taco1987
    Taco1987 Active Member
    Daniel
    Louisa, Virginia
    2014 Tacoma SR5 Double Cab
    3" Rough Country Lift 265/75/16 Spidertrax
    Ditto here, went to the dealer, performed the TSB, it fixed it and runs great. No losses in power. :thumbsup:
  3. Sep 3, 2015 at 11:56 AM
    #523
    btwice22
    btwice22 Well-Known Member
    Bryan
    Cincinnati, OH
    2013 Tacoma TRD Dbl cab
    Window tint. LED's inside and out. Sylvannia Ultra Headlight bulbs Nokya 2500k fogs Digital Weathertechs Thule Xsporter
    In Cincinnati temps have been in upper 80's. Just yesterday I noticed the aforementioned pinging noise exactly at 1500 rpms with the AC on. I always use 87 gas too. I agree that if Toyota has a solution go with that bc we shouldn't have to run 93 gas in these trucks. Thanks to the knowledge in Tacomaworld the problem is hopefully getting fixed tomorrow by the dealership for FREE. I'll follow up to see if the TSB works.
  4. Sep 3, 2015 at 11:57 AM
    #524
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Did this TSB today and the noise is gone!
    TAZ2014Taco likes this.
  5. Sep 3, 2015 at 12:43 PM
    #525
    btwice22
    Bryan
    Cincinnati, OH
    ^^^^^:rofl: THAT SIGNATURE GIF IS FUNNY AS FUG
  6. Sep 3, 2015 at 12:43 PM
    #526
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    thanks haha! it is a classic
  7. Sep 3, 2015 at 12:50 PM
    #527
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Glad to hear the word is spreading about this TSB.
  8. Sep 3, 2015 at 7:52 PM
    #528
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    My 2013 dclb 4x4 is pinging like a sonar under load. I tried switching from 87 to 91 octane but #1, no big difference, #2 most threads read that our trucks are rated for 87 and not to use 91 or 93. Will higher octane hurt the engine? It sucks because it only has 30,000 miles but if something needs being looked at I am glad it is under the bumper to bumper warranty though. Can they reflash the truck if you ask them too? Do I just go in their and say "can you do this tsb for my truck?"
  9. Sep 3, 2015 at 9:09 PM
    #529
    ASUAviator
    Anchorage, AK
    Tacoma TRD Off Road
    Typically they have to verify the sound before doing the tsb. Take your truck in and say you want to take a tech for a ride to listen to the noise. hopefully you can hear it and have the tsb handy to show them you think that is the cause. If it is hit or miss on pinging try having a video ready.
  10. Sep 3, 2015 at 9:18 PM
    #530
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Typically yes.
    But call around. One of the dealers in my area i talked to a guy that just so happened to know of the TSB, said bring the truck in ill do it for ya in an hour. Had it done in 40 min, was awesome.
  11. Sep 9, 2015 at 10:02 AM
    #531
    gonathan85
    Nate
    Central California
    Just a heads up. This wasn't the case with my truck. I brought the printed copy of the TSB, explained the issue, and told the service writer that there was currently premium grade fuel in the truck so it was unlikely to ping aggressively. I picked up the truck later that day, and the TSB was complete.
    Norton likes this.
  12. Sep 9, 2015 at 12:45 PM
    #532
    btwice22
    Bryan
    Cincinnati, OH
    TSB completed free of charge at Toyota. I printed the TSB off and took it with with to the mechanic. Knocking sound gone. Running 87 gas and life is good.
  13. Sep 10, 2015 at 4:11 PM
    #533
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Talking to Toyota on the phone now trying to resolve this for my 2011. No TSB yet (or probably ever) for this model. Truck sounds like crap and it cannot be good long term.
  14. Sep 14, 2015 at 3:47 AM
    #534
    Taco One
    Taco One Well-Known Member
    Bone Stock 2011 TRD Sport
    I changed the plugs at 45k on my 2011 Taco and pinging essentially went away, however it is cooling Down without the 90% humidity.
    I know the plugs were recommended to be changed at 30k (Emmisions Warrenty) but I scoffed at the idea since my 2007 4Runner went 85K with factory plugs and ran just fine. Only reason I changed them in the runner is the on board computer showed a drop in gas mileage, by about 4 mpg.
    Plugs I pulled from the Taco were worn far worse than the runner. Gap had increased to .between .045 & .050+ Very obvious worn electrode. Plugs looked like they had been in the car years and years. Same factory plugs, same engine but very different wear and results.
  15. Oct 23, 2015 at 5:39 PM
    #535
    TheK
    TheK New Member
    FYI my 2013 was pinging badly prior to TSB. Had TSB performed and while the truck is not pinging nearly as much as before the TSB on a 80+ degree day I am still hearing pinging under certain throttle loads on 87 octane. Disappointing. Also the dealer did not install an modification label under the hood. Anyone else have a similar experience?
  16. Oct 23, 2015 at 6:00 PM
    #536
    DouginNC
    DouginNC Well-Known Member
    Doug
    North Carolina
    2014 Double Cab TRD Sport
    Mine doesn't ping anymore and I've driven on several 90+ degree days. Dealer didn't install the sticker.
  17. Oct 23, 2015 at 6:03 PM
    #537
    DouginNC
    Doug
    North Carolina
    Same here. My dealer didn't question the TSB, they got the truck in and done in short order.
  18. Dec 7, 2015 at 6:46 AM
    #538
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    did you get this done? Where in Jax did you go? How are your results?
  19. Dec 10, 2015 at 4:49 AM
    #539
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    Well here I am sitting at the Toyota dealership trying to get the spark noise TSB done lol
    Of course they said that it might be due to my intake among other things needing cleaning and that service is on sale for $189 lol
    I think I will def decline that service when they return (I hate coming here)
    Also said there will be a $65 diagnostic charge (waived if it ends up being warranty related) I wasn't really expecting to hear that. Anyone else been told this? The guy said only about 30% of tacos actually need the TSB done (to which I assume in my mind the other 70% get slapped with the $65 fee lol)
  20. Dec 10, 2015 at 6:08 AM
    #540
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ^^ you are getting screwed
    they should just go for a ride, hear the knock and do the tsb with no bullshit
    Norton likes this.
