T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Mar 30, 2016 at 2:41 PM
    #561
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yes the trans learns how you drive. A disconnect of the battery resets this back to its default state.
    The TSB has done nothing for shift points. But it does seem like it stays locked up in 5th slightly longer with more throttle input which is a good thing. That stated at 32mph under light throttle input the trans will try to do 5th lockup regardless, its how its coded.
  2. Mar 30, 2016 at 3:24 PM
    #562
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Yep - what he said.
  3. Apr 6, 2016 at 2:52 PM
    #563
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    If the TSB doesn't change the shift points, how come people are saying it makes the 4-5 shift smoother? I notice my 4-5 shift is rough under light throttle when it shifts at sub-1,500 RPM but if I get on it a bit more and it's above 2,000 RPM it shifts fine.
    It has to do something about the lockup points, at a minimum, I'd think. I'm going to fight for this at my next oil change. I am going nuts with the constant locking and unlocking of my converter every time I'm on/off the gas.
  4. Apr 6, 2016 at 3:38 PM
    #564
    gonathan85
    Nate
    Central California
    You shouldn't have to fight to have this TSB performed. Print the TSB, bring it with you when you talk to the service writer face to face, and be patient/kind but firm in the fact that you want it performed under the 8x,xxx mile emissions warranty period. You should be fine. If you absolutely need to, appeal to the service manager.
  5. Apr 6, 2016 at 3:58 PM
    #565
    nd4spdbh
    SoCal
    I think it has something to do with how power comes on after the TSB. The only shifting difference i have noticed is the fact that it will stay in lockup longer. Meaning it could possibly be making a little more power at less throttle input to allow me not to have to push the accelerator down to a point where the trans goes... ok he wants the next gear.
  6. Apr 6, 2016 at 4:19 PM
    #566
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    for me it drops to 4th sooner, and stays in 4th longer, for fixed throttle position on a hill
    I drive daily... steep, around 30 mph, and in D
  7. Apr 6, 2016 at 4:22 PM
    #567
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Do you have a ScanGauge?
    I notice driving in 4 raising my transmission temp compared to OD so I was curious what you've seen.
  8. Apr 6, 2016 at 5:47 PM
    #568
    nd4spdbh
    SoCal
    probably because you are not in lockup in 4th.
  9. Apr 6, 2016 at 5:53 PM
    #569
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Most likely. It's incredibly difficult to get it to lock in 4th. I see a lot of members here advocating driving around town in 4 to alleviate the issues these trucks have, but seeing transmission temps rise so much always make me nervous.
  10. Apr 6, 2016 at 5:54 PM
    #570
    nd4spdbh
    SoCal
    Put the trans in 4th, it should lockup rather quick.
  11. Apr 6, 2016 at 6:11 PM
    #571
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I don't see it doing it. I mean, sometimes I've gotten it to do it, but I have to be on a dead flat road with absolutely no modulation of the throttle. Regardless, typically the second I go in 4th, I watch my transmission temps go up 10-20 degrees (I believe I'm seeing converter temp as the pan temp wouldn't fluctuate that fast).
  12. Apr 6, 2016 at 7:12 PM
    #572
    nd4spdbh
    SoCal
    yeah if you are seeing 10-20 deg swings in a few seconds that converter output temp for sure. I have watch converter output temps shoot 40* and pan temps only go up 5
    Its harder to tell 4th lockup vs 5th lockup because in 4th you are closer to the stall rpm of the torque converter so the difference in rpms lockup makes isnt as much as it would be in 5th.
  13. Apr 10, 2016 at 1:39 AM
    #573
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I have a 12 off road and as far as I know I don't have pinging running 87. I also have no idea what pinging sounds like. I've printed out the TSB but don't know if I should try to have this done. Since it's only a software update wouldn't it be a improvement or could it make my truck ping.
  14. Apr 10, 2016 at 10:56 AM
    #574
    gonathan85
    Nate
    Central California
    Hi - all good questions. If I were you, I'd probably bring the printed TSB to your service manager to show him you're aware of the potential problem. This will give you a chance to have it performed, or at least set a point that he and you can look back on and reference if you need to perform it at a later date.
    If you want to have it performed, we have seen no negative effects so far. I've had the TSB on my truck for 50,000 miles now.
  15. May 12, 2016 at 8:56 AM
    #575
    The Cokeman
    The Cokeman Member
    2012 TRD Off Road 4x4 Tacoma Double Cab
    TSB done today. No more pinging on 87oct gas. Power still good. Don't know if mpg affected yet.
  16. May 13, 2016 at 10:13 AM
    #576
    gonathan85
    Nate
    Central California
    I haven't seen any changes in mpg due to the TSB. I've had it done for ~25,000 miles now. The biggest change in mpg I've noted is due to change from stock dunflop tires to Cooper Discoverer AT3 265/75-16s P-rated. ~18 avg mpg is now ~16.5 (it's also possible that my foot got heavier over time...more skinny pedal :D)
  17. May 30, 2016 at 9:42 AM
    #577
    Taco One
    Taco One Well-Known Member
    Bone Stock 2011 TRD Sport
    Mine is a 2011 Tacoma and not adjustable from what I've been told. I've started running 89 & 93 Octane from Chevron & Texeco. I had been running 87 from the cheapest place in town, Typically Wal-Mart or Raceway. Change in fuel over the last 10 tankful so or so seem to have made a difference. Clearly not as bad as it was, but will see as the weather heats up and humidity increases. Poorest its ever run was in the July-August, 95+ Degrees with 100% Humidity.
  18. May 30, 2016 at 5:01 PM
    #578
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Still no pings or issues since I had the TSB performed. I've always ran either running 89 octane or 90 octane No Ethanol.
  19. Jun 6, 2016 at 2:41 PM
    #579
    gonathan85
    Nate
    Central California
    *thumbs up*
  20. Jul 18, 2016 at 2:42 PM
    #580
    bigfro
    bigfro Well-Known Member
    Denver
    13 TRD Sport DCSB
    Billy 5100 @ 1.85 + shim on L for Taco Lean Icon AAL 3 pack w Rear Overload Removed
    I live in CO and have never had an issue with any of my non-turbo vehicles (except for a high compression v6 I once had) with running 85.
    My 2013 Taco on the other hand was a pinging machine. Onramp, going up hills, etc. It got much worse with a lift kit and topper....
    Today they flashed the truck..
    All I have to say is holy shit..... No idea the 4.0 would run that quiet. Zero pings on 85 here. (i'll prob step up to 91 as the service manager said it will run better on 91)
    Just an FYI if you have a 12' or 13' do this. no brainer. easy.
    gonathan85[OP] and Norton like this.
