T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Apr 28, 2017 at 3:25 PM
    #601
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Did they read the TSB themselves? If I were you, I would highlight the section that shows which vehicle(s) this TSB applies to, then bring it back to them with your highlighted paper and have them read it out loud in front of you. Should do the trick. Don't do it "smugly," but go in there confidently but firm.
  2. May 22, 2017 at 7:19 AM
    #602
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    Well I just scheduled service to have my truck dropped of Wednesday for this. Guess we will see what they say.
  3. May 22, 2017 at 8:07 AM
    #603
    skrazz
    skrazz 2013 SR5 4x4 4.0L AC
    Joshua
    St. Petersburg, FL
    2013 SR5 4x4 4.0L AC MGM
    It took 2 test drives but finally a tech heard the pinging and accepted/applied the TSB on my 2013. He said it didn't fix the issue and offered to do an "top-end engine clean" which they described as spraying a can of stuff into the intake while the motor was running to clear any carbon build up. I politely declined, as this is something I would be comfortable doing on my own (I believe Seafoam has a kit for it). After my first fresh tank of regular gas, the ignition system seemed to "learn" the required timing and I've been ping free for the last 3 tanks. No more need for premium! And I haven't done the top end cleaning, as there shouldn't be much carbon based on my lack of miles+driving habits.
    Not sure if this has been stated but they will NOT do the TSB unless they hear it, so expect a fight if they come back saying "sorry". You know your truck better than them.
  4. May 22, 2017 at 1:21 PM
    #604
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Mine did the tsb because I asked them nice.
    I brought it in in dead of winter [and to reproduce the issue it has to be 80 degrees
    out or more according to the tsb]....so I asked well gee no way to repro but it does
    do it...they did it. solved 99% the pings. every once in a blue moon it may ping
    but it used to happen 5 times a day. now, almost never
  5. May 22, 2017 at 7:16 PM
    #605
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    A word of caution to anyone thinking about installing a supercharger... Having this (or any ECU flash) done prevents updating the ECU with the required supercharger tune. Doesn't matter if you roll the dice with Magnuson's BullyDog tuner or go to Toyota. Once your ECU has anything other than its original tune/firmware, you're SOL. Your only option will be to buy a "virgin" ECU, which are becoming hard to find since everything from Toyota is pre-updated.
    Yes, this is the voice of experience. :frusty:
  6. May 24, 2017 at 12:02 PM
    #606
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Dropped the truck off at 10am. Toyota called at 1300 saying the tech that drove the truck did hear and feel the "pinging" and would be performing the fix for me.
  7. May 24, 2017 at 12:16 PM
    #607
    jca
    jca Well-Known Member
    My truck is currently at the dealership for this TSB. Provided the print out and everything. I will provide an update if they can "reproduce the symptoms" and reflash the ECM. Wish me luck.
  8. May 24, 2017 at 3:47 PM
    #608
    jca
    Got it done. No more pinging. Thank you OP and the TW community once again!
  9. May 25, 2017 at 6:01 AM
    #609
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Thats a lot more in depth then mine was lol.
    "Customer requesting T-SB-0044-14 - STATES PINGING AT 1800RPM, UNDER LOAD, UPHILL, WHEN ABOVE 80DEGREES OUTSIDE."
    "TECH TEST DROVE AND HEARD AND FELT SPARK DETONATION."
    "REPROGRAMMED ECM"
    But whatever they did, man its better by 10 fold. My butt dyno even says its more responsive and has more power. Ive noticed my engine runs quieter, smoother, and my exhaust tone has also changed. I always swore I had an exhaust leak, but that sound went away too.
  10. Jul 14, 2017 at 7:55 PM
    #610
    Ren
    Ren Well-Known Member
    Denton, TX
    White 2012 Pre-Runner DCSB
    So, my 2012 just started this pinging under light acceleration a few weeks ago, but I'm at 95K miles. I assume I'm SOL and they won't do the TSB for a truck with that mileage?
  11. Jul 14, 2017 at 8:13 PM
    #611
    Norton
    They'll probably do it, but charge you. IIRC, local dealer tried to charge me ~$75 for it before I reminded them mine was still under warranty.
  12. Jul 15, 2017 at 7:43 AM
    #612
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  13. Jul 15, 2017 at 7:45 AM
    #613
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What issues are you running into? I got the tsb done but I want to do the supercharger sometime in the future.
  14. Jul 15, 2017 at 12:02 PM
    #614
    Norton
    As I said, once flashed for the TSB, the ECU must be replaced (with a "virgin" unit) if you want to run the TRD flash/tune. Toyota is unable to flash the ECU a second time.
  15. Jul 15, 2017 at 12:06 PM
    #615
    Bebop
    Nick
    I understand that. Are you running into drivability issues with the supercharger and the tsb flash?
  16. Jul 15, 2017 at 12:24 PM
    #616
    Norton
    No idea. I bought a virgin ECU that I had flashed with the TRD supercharger tune. No issues running that.
    Neither the stock nor TSB tune is appropriate for use with a supercharger, since they don't account for the increased amount of air entering the engine or the larger fuel injectors that come with the kit.
  17. Sep 18, 2017 at 11:45 PM
    #617
    I married my tacoma
    I married my tacoma Well-Known Member
    Klaus
    Location, Location, Location
    14 Tacoma
    Op, thank you for this post. I read this about a year ago and had the TSB performed. @25K Little to no spark knock remaining since @35K
  18. Sep 19, 2017 at 10:43 AM
    #618
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    8 years/80k miles; maybe they'll have some mercy on you as you're under the 8 years..
  19. Oct 17, 2017 at 9:40 PM
    #619
    MJTaco
    MJTaco Well-Known Member
    Mark
    Sonoma, CA
    2013 Super White AC TRD Off-road
    Front skid plate, running boards, camper shell, bed rug mat, Thule rack, Wolf 1/2inch spacers.
    Just had the TSB done today. No trouble at the dealership, they were great actually! I just described the symptoms, took a tech for a drive, and they did the flash for no charge under warranty. On the drive to the dealer I could consistently get it to ping, after the update I could not get it to ping no matter how hard I tried. Very happy!
  20. Dec 22, 2017 at 7:25 AM
    #620
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    With all the trucks pinging, has anyone had an engine failure? I have not seen one around here.....
