T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Jul 30, 2014 at 4:42 PM
    #61
    beeftastic
    beeftastic Well-Known Member
    Heath
    Alabama
    2014 SSM TRD off-road 4x4
    Csjumper leds on entire truck w/ switchback dtrls; fog light anytime mod; custom car grill mesh grill
    Yes I did
  2. Jul 30, 2014 at 7:30 PM
    #62
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    Had mind done yesterday. When running on 87 it idles much smoother and is much more drivable in the 1500-2000 RPM range. There was a noticable difference when running 87 to 91 before the reflash. Especially with the summer blends here in California.
  3. Jul 30, 2014 at 7:56 PM
    #63
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Perhaps a stupid question, but would you have this re-flash done if the truck fell into the 'years effected category' and it wasn't pinging to make sure it didn't start pinging in the future?
  4. Jul 30, 2014 at 9:18 PM
    #64
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Have you noticed any power loss? And please report back wit long term mpg.
  5. Jul 31, 2014 at 7:12 AM
    #65
    Del Scorcho
    Eagle, ID
    It runs fine. I have a Scan gauge and haven't seen any loss in milage. If anything it'll be better since I haven't had to put my foot in it as much while in OD at lower RPMs just for it to get out of its own way...
    I don't know why everyone's so scared to get the reflash. It's designed to make it run BETTER. There's a lot more to it than just retarding the timing. With modern ignition you can change the spark advance at the bottom without affecting top end. Spark advance just doesn't go off RPM or a fancy vacuum advance anymore... I'm sure they changed a combination of things in the reflash. A/F ratio, exhaust cam timing, ignition curve, shift timing just to name a few...
    I had a SVT Focus before and Ford came out with two different reflashes while I owned the car. Each one improved the driveability of the car and farther refined it.
  6. Jul 31, 2014 at 8:09 AM
    #66
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Thanks for info.
    Good feedback, thank you. I'm also in California, so I know what you mean about summer fuel. Off Topic: Guy on a bufffffalooooo...ok had to do that.
    Not a stupid question by any means. How many miles on your truck? I would ask the service manager at your dealership, and see what he says. According to someone else on this thread, this falls under a category that allows the TSB to be performed under warranty up to 86,000 miles. You have the option to wait/see what happens between now & that time.
    Thanks for the Scangauge feedback. Once I return from my Mt. Whitney excursion that is fast approaching, I'm bringing in my Trusty Tacoma for this T SB. Thanks for the mini-education regarding modern ignition & ECM calibration.
  7. Jul 31, 2014 at 8:40 AM
    #67
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I only have 3600miles on my truck. Good point; I've got another 82k miles to see whats up. Thank you.
  8. Jul 31, 2014 at 8:57 AM
    #68
    gonathan85
    Nate
    Central California
    You're welcome. If I remember correctly, my engine still ran without any pinging noice at 3,600 miles. I believe my issues started somewhere close to 15,000 to 20,000 miles?
  9. Jul 31, 2014 at 10:56 AM
    #69
    nd4spdbh
    SoCal
    really im scared about mileage.... the 4.0L is very tempromental when it comes to mpg... my current configuration i get decent mpg (19 or so mpg in 50/50 and 21-22 on the hwy) id just hate for it to be flashed and then bam crappy mpg cus they retarded timing and added more fuel.
  10. Jul 31, 2014 at 12:32 PM
    #70
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    good to hear.. hope they make the re flash for a 2010
  11. Jul 31, 2014 at 12:54 PM
    #71
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    Subbed, I have the dreaded ping.
  12. Jul 31, 2014 at 1:14 PM
    #72
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Does anyone have the ping in a manuel or is it isolated to automatics?
  13. Jul 31, 2014 at 1:14 PM
    #73
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Anybody heard or find info if they have a supported S/C flash to fix the ping?
  14. Jul 31, 2014 at 1:18 PM
    #74
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It happens with my 6 speed.
  15. Jul 31, 2014 at 1:47 PM
    #75
    gonathan85
    Nate
    Central California
    Who had the TSB performed, and still has pinging? There is 1x vote for "TSB Performed & still has pinging regardless of octane used."
    I don't remember seeing someone comment in this thread that they had TSB performed & still have pinging??? I've only seen positive comments post-TSB so far :confused: ???
  16. Jul 31, 2014 at 2:44 PM
    #76
    nd4spdbh
    SoCal
    also, @Del Scorcho you say it drives better. Are you saying it downshifts less in 5th lock up?
  17. Jul 31, 2014 at 3:25 PM
    #77
    Tcollins83
    Tcollins83 Well-Known Member
    Trevor
    Ocala,fl
    '13 TRD Off-road dbl cab
    Window tint, k&n filter, painted grill.
    I'm starting to hear a sound from my engine and it doesn't sound well. Almost like it's bogging or something, anyways I think it's the ping. So how do I go about getting the dealer to so this reflash thing? I'm at about 26k milage. Thanks I'm advance for the help.
  18. Jul 31, 2014 at 3:29 PM
    #78
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    How many miles??
  19. Jul 31, 2014 at 4:23 PM
    #79
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Has anyone gone in for the flash / pinging solution with an oil catch can installed? Did the dealer say anything about it, or give you any problems?
  20. Jul 31, 2014 at 5:35 PM
    #80
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I'm at 6,500. I picked mine up last year in July and didn't hear any pinging all last summer. Heck, I could lug it pretty good and it was surprisingly quiet. This summer it started only when it would get hot out - above 80/85 or so regardless of which gear I'm in with 87 octane. As long as I'm around 1500-2500ish rpm and pressing on the skinny pedal a bit, it'll ping. Worse with the AC on but that would be expected due to the compressor load on the engine. I have yet to try higher octane but if the TSB fixes this and doesn't hurt power or MPG, I'll have it done.
