T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Aug 7, 2014 at 8:11 PM
    #101
    Cano PR
    Cano PR Well-Known Member
    PR
    2014 black trd sport 2wd 4.0L v6
    Oem skid plate, oem running boards, oem roof rack, TRD cat back, TRD drop in filter, hid & leds, avs in-channel vent visor, 20% window tint, oem door sill, oem bed mat short bed.
    Had mine done yesterday was done in a hour the truck is completely silent more power more mpg it great thank you toyota for you guys with the ping call your dealer and make appointment you will be very happy like me
  2. Aug 7, 2014 at 8:17 PM
    #102
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    Anyone In canada get this done? The tsb says US in the region section why I ask
  3. Aug 7, 2014 at 8:22 PM
    #103
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    What does this "ping" sound like? Any sound clips?
  4. Aug 8, 2014 at 5:39 AM
    #104
    Brandon9281
    Brandon9281 Member
    Indiana
    2013 TRD Off Road double cab
    Softtopper, wet okole,
    Look on the last page for my post. That's what my truck sounded like and is what a lot of people have described it sounding like. You might want to turn your volume up.
  5. Aug 8, 2014 at 6:08 AM
    #105
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Cool beans. Thanks. I've got a similar sound, but hopefully it's the rollers on my winch fairlead. Glad there's a TSB for it if it's not the rollers
  6. Aug 9, 2014 at 11:12 AM
    #106
    beeftastic
    beeftastic Well-Known Member
    Heath
    Alabama
    2014 SSM TRD off-road 4x4
    Csjumper leds on entire truck w/ switchback dtrls; fog light anytime mod; custom car grill mesh grill
    So far so good since getting the tsb done on my truck. Seems to idle better as well. Worth getting done if you ask me
  7. Aug 10, 2014 at 5:44 AM
    #107
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Good news! Thanks for contributing to the thread.
  8. Aug 10, 2014 at 5:55 AM
    #108
    TacoRuthe
    TacoRuthe Well-Known Member
    Joshua
    Santee, CA
    2002 Acura RSX Type-S / 2006 4Runner 4WD V8 / 1999 4Runner V6 4x4
    Loading......
    Just got this done yesterday, did it as a preventative measure..... Haven't actually heard pinging since I always use 91. I will say the truck seems "different" and in a good way.
  9. Aug 10, 2014 at 11:18 PM
    #109
    gonathan85
    Nate
    Central California
    Hi - thanks for the feedback. Are you back to running 87 regular unleaded now?
  10. Aug 11, 2014 at 6:10 AM
    #110
    TacoRuthe
    Joshua
    Santee, CA
    Loading......
    I'm still on my tank of 91 octane; next fill-up I'm going to give 87 a shot and I will report back any issues.
  11. Aug 11, 2014 at 7:39 AM
    #111
    Foghorn Leghorn
    Foghorn Leghorn New Member
    San Francisco
    TRD Off road Doublecab
    Dynomax cat back, Bilstein 5100 front lift
    I meant to respond a couple weeks ago but I had the TSB performed about a month ago. It was pinging only when warmer out with the AC on now after the TSB it seems like it does it regardless of the temp. I'm not certain if the dealer even performed the re flash because part of the TSB is to put a new decal under the hood.
  12. Aug 11, 2014 at 11:19 AM
    #112
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Welp, secured the rollers on my fairlead, and truck still makes the rattle ping thing, so maybe I will get the TSB thing done
  13. Aug 11, 2014 at 12:10 PM
    #113
    gonathan85
    Nate
    Central California
    Sadly, this is a possibility.
    I decided to take advantage of the Toyota Care 25,000 mile free maintenance that my dealer included with the sale of the truck. Each time I brought my truck to the dealer, I asked the service writer to stamp my maintenance log, and mark with a pen which service items were performed.
    At each 5,000 mile service interval (up to 25k miles), the service writer marked the items "Re-torque Propeller Shaft Bolt," "Lubricate Propeller Shaft," and "Tighten Nuts and Bolts on Chassis and Body."
    When I inspected nuts/bolts on the chassis/body/propeller shaft (driveline unions) after each 5,000 mile service, NONE of them had been touched with a socket or wrench of any kind. I couldn't find a single mark on the factory black paint on any piece of hardware. When I crawled under the truck for the first time to check greasing of the u-joints, ALL of the grease zerk fittings still had the original factory black paint sealing covering the tiny ball in the center. No grease had ever been added to any u-joint since being greased at the factory pre-paint. [See Picture Below]
    SO, all this is to say, that it is very possible that they told you they performed a service, which was actually never performed.
    I'm a service/parts manager, and whenever I see blatant errors like this, it makes my skin crawl. :annoyed:
  14. Aug 11, 2014 at 12:10 PM
    #114
    gonathan85
    Nate
    Central California
    If you do, please check back in here and let us know how it goes.
    Thanks!
  15. Aug 11, 2014 at 1:15 PM
    #115
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    First off.... the free service at 5k intervals ONLY include tire rotation and oil / filter change... thats it... no other labor.
  16. Aug 11, 2014 at 1:19 PM
    #116
    BamaToy1997
    Bill
    Navarre, FL
    I would like to know what footnote #3 is, since all of those items have a little "3" footnote after them.
  17. Aug 11, 2014 at 1:22 PM
    #117
    gonathan85
    Nate
    Central California
    If that is the case, then the sales manager that finalized my purchase definitely over-exaggerated the complimentary up-to-25k maintenance. :rolleyes:
    As a service manager myself, I'd rather be told that up-front instead of someone marking my service schedule book inaccurately. I'm not trying to be nitpicky here...but I prefer accuracy/honesty when it comes to what was done & what wasn't done. :)
  18. Aug 11, 2014 at 1:24 PM
    #118
    gonathan85
    Nate
    Central California
    Footnote 3 - "Includes operating on roads which road salt has been applied."
    So, the way I read it...."Perform these service items only if you drive primarily on dirt roads with dusty conditions and where road salt has been used."
  19. Aug 11, 2014 at 1:30 PM
    #119
    BamaToy1997
    Bill
    Navarre, FL
    Right, so if he normally drives highways, then no need to do the ones with the "3" footnote.
  20. Aug 11, 2014 at 2:11 PM
    #120
    gonathan85
    Nate
    Central California
    Yes yes - I see where you're going with this. ;)
    As far as nut/bolt torque goes, they probably never needed to be touched. I would like to have seen them at least attempt to put a grease gun on each zerk fitting.
    Either way, I caught it myself & took care of both items :) .
    I was merely trying to show that it is possible for someone to say they performed a service to a piece of equipment, when actually no such service was performed.
