T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Aug 11, 2014 at 3:00 PM
    #121
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Exactly happens all the time. I hate the dealer for this reason.
  2. Aug 11, 2014 at 6:26 PM
    #122
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Happens with my 6spd
  3. Aug 11, 2014 at 8:49 PM
    #123
    AZDevilsFan
    AZDevilsFan New Member
    '13 Baja
    Well, it appears I was a little too eager to place my vote on the TSB fixing the ping. Unfortunately, my truck is now pinging on 87 octane. I just refueled with 91 to see if that helps and will try and find the time to contact my dealer and/or Toyota. In case anyone is still interested, my fuel mileage didn't appear to be impacted by the TSB and I do not see any stickers indicating a re-flash of the ECU was performed (maybe I'm looking in the wrong place).:(
  4. Aug 11, 2014 at 9:36 PM
    #124
    nd4spdbh
    SoCal
    My truck only has one sticker on the hood from the factory (never been in for a reflash) FYI
  5. Aug 12, 2014 at 6:05 AM
    #125
    BamaToy1997
    Bill
    Navarre, FL
    I do agree with you on how some things should be done anyway. For example I never looked at a vehicle's driving characteristics when I did maintenance at the dealerships. If I did an oil change, EVERY zerk fitting got grease. Period.
    And you know this because you have a video camera located in every dealership in the US and watch each of the millions of vehicles that get serviced every day? Come on, get serious.:rolleyes:
  6. Aug 12, 2014 at 6:17 AM
    #126
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Well shoot. Sorry to hear this. Let us know what Toyota or the dealer says.
  7. Aug 12, 2014 at 7:35 AM
    #127
    wh013mi1k
    wh013mi1k Well-Known Member
    2012 DCLB TRD SPT V6
    Had the TSB, pinging seems to have nearly disappeared (thought I hear the slightest bit on the way from the dealership to the office this morning) - but will know for sure on the way home tonight. Sounds promising so far; but wanted to add that I checked under my hood for the modification decal/sticker and did NOT see one either. Will double-check on the way home, but made me nervous.
  8. Aug 12, 2014 at 7:51 AM
    #128
    nd4spdbh
    SoCal
    From my experience at the dealership yes....
    Driveline Vibration TSB, i had to provide a proper angle finder to the head service tech who ordered the wrong one, then i proceeded to spend 45min under my truck on a lift at the dealership showing him how to properly do the TSB as he had no clue.... and during that time i was in the bay with the head service tech and oil change boy, i caught the oil change boy about to start my truck with no oil in it. You could say i trust the dealerships about as far as i can throw my truck. When i take my truck in for this tsb, there will be a gopro recording everything thats going on in the cab.
  9. Aug 12, 2014 at 9:20 AM
    #129
    gonathan85
    Nate
    Central California
    Thanks for the feedback - keep us updated if anything changes.
    Odd - not sure why they wouldn't label the vehicle after making an alteration. I suppose the tsb is somehow recorded on the service history of the vehicle.
  10. Aug 12, 2014 at 9:30 AM
    #130
    TacoRuthe
    TacoRuthe Well-Known Member
    Joshua
    Santee, CA
    2002 Acura RSX Type-S / 2006 4Runner 4WD V8 / 1999 4Runner V6 4x4
    Loading......
    They did not place a decal under my hood either.
  11. Aug 12, 2014 at 11:39 AM
    #131
    gonathan85
    Nate
    Central California
    Good to know. I'll ask about the decal or plate marker when I bring in my truck.
  12. Aug 12, 2014 at 11:43 AM
    #132
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Contacted the dealer I normally use, and decided not to take it to them. Had a VERY bad experience with a tech there last time I was there. Turns out he is the foreman.
    Contacted a different dealership in town, and I'm currently waiting to see if they can replicate the sound. Tried to get a recording of the sound on my way in, but couldn't get the truck to ping-knock-kablam
  13. Aug 12, 2014 at 2:29 PM
    #133
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    So far, I've gone about 30ish miles after they supposedly did the TSB thingy. Tried to get the clankyness to jump out at every opportunity. So far, I haven't got the ping to occur again. Truck seems to fire up, take off, accelerate, climb hills, and in general, run smoother. (Knock in wood). They also performed some little recall brake work (electronic crap). I put off filling the tank 'til after the tsb in order to possibly catch any mpg change. My last tank averaged 17.135 mpg which was mostly hwy below 70mph. Normal for me is 15.5-16ish. We shall see if anything changes.
    BTW, truck is 2012 DCSB 4x4 SR5 6spd. OME lift w/886 coils & dakar leaf packs. Plate bumper w/winch(steel cable). Bed rack w/ RTT. (5) 255/85r16 on 4 aluminum OR wheels, & 1 spare steely. Safari snorkel. Some other miscellaneous crap
  14. Aug 12, 2014 at 2:33 PM
    #134
    gonathan85
    Nate
    Central California
    Hey thanks for the feedback :thumbsup: !
    I hope this is the once & final fix for this issue.
  15. Aug 12, 2014 at 2:49 PM
    #135
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I sure hope so. I think I forgot to mention that they did NOT put a sticker/label/decal under the hood indicating a re-flash
  16. Aug 12, 2014 at 6:54 PM
    #136
    wh013mi1k
    Okay - update to my first day with the TSB. My OCD trained me to expect the pinging on very specific portions of my commute home (merging onto highway, getting up to traveling speed, the steep bank on my exit) - can confirm that no pinging occurred. I thought for a moment that I heard a SLIGHT pinging - but that could've been my brain playing tricks because I was expecting it to occur like normal.
    I read from a previous post that the TSB needs time to "take" or set roots (not mechanical enough to know if that's true or witchcraft) - but will reserve final judgement for tomorrow's drive to the office.
    I also have tracked MPG for every tank of gas I've ever put in the girl since I bought it new - so I'll know immediately if this improved MPG. Always been 87, but tracked the gas brand at each fill up as well. I should have a good apples-to-apples comparison upon the next fill up. Will update then.
  17. Aug 12, 2014 at 9:49 PM
    #137
    nd4spdbh
    SoCal
    awesome please do!!!
  18. Aug 13, 2014 at 6:11 AM
    #138
    gonathan85
    Nate
    Central California
    Hey regarding tracking each fuel-up...me too. Yes please let us know any changes/improvements :).
  19. Aug 13, 2014 at 7:16 AM
    #139
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I think I heard a very faint ruckus on my way to work this mornin'. I was going up a steep incline the normaly gets my truck chatterin' REAL loud
  20. Aug 13, 2014 at 7:19 AM
    #140
    BamaToy1997
    Bill
    Navarre, FL
    See, you made the point I was trying to make right there. I was specifically calling out your comment that indicated ALL dealerships were like that. Since now you are stating that you are basing your opinion only on YOUR experience I can accept that. It does suck that you had such a bad experience at a dealership, but I promise you that not ALL dealerships have bad techs, or unknowing techs. I was mainly just trying to call out that point. Going back and reading I can see how what I said could come out as being an ass. My apologies. I just don't like when people make it seem like just because THEY have a bad experience at a dealership means that ALL dealerships are stupid.
