T-SB-0044-14 Feedback: Engine ECM Reprogram [Pinging]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonathan85, Jul 24, 2014.
Did the TSB Eliminate Engine Pinging
Poll closed Aug 23, 2014.
  1. Yes, no pinging using regular unleaded fuel.
    14 vote(s)
    77.8%
  2. Yes, no pinging but using mid-grade or supreme fuel.
    0 vote(s)
    0.0%
  3. No, still having pinging regardless of fuel octane used.
    4 vote(s)
    22.2%
  1. Aug 21, 2014 at 11:22 AM
    #161
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    brought the TSB papers into the dealership today...see what happens...I'll keep u posted...
  2. Aug 21, 2014 at 2:18 PM
    #162
    AJO432
    AJO432 Well-Known Member
    Midwest
    '14 MGM DCSB 4x4 TRD OR
    My first tank after the TSB was exactly the same as it was prior. I will report back it that changes.
  3. Aug 21, 2014 at 2:40 PM
    #163
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    So they performed the TSB so far so good engine running smooth...I report back after I go for a rip on the hwy and up some good hills in the heat...
  4. Aug 21, 2014 at 3:12 PM
    #164
    Sledhauler
    Sledhauler Well-Known Member
    Derek
    MD
    13 DCSB TRD Sport 4X4
    Hot and humid today, the exact conditions that the problem is the most severe. Only once did it ping, 2nd to 3rd, low rpms, incline, seemed as thou it quickly corrected the problem. Before and after this the truck ran as it should, if not better. Maybe in all my head but it seems to run smoother now and not as bogged down when the a/c is on.
    Also I should mention, that I work out of my vehicle, 40-60 miles a day at this time. I do 20-25 stops a day if not more and only turn the truck off a few times a day. In other words, my info comes from being in my truck 4-5 days a week, 6 to 7 hrs a day.
    Since TSB I've driven 51 miles, worked just over 6hrs, stopped @ 23 places, and truck was turned off twice. Tomorrow will be a day similar if not less, then the truck is heading to OBX sat morning. I'll be sure to post if any pinging occurs.
  5. Aug 21, 2014 at 4:22 PM
    #165
    gonathan85
    gonathan85 [OP] Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Thanks for the continued feedback guys. :thumbsup:
  6. Aug 22, 2014 at 6:10 AM
    #166
    Brandon9281
    Brandon9281 Member
    Indiana
    2013 TRD Off Road double cab
    Softtopper, wet okole,
    After 4 weeks of driving since having the TSB done my truck is running a lot smoother. I have tried to make it knock/ping but can't. I've driven to Chicago and back with no issue and pulled a trailer with two polaris rangers that would normally cause it to sound like the engine was going to explode. I can definitely feel more power in every gear and the transmission seems to shift smoother then before. My gas mileage has gone up from 16-17 to 19-20. I've been running 87 octane with no problems. The temps here in Indy have been around the 90's with 80% humidity. If you are having trouble getting your truck to ping for the dealer play them the audio from my earlier post (I think it's on page 5) My buddy did this at the dealer as his would only ping/knock every once in a while and the tech did the flash right there.
  7. Aug 22, 2014 at 6:59 AM
    #167
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    Update: got my truck back late last night, just before the dealer closed. My service tech said he was on the phone off and on most of the day with Toyota and they ended up telling him that in the manual it states that some knocking, while accelerating or driving up hill, is normal, and that the manual also states using Top Tier fuel is recommended. Guess what type of fuel has been run in my truck since day one, Top Tier, and I have all my receipts to show that. My service tech then told Toyota that my complaint was mostly while towing not normal driving which lead to a long hold on the phone and now Toyota says they will get back to the service tech by Tuesday with an answer. My service tech and the service manager have refused to close my work order at this point as they both feel this is not normal for my engine to be operating this way. They have told me to sit tight and they will get this figured out, however they still feel that the plugs are too hot for the motor causing the pre-detonation, thats why when I use a higher octane fuel the problems mostly goes away. I guess I will have to wait a few more days while they try to figure this all out.
  8. Aug 22, 2014 at 7:20 AM
    #168
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    At the dealer getting this done right now. It hasn't been pinging much lately so I was worried they might not do the fix. The tech was super cool and said he heard a little knock and would do the fix.
    Ackerman Toyota in St Louis
  9. Aug 22, 2014 at 8:27 AM
    #169
    gonathan85
    Nate
    Central California
    Good suggestions & thank you for the feedback. I'm still trying to make it to the dealer for this TSB. Keep us updated =).
    It's always nice to have the dealer on your side. I'm glad to hear they are taking this seriously, and not shrugging off the issue as "normal." Good dealer by the sound of it. Please let us know what comes of this.
    Sounds like you're also working with a good dealer. Good news. Let us know how she behaves post TSB =).
  10. Aug 22, 2014 at 10:56 AM
    #170
    The109
    Fort Collins
    Update:
    Drove it around town after the TSB and then drove back into work. My engine is smoother and quieter than it's ever been. So that's only about 35 miles since the flash, I'll post again if I notice anything negative.
  11. Aug 22, 2014 at 11:21 AM
    #171
    gonathan85
    Nate
    Central California
    Well shoot that's good news =). Keep us updated!
  12. Aug 22, 2014 at 6:20 PM
    #172
    AJO432
    Midwest
    Some of you are having a hard time getting your dealer to perform the TSB? I went and said the engine in my brand new truck is knocking. Please perform TSB 0044-14. They said ok.
  13. Aug 23, 2014 at 8:09 AM
    #173
    SAXD Taco
    SAXD Taco Well-Known Member
    Justin
    Atlanta
    2013 DCLB, 4X4, MGM
    N-Fab Steps, BakFlip F1, TRD Accessory Skid Plate, Toyota Bed Mat, Husky Liner Floormats
    Well, I just got the tsb for my 2013 taco. We'll see how it goes & I'll update after I drive it for a bit.
  14. Aug 23, 2014 at 9:46 AM
    #174
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I'm hoping the same happens with me. I plan to ask them to do it when they do the free service in a few weeks.
  15. Aug 24, 2014 at 2:50 PM
    #175
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    does this TSB is valid in canada ?
  16. Aug 25, 2014 at 11:58 AM
    #176
    SAXD Taco
    Justin
    Atlanta
    2013 DCLB, 4X4, MGM
    I thought that I would post a little update. So far, I have about 75 miles on the TSB tune. The engine seems to run a bit smoother & not quite as loud as before. I am unsure of the MPG change as I only have driven 75 or so miles since the TSB was performed. Can't really comment on 87 octane as I had 93 octane in my tank before the tsb. Time will tell & I'll continue update as I put more miles on it, but it seems promising.
  17. Aug 26, 2014 at 2:26 PM
    #177
    gonathan85
    Nate
    Central California
    Thanks for the heads-up! Keep us updated =).
  18. Aug 26, 2014 at 4:37 PM
    #178
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I had it done yesterday at my 10k service, the motor is amazingly smooth.
  19. Aug 26, 2014 at 7:43 PM
    #179
    rusbob
    rusbob Active Member
    Pensacola, Fl
    2012 sr5 4x4
    Tank #2 of 87 octane, 600 miles since TSB. Mid-90 temps last week. NO pinging whatsoever, mileage unchanged 18.5-19.5 hand calculated.
  20. Aug 27, 2014 at 7:39 AM
    #180
    Turbo-Taco
    Randy
    Portland, Oregon
    So I finally heard back from my service tech and he told me due to the software update my trucks computer needed to re-learn my driving habits and that included towing. Once the TSB software update was done, as far as my truck knew, it had never towed anything or been drove. I thought that was a bunch of BS, however, since pulling my camper just over 100 miles it now runs much smoother. No pinging under normal driving nor towing. I am leaving Saturday, towing my camper about 3800 miles, so I guess I will find out whether or not it stays this way. I will update after my trip to let you all know.
