T-SB-0077-16 Rev 1
Discussion in '3rd Gen. Tacomas (2016-2023)' started by illogical, Oct 26, 2016.
  1. May 10, 2017 at 3:25 PM
    #2421
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    2016 TRD Sport access cab 4x4 auto
    Black tube steps,mud flaps, fluid filmed tonneau cover,jbl speakers heated leather seat covers,bed mat,husky floor liners
    Checked my trans fluid myself. There's a good write up how to do it,I don't trust the dealers. Mine took 3 oz.
  2. May 10, 2017 at 3:48 PM
    #2422
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Can you share this write up? Did you replace the bolt gaskets?
    20tacoma17 likes this.
  3. May 10, 2017 at 4:41 PM
    #2423
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    Look in the technical chat. I didn't change the plug gasket rings, no leaks.
  4. May 10, 2017 at 5:22 PM
    #2424
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    Try a different dealer!
  5. May 12, 2017 at 3:44 PM
    #2425
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I would contact Corporate and open a case. I did that and the dealer did a solid 180 and did everything that they should have done on my initial visit. Plus they provided a free rental.
    Tacoma2GR likes this.
  6. May 12, 2017 at 11:28 PM
    #2426
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Do you have the number to corporate?
  7. May 15, 2017 at 11:30 AM
    #2427
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Are the PDFs in the OP still valid? I'm heading into the dealer shortly for 15k service and wanted to bring a copy of this...
  8. May 15, 2017 at 2:18 PM
    #2428
    Kkcv05
    Kkcv05 New Member
    2016 Tacoma Limited 4x4
    My 2016 Tacoma does the same. Brought my truck with the trailer and SXS loaded and made them do a road test with me to show them. They still managed to say it was "normal" for the truck. What a joke.
  9. May 15, 2017 at 2:28 PM
    #2429
    oldschoolczar
    '16 DCSB TRD OR
    The TSB, both the original and the revision, should completely resolve this issue.
    Tcoma16 likes this.
  10. May 15, 2017 at 2:31 PM
    #2430
    illogical
    illogical [OP] Well-Known Member
    2017 TRD 4x4 OR MT
    Yes they are. Grab the non-scanned version if you're printing it out, much cleaner copy.
    If/when a rev2 becomes available, there's going to be a frenzy of posts about it. I doubt anyone would miss it. :)
    oldschoolczar[QUOTED] likes this.
  11. May 15, 2017 at 7:16 PM
    #2431
    treimche
    treimche Well-Known Member
    Fargo, ND
    Nope it doesn't. Even without towing, mine does this on the highway unless there is a tail wind.
  12. May 15, 2017 at 10:27 PM
    #2432
    illogical
    2017 TRD 4x4 OR MT
    @treimche did you ever try the reset in TechStream? Just curious if you had the same or different results from what I had found.
    There's always a chance that I was experiencing a placebo effect, no one else has chimed in. :confused:
    *unlikely though, 30 years of butt dyno backing up my claim. :thumbsup:
    taco 16 likes this.
  13. May 15, 2017 at 10:37 PM
    #2433
    oldschoolczar
    '16 DCSB TRD OR
    Hmm.. this resolved my problem 8,000 miles ago and it hasn't returned. Although mine didn't do it as bad as your post indicated. Mine would upshift eventually prior to the TSB if I was going downhill. I assume you've had fluid levels checked? That's a bummer man. Cruise has really helped me limit gear hunting in the mountains since it's been fixed. Cruise definitely holds gears longer - sometimes too long I guess
    Bob259 and SLO TRD like this.
  14. May 17, 2017 at 7:09 PM
    #2434
    treimche
    Fargo, ND
    I haven't had the time to mess with it yet, work has been super busy.
  15. May 17, 2017 at 7:11 PM
    #2435
    treimche
    Fargo, ND
    Fluid was checked with very few miles on the truck and was half quart low. REV-1 was installed before I ever took delivery. It's ALWAYS windy here, so the lack of low end power of this thing makes it constantly rev out to find power. Toyota should really retune 5th/6th gears.
    Sosk likes this.
  16. May 17, 2017 at 8:56 PM
    #2436
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Maybe even 4th too
  17. May 18, 2017 at 8:44 AM
    #2437
    gsingh
    gsingh Well-Known Member
    G
    2016 Toyota Tacoma TRD Sport
    no they did not.
  18. May 19, 2017 at 12:12 PM
    #2438
    Leon1tus
    Leon1tus Well-Known Member
    Leo
    Socal
    TRD Offroad 4x4
    What's up TW. I was feeling the transmission issue on my 17 OR. On long drives it would down shift and gets stuck for too long on slight incline or constantly shifting from 4th to 5th.
    Took it in to my local dealership with a print out. They said the 17 model already had the update. I didn't believe them so I insisted they check out my truck. The advisor mentioned supposedly they don't get paid for the job. Anyways they kept her over night to have the transmission cooled before fluid level inspection.
    Picked up the truck today. No updates were made on the programming but they found fluid levels were low by 0.5 quarts.
    Shifting from park to drive or reverse is now a lot smoother. City drive feel effortless too. The ultimate test would be another road trip. Will check back on results after.
  19. May 21, 2017 at 6:30 PM
    #2439
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Yep, me....3 quarts low manual check.
  20. May 21, 2017 at 8:16 PM
    #2440
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    Check the level yourself. I don't believe the techstream can check levels it can only tell you trans temp
