T56 Transmission Swap Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, May 22, 2014.
  1. May 22, 2014 at 7:59 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. May 29, 2014 at 3:10 PM
    Large
    Large Red
    Any updates?
  3. May 29, 2014 at 4:07 PM
    Torspd
    Tor
    The Great America!
    We'll see. I asked if there were.
  4. May 29, 2014 at 4:30 PM
    BoatRacer
    BoatRacer Well-Known Member
    Olalla WA
    '02 TRD 3.4 5-Speed
    All Pro front bumper, Warn winch, leds, Dakar leaf pack, locker wire mod.
    Awesome! I'd be very interested.
  5. Jun 8, 2014 at 8:38 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  6. Aug 7, 2014 at 3:44 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Subbed as my tranny starting to piss me off... Is this going to be compatible for 4wd trucks?
  7. Aug 7, 2014 at 5:01 AM
    Torspd
    Tor
    The Great America!
    Yes, as long as you speak with www.RSGear.com They have done the adapters to the T56 Magnum, and told me it was possible with the regular T56 as well. Just need to speak with them.
    The GMC Syclone "Syborg" is best known for that adaptation.
  8. Aug 7, 2014 at 5:07 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
  9. Apr 1, 2015 at 9:20 AM
    Torspd
    Tor
    The Great America!
  10. Apr 21, 2015 at 5:06 AM
    Ghost848
    Tony
    Alberta,Canada
    So poking at this, t56 wouldnt bolt onto the stock taco tcase so how would u figure you go with that?
  11. Apr 21, 2015 at 5:26 AM
    Torspd
    Tor
    The Great America!
    That one member krisxone did that write-up on it. I heard that there were a few others as well to do the same. Just need a steady hand. ;)
    Rockland Standard Gear makes a kit for the Magnum T-56, and told me that they make a kit for the regular T-56 as well, to bolt up an AWD transfer case. It's a driver side output shaft so would need a matching flange and likely have to modify the front drive shaft's length.
    Then you'd have an AWD setup. The specific Borg Warner transfer case is vacuum actuated. No vacuum, always in AWD.
  12. Apr 22, 2015 at 3:37 AM
    Ghost848
    Tony
    Alberta,Canada
    Hmm so no actual 4x4 just awd
    Like the fj cruiser is awd but goes 4x4 too
    Doing my own homework im wondering with the proper adaptor plate if the stock tcase would bolt right on? I dont know spline counts tho so i dunno
  13. Apr 26, 2015 at 2:42 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  14. Apr 26, 2015 at 8:52 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    There are other options for the 4wd crowd- http://www.lceperformance.com/Trans-Adapter-Kit-1GR-To-Chevy-Trans-p/1033040.htm
    Some go fast desert guys are running the TH400 auto with some success. It is a very bombproof trans when built right, and the short shaft version will mate to any number of transfer cases. I've been considering this for a while, but figure I'll run this motor until it's toast and do an LS swap.
    tacoma16 likes this.
  15. Apr 27, 2015 at 11:51 AM
    Torspd
    Tor
    The Great America!
    The member DoubllD purchased and used that setup. Got a separate controller for shifting gears. Had to do a little notching here and there, but it is all documented in his build thread on XRU.
    05Taco4x4 likes this.
  16. Jan 7, 2016 at 7:08 AM
    Ghost848
    Tony
    Alberta,Canada
    so bringing this alive again, i have pooched tranny #2 soooo im done, how are the ratios feel vs what stock was? (ra60 1st gear was 4.171, tranzilla 1st is 2.98 or somthing close)
  17. Jan 7, 2016 at 10:44 AM
    Torspd
    Tor
    The Great America!
    There are multiple selections from www.rsgear.com, for the gear ratios. As well as output shaft sizes. The highest 1st gear is the 2.98. Mine is lower, however I do not remember its ratio of the top of my head. If you have larger than stock tires, I'd recommend the 2.98 1st gear. Then use a gear calculator to determine if an eventual ring and pinion upgrade is wanted.
    I have a ~28" overall tire, with a 3.73 rear.
  18. Jan 7, 2016 at 11:00 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats going to CRIPPLE off road performance.... id personally like to have a first in a manual around 5-6:1 but thats just me.
  19. Jan 7, 2016 at 12:22 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Nah. Unless you are seriously rock crawling all of the time, low gears suck offroad. It's rare that I need to use 4lo, but LT helps smooth things out a bit too...
  20. Jan 7, 2016 at 12:55 PM
    Ghost848
    Tony
    Alberta,Canada
    talkd to george down there, and he agrs 2.98 sux for offroad 4x4. he did suggest a 5 spd that has 5.81 for first gear lmao!
