T56 Transmission Swap Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, May 22, 2014.
  1. Jan 7, 2016 at 4:05 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    You've gone through two transmissions in a 2009 truck??
  2. Jan 7, 2016 at 4:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    well yeah high speed stuff.
    I find myself using 4lo more times than im using 4 high... so much better for precise movement on tight trails.
  3. Jan 7, 2016 at 6:04 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Yup, first one 1,2 geat t would pop out of gear... This trannyreverse died and I don't know why, all I know is it was a bitch to put into gear since I have installed and this morning I backed out of my drive way and got to work and went to back in and grind is all I got
  4. May 13, 2024 at 5:37 PM
    Beats231
    Beats231 Member
    05 tacoma TRD
    Hey hope everyones doin well
    I know this is an older post, just trying to find out any info I can on doing the T56 swap. Already spoke with George at RSG about sourcing a trans and transfer case for my 4x4 taco. I also spoke to Gadget about getting the remaining parts for the swap kit, he just discontinued it for now so I may not be able to get all the necessary parts. Anyhow I am just curious if anyone has done a T56 swap recently on a 4x4, and if so, is there a shop in the country who specializes in these swaps and making any adapter hardware?
    I am not a mechanic but love to wrench in my spare time and am also totally new to learning about transmissions let alone a swap like this. All the posts and experiences from everyone up here have never led me wrong, and this is where I first learned about doing this swap
    So thanks for any time and info! It is appreciated
  5. May 14, 2024 at 10:27 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The hardest part to get, is the bell housing. Everything else can be sourced pretty easily.
  6. May 18, 2024 at 3:30 AM
    Beats231
    Beats231 Member
    05 tacoma TRD
    Ok I think Gadget said he still has one of those. Mayb Ill just start collecting parts for now
    Thank you.
    inwood customs likes this.
  7. May 18, 2024 at 5:06 AM
    Torspd
    Tor
    The Great America!
    If you can get the bell housing, then you'd be pretty golden. The next hardest thing would be having a crossmember welded up. Which isn't too hard for a fabricator.
    Beats231 and inwood customs like this.
  8. Jun 13, 2024 at 6:26 PM
    Beats231
    Beats231 Member
    05 tacoma TRD
    Was able to get a bell housing and some other parts from Gadget
    Now saving for the trans and tc from RSG
    Thanks!
    Torspd[OP] likes this.
  9. Jun 14, 2024 at 3:26 AM
    Torspd
    Tor
    The Great America!
    Keep us posted on how this turns out. This will be exciting with the AWD setup.
  10. Sep 8, 2025 at 12:11 PM
    Beats231
    Beats231 Member
    05 tacoma TRD
    Hey guys hope everyone is well! So I am trying to source the electronics Gadget used to sell in his T56 swap kit. Anyone got any leads? Thanks so much!
  11. Sep 9, 2025 at 8:11 AM
    Torspd
    Tor
    The Great America!
    I believe the main thing that you are missing, electronics wise, is the Dakota Digital box. This is to translate the T56 speed into the signal the the Speedometer uses.
    The other electronic piece, which may be in the first link that I provided, would be the reverse lockout switch.
    Otherwise, post up some photos. I'd like to see your AWD setup!!!
  12. Sep 10, 2025 at 6:51 AM
    Beats231
    Beats231 Member
    05 tacoma TRD
    Thank you brother I appreciate you!
    I have a mechanic buddy who can prob help me with the other parts and fabricating a cross member.
    still gota get my 4.56 trutrac front dif from ECGS before I can run awd but I did a trutrac on the rear so barely need 4wd
    Ill get some pics soon!
    Enjoy the day!
