Table saw or miter saw?
Discussion in 'Garage / Workshop' started by 12DblCab, Nov 27, 2013.
  1. Nov 27, 2013 at 1:21 PM
    12DblCab
    12DblCab [OP] I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    I'm slowly acquiring tools as I need them, and I'm trying to decide on whether to get a miter saw or a table saw for Christmas for general DIY household stuff. I'd like to build an arbor with a swing in the next few months, and I'm going to rebuild a wooden bench that has some iron pieces that will require cutting some boards. I currently have a circular saw, and I'm going to buy a jigsaw pretty soon for curved cuts. I don't know whether to get a table saw or a miter saw because my circular saw can cut large pieces of plywood a table saw would cut, but it's also pretty similar in design to a miter saw. What do you guys think? For the arbor I'll probably cut some 4x4" fence posts. Can that be done on both saws? I may also do some angled cuts.
  2. Nov 27, 2013 at 1:25 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    For 4x4s the miter saw is the way to go, and it makes a lot of cuts real easy.
    As you know you can do a lot with a circular saw and a straight edge just as nicely as a table saw. You don't want to cut 4x4s with a table saw.
  3. Nov 27, 2013 at 1:30 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Thousand Oaks, CA
    '13 DCLB TRDSport PreRunner & '99 4Runner 4x4
    Tailgate Anti-theft Anytime Foglights Removed/Relocated Badges BHLM Window tint Goodyear Duratracs Satoshi Grill from Customcargrills.com
    I would go for the miter saw. and if I can give a bit of advice, get a sliding compound with double bevel...nothing worse than trying to cut crown angles and have to sit there and think about it forever deciding which way to cut the wood because your saw only bevels to one side. and having a sliding arm makes it so you can cut wider planks than you could without.
  4. Nov 27, 2013 at 1:31 PM
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    Hello,
    If the goal is long term, a good table saw is the foundation of any wood shop. I think you can get away with the miter and circular saw building arbors and wood bench but for bigger projects and precise cuts, nothing beats a table saw.
    Although I have both, a table saw is a much bigger commitment than the miter saw. Personally, I use a Delta cabinet saw, a Makita miter saw, and Festool circular saw. Godspeed.
  5. Nov 27, 2013 at 1:40 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Tough call on which to get first, but I would go with the Miter Saw.
  6. Nov 27, 2013 at 1:47 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    get BOTH!! treat yourself.
    Do not get a CHEAP one--you will be dissappointed.
    Sliding miter saw rather than just a chop-cut.
    Heavy base table saw are much BETTER.
    Most of the time you can find a good used one(table saw).
    Check craigslist or local newspaper.
    Miter saws are easier to store-if space is a factor.
  7. Nov 27, 2013 at 1:47 PM
    Ham N Egger
    Ham N Egger Well-Known Member
    33.414842, -111.909319 or 36.107324, -115.175744
    09 PreRunner V-6
    For the project you mentioned, miter saw rather than table, but as another poster mentioned the table saw is a good starting point for anyone assembly tools for future use.
    Baseboards, mouldings and angle cuts can be cut on both. I find my table saw to be easier to use for precise cuts. If you are just starting out, and from your post it sounds like you are, I tend to agree with the table saw purchase.
  8. Nov 27, 2013 at 1:53 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Both
  9. Nov 27, 2013 at 1:55 PM
    TheDrMaSuess
    TheDrMaSuess Member
    Loren
    South Jordan
    Tacoma
    6" Tough Country Lift, AFE Cold air intake, Custom Exhaust, Nascar Tip, Custom Bumper Fab'd by me, Frame chop in front wheel wells and more
    I'd probably go with a miter saw. They will do most of the cuts you need unless you are going to be ripping wood or have long sheets/boards to cut.
  10. Nov 27, 2013 at 4:29 PM
    SH7mi
    SH7mi Live long and prosper.
    Kevin
    West Grove, Pa.
    08 DCLB 4x4 black
    Get both if you can afford it, if not start with the compound slide mitre saw. There is always a way to rip a long straight board without the table saw until you can afford one.
  11. Nov 27, 2013 at 4:32 PM
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - 3" OME Lift, UCWMS
    UCWMS; OME 3" lift/OME 885 springs; OME 90000/60091 shocks; Diff drop Spacers; Light Racing UCAs
    Concur.
    Good luck with the decision.
  12. Nov 28, 2013 at 7:03 PM
    1mrwatermaker
    1mrwatermaker Well-Known Member
    Kentucky
    2006 TRD 4X4
    XD Chrome Revolvers 18x9, 285/60R18 Cooper Zeon LTZ tires,chrome bull bar,chrome nerfbars, foglight mod, led interior lights,5% tent all around, factory HU, AUX mod kicker6x9 front, kicker 6.5 rear, power acoustik tweets F&B, eclipse EQ, kicker 4 ch amp, 600D directed amp, 2 8" Kicker DVC Comp subs, ultraguage, LED cupholder lights, LED bed lights
    I do alot of wood working, cabinets, shelving and things like that..i do not own a table saw just a miter saw and a circular saw with a good straight edge (8 ft aluminum stock) and good irwin clamps....
    IMO....i wld go with the miter saw.
    most all table saws can only rip about 2 ft unless it is stationary with a large table attached to the side... whereas 2 sawhorses , a straight edge and a circular saw u can rip any size u want.... thats just my opinion and me thinking outloud...
  13. Nov 29, 2013 at 11:51 AM
    12DblCab
    South
    Update: I went with the Kobalt 10" sliding compound miter saw. It looks like the only consistent complaint online is that the laser isn't very accurate. I think it will do everything I need it to, and it was under $200 with a coupon. :D
  14. Nov 29, 2013 at 12:55 PM
    worthywads
    Nice, that think should be able to do a lot.
    A better blade might be a future purchase, the stock blades usually aren't top quality.
  15. Dec 16, 2013 at 2:57 PM
    TACO RKN
    TACO RKN Well-Known Member
    South OC, CA
    10 Taco in progress
    oh it begins again!
    X2...I have a Forrest blade on my mitre saw and it is amazing....
    Keep that table saw on your list...and get one like previously mentioned. I have used my Delta cabinet saw for 15 years and it is still like new.
  16. Dec 16, 2013 at 2:59 PM
    OZ-T
    Peter North
    British Columbia
    Are the Forrest blades better than Freud's Premier line ?
  17. Dec 16, 2013 at 3:00 PM
    Shauncho
    Shaun
    Thousand Oaks, CA
    from my experience, unless you're spending top dollar on a miter saw, none of the lasers are accurate. nothing is more precise than an experienced eye.
  18. Dec 18, 2013 at 5:03 PM
    TACO RKN
    South OC, CA
    10 Taco in progress
    oh it begins again!
    Don't know... I haven't tied that line...
  19. Dec 18, 2013 at 5:04 PM
    OZ-T
    Peter North
    British Columbia
    What do you consider to be " top dollar " ?
  20. Dec 18, 2013 at 5:04 PM
    OZ-T
    Peter North
    British Columbia
    OK. , thanks
