Tac holster vs. Hip holster
Discussion in 'Law Enforcement Officers' started by ProForce, Aug 13, 2012.
  1. Aug 13, 2012 at 12:59 AM
    ProForce
    ProForce [OP] Thin Blue Line
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    So I am looking for opinions of thigh rigs vs regular hip holsters. I currently use a Serpa level 3 on my duty belt with the lower drop adapter:
    I also have a safariland tactical thigh holster that I don't use simply because I like the hood release better on the Blackhawk, and also I have heard negative things about using tac holsters for duty use. I love how it takes some of the weight off your belt and its also easier to draw since it's closer to my hands natural resting position.
    My question is can anyone give me some pros/cons of each type (hip v thigh) and tell me what you choose to use and why? A lot of guys I work with are all switching to tac holsters and say they love em... suggestions?
    Thanks! :)
  2. Aug 13, 2012 at 1:50 AM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    Tac holsters are just that... For Tac operators. They are designed to be able to wear a heavy vest and not have it interfere with your draw. That's really the only plus for a Tac holster. They are not comfortable to run in and move all over while running, make it harder to draw from a seated position, the constant rubbing and moving destroys uniform pants and without getting into too much detail... Retention. Lots of k-9 officers wear tac holsters because wearing a leash around the waist can interfere with a draw from the hip. But that can be solved with a hood system similar to ones safariland makes. They also potentially will have to put on a heavy vest if they work with swat. I would stick with your current set up.
    Oh and as far as the "neutral position" of your hands for a draw with the thigh holster... Your hands shouldn't be down at your side when you are dealing with anyone in the first place. If you think about it, your hands are actually much closer to your hips when you are interacting with people... At least thats where they should be ;-)
  3. Aug 13, 2012 at 7:09 AM
    ProForce
    Anthony
    SoCal-Ontario
    This makes total sense, I just personally found it more comfortable... even to run in... maybe I'm doing something wrong :confused: I do not operate in "tactical" environments by any means, and I realize that they're not named tactical holsters for nothing.
    Another guy just showed me his pants yesterday, he wears his Taser on a tac holster and that is super light compared to a firearm and the inside of his pants were destroyed. And that was a nice pair of 5.11 tac pants too, so I know they really take a toll on your uniform.
    As far as drawing from a seated position... I can't currently draw from inside my vehicle as it is. Only when I gear down and wear my level 1 blackhawk paddle holster (which is adjusted to angle the gun forward) can I even attempt to draw from inside the car. Especially with the seat belt on! Maybe its because I used my truck to patrol, not a CV. Not sure how big of a difference it makes. To me, I think a thigh rig makes it way easier to draw from a seated position. Maybe its just me :eek:
    I agree and am not arguing your points you made, just trying to bounce ideas around and see if I'm missing something. I know there are many cons to a tac holster for regular patrol duty, but are there any pros? I thought the drawing while seated was a + but I guess its different for you.
  4. Aug 13, 2012 at 10:47 AM
    TacoMal
    California
    Don't think you are arguing at all! There are pros and cons for every type of gear out there. It just comes down to personal preference and what your department allows. You have to decide what pros you like best and what cons you are going to live with. I have never worn a Tac holster on patrol but I have worn it in a patrol car to and from swat trainings etc. I've messed around with trying to draw seated with the Tac holster and found its not as fast as my hip rig. Your set up may be different so that will be a deciding factor for you. You can always just try it out for a while and see if you like it. If not, you can always switch back.
  5. Aug 13, 2012 at 2:57 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Floriduh
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    This is what i rock with the tlr-1 light. I like it a lot, plus this is what my dept. uses have no choice, But I like it. It's a Safariland ALS Level 3 with light holster. I know a lot of K9 guys out there wear the drop holster but I don't like crap on my leg while running. Looks cool, functions like sheot IMO.
  6. Aug 13, 2012 at 3:10 PM
    TacoMal
    California
    What my dept uses and IMO the best holster out there!
  7. Aug 13, 2012 at 3:27 PM
    ProForce
    Anthony
    SoCal-Ontario
    This is the safariland holster I have except without the light area. I like the holster, can't stand the hood release though. Probably just takes practice and some getting used too, but the blackhawk is way easier to draw from IMO. That's why I am debating switching. The safari land I can wear on my belt or on thigh rig. Just seeing what holsters you guys like and hip vs thigh preference and why. Thanks for your input everyone
  8. Aug 13, 2012 at 3:33 PM
    Tim 2011 DC
    Tim 2011 DC Member
    Virginia
    2011 Double Cab 4X4
    Do a quick google search about the Serpa holster and how it has failed to release the pistol as well as leading to negligent discharges. After you read a little, go ahead and get the Safariland that mounts to your belt rather than on a drop leg platform.
    Edit to add: Try getting in and out of the car with the two different holsters. Try drawing from a seated position. Try running, which is more stable? Try drawing from any position other than standing on the range. I think you'll see the belt mounted does a better job all around. If you like it mounted lower like your current holster Safariland makes them that way too.
  9. Aug 13, 2012 at 6:33 PM
    ProForce
    Anthony
    SoCal-Ontario
    I will definitely check that out! Just to clarify also, this is the current Safariland holster I have, it is model 6070 Raptor Level 4 retention with mid-ride attachment. This is the holster I was considering purchasing the tac platform for. But I think I need to practice drawing before I change anything. As it is, I can hardly get my gun out of this thing with 2 hand holding it in front of me :eek:
    Thanks for all the input again everyone. I know its as simple as try it, use it, test it, practice with it, etc etc and decide for myself. I was just looking for some other reviews as well and this has certainly helped so far!
  10. Aug 13, 2012 at 6:48 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    I have the 6270. Level 4 with the sls hood guard.
    Only differance is I don't have the middle finger release, I just rock the gun back a bit and then draw.
    Its new to me but it seems to be a solid holster. Just takes practice.
  11. Aug 13, 2012 at 8:18 PM
    ProForce
    Anthony
    SoCal-Ontario
    Yeah its the middle finger thing that I can't stand. If it were a trigger finger release like the serpa then I would love it. But the middle finger thing doesn't seem natural to me :confused:
  12. Aug 13, 2012 at 9:05 PM
    IGO4LOW
    Zach
    Fullerton, CA
    I guess that feature has been replaced with the rock back to release because of that reason. I'm still getting the hang of mine. seems solid tho. I have the mid ride loop system and it works well while sitting in the truck. Wish I could be more helpful with the original question but I've never used a thigh rig.
  13. Aug 13, 2012 at 9:55 PM
    ProForce
    Anthony
    SoCal-Ontario
    But mine also has the rock back as well. Its the hood, the middle finger release, then push down and back and draw. Plus the regular retention. So the finger thing is just annoying to me. But its super super legit and I imagine very difficult for someone to draw off of me
  14. Aug 13, 2012 at 10:04 PM
    IGO4LOW
    Zach
    Fullerton, CA
    Hmm Idk then. Mine has the sentry lock/hood guard, sls rotating hood, then the rock back and draw.
    I've had some friends/family try to get my gun (unloaded/safety checked) from the holster while its on me. Even knowing the retention devices they can't do it fast enough for me to not stop them.
  15. Aug 14, 2012 at 6:18 PM
    k9cop
    Farva
    Floriduh
    I took the stupid hood thingy off..Takes some practice from the ss3 holsters that we had when I first came on. But once you get used to it it's like anything else...
  16. Aug 15, 2012 at 7:24 PM
    Robo02cop
    Robo02cop Well-Known Member
    Island of Nunya
    2012 MGM DCSB SPORT
    TRD Intake, Avic D3 DVD Player, Toyota Bed Extender, & Tinted Windows.
    I did the same thing!!! It kept poking me and I kept catching the seat belt on it when I tried to jump outta the cruiser quick!!! Plus when crawling on the ground it became a shovel for the sand!!
