TAC0MAN04 Takes On The World!
Discussion in 'New Members' started by TAC0MAN04, Dec 11, 2018.
  1. Dec 11, 2018 at 5:08 PM
    TAC0MAN04
    TAC0MAN04 [OP] Member
    2004 Grey Tacoma TRD
    Hey yall,
    My name is Chris and back in May of this year, I bought myself a 2004 Toyota Tacoma Trd extra-cab(5 speed). I hope to transform my taco into a beast. I purchased the truck with 194,000 miles on it with its original clutch (Frame replaced at 105,000 miles by Toyota due too recall). Just last week I replaced the Clutch at 204,000 miles hoping that my clutch problem will be solved for the duration of my trucks life. I was also driving around for a couple of months with my check engine light on, due too an admission system problem from a crack in my exhaust pipe. After being a lazy bum I finally got around to fixing the exhaust by welding a 2 1/2 Flex id pipe onto the exhaust between the 2 Cadillac converters. This is a temporary fix until I find the funds to get myself a nice exhaust system to fix my problems for the long term. I also put on new tires (Wrangler All-Terrain Adventure With Kevlar- Size: 265/70R16) with my stock rims(Garbage Rims).
    My next move is to fix my 4wd system, the system won't even initiate at the moment and the 4wd light won't even turn on when you put it in 4wd L4 or H4. After fixing the 4wd problem I will look into replacing my shocks and springs, once I accomplish that I will try and put a 2.5 inch Rough Country suspension lift on the truck. After putting the lift on I will look into getting bigger tires probably 32s or 33s and some nice black trd rims. I definitely have a lot of work ahead of me.
    TAC0MAN04
  2. Dec 11, 2018 at 5:10 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  3. Dec 11, 2018 at 5:11 PM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
  4. Dec 11, 2018 at 5:14 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
  5. Dec 11, 2018 at 5:17 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Welcome Cadillac convertor!:hattip:
  6. Dec 11, 2018 at 5:52 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  7. Dec 11, 2018 at 5:55 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Welcome to TW man lets see some pics!
  8. Dec 11, 2018 at 6:08 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
  9. Dec 11, 2018 at 6:10 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  10. Dec 12, 2018 at 5:43 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  11. Dec 12, 2018 at 5:44 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  12. Dec 12, 2018 at 5:45 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Welcome!!! Let’s see some pictures!!!
    MJ-12, TAC0MAN04[OP] and irayfz6 like this.
  13. Dec 12, 2018 at 7:43 PM
    TAC0MAN04
    Update: My Father and I removed the transfer shift actuator on the rear of the transfer case, it was seized with rust, cleaned it up the best I could and put it back on. Now when I press the 4wd button I hear the whirl of the system kicking in under my seat. Yet I still have no four wheel drive light on my dash. The only time I get a light on my dash is when I pull the plug off my rear actuator then the 4wd light flashes. I have my truck up on jacks and I'm in the process of removing my front add actuator. When I pull the plug on the add actuator on the front of the truck my 4wd light does not even show up on the dash. I was unable to get the front drive shaft to engage and lock up, so I figure that is my problem. One thing I do know is that my rear diff works, I hit the differential button, Then i hear it locking. When the trucks up on jacks I spin the rear tires and they both turn. Any advice yall can give me would be much appreciated.
    I'll post pictures once I get the 4wd fixed.
    TAC0MAN04
    MJ-12 likes this.
