Taca won't start!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flesheatingvirus, May 26, 2023.
  1. May 26, 2023 at 2:20 PM
    flesheatingvirus
    flesheatingvirus [OP] Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    I've never had any issues with this truck. It does have the Smart Key/push button start.
    The start button light won't turn green when the brake is depressed. It turns on Accessory and Ignition. I cannot shift gears with the Ignition on. It is in Park.
    1. Remote battery- getting 3.2 volts. Swapped it out with another just in case; nothing.
    2. Steering wheel lock- does not appear to be the issue. With the ignition on, I wiggle the wheel. No change.
    3. Smart Key Deactivation- As far as I can tell, I don't have this switch.
    I even tried a spare remote. Both remotes lock/unlock the truck just fine and have good batteries. Neither will allow the Start button green light to come on when the brake is depressed.
    On another note, I noticed that the brake lights do NOT come on when the brake pedal is depressed. Perhaps a switch connected to the brake pedal?
  2. May 26, 2023 at 2:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i would check the fuses...then check your brake switch
    Phlogiston, Stevie17 and Murd3rd like this.
  3. May 26, 2023 at 2:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Most all push to start require the brake to be pressed to start. You need to address the lack of brake lights. Once you figure that out, I bet the truck starts.
  4. May 26, 2023 at 2:39 PM
    flesheatingvirus
    ABQ, NM
    Tech Package
    I checked all fuses that appeared to be relevant under the hood and dash.
    Nothing.
    Another note, this did happen after I removed my driver side brake light LED because it wasn’t functioning. I determined it was a bad LED, reinstalled it to replace later, then this happened.
    Stevie17, HondaGM and TnShooter like this.
  5. May 26, 2023 at 2:44 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sounds like a fuse or that LED is causing issues. Put in a stock bulb and see if it works? If it still doesnt, its probs a fuse...I would imagine.
    Stevie17 and Chew like this.
  6. May 26, 2023 at 2:45 PM
    TnShooter
    Deogee
    STOCK
    I’d have to pull up the wiring diagrams.
    But you are going to need power to and from the brake switch. I always use a test light when possible to check fuses. Check both sides of the fuse for power.
    We need to figure out why the brake lights aren’t working.
    Stevie17 and HondaGM like this.
  7. May 26, 2023 at 2:49 PM
    flesheatingvirus
    ABQ, NM
    Tech Package
    With all the fuse replies, I checked again. This time, I went through ALL of them.
    One labeled STOP was burned out. That did the trick.
    who labels this shit??
  8. May 26, 2023 at 2:53 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Glad you got it!
  9. May 26, 2023 at 2:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Smart people who know they have to be able to communicate with
    Non English speakers
    Old people
    Dumbasses
    People with no education
    People with too much education
    Normal people
    Men
    Women
    Children
    Mad people
    Sad people
    Divorced people
    Ugly people
    Beautiful people
    Excited people
    Drunks
    High people
    Mechanics
    Know it all's
    Shy people
    Extroverts
    Quiet people
    Legally blind people
    Finally, people who can't find their ass with both hands.
    Kolohe07, RustyGreen, HondaGM and 6 others like this.
  10. May 26, 2023 at 3:51 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    ive seen alot of problems with led tail lights
    and on my 2022 you can hold the start button for 20 or 30 seconds without using brake pedal and it will start
    HondaGM likes this.
  11. May 26, 2023 at 6:12 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Nearly weekly.
    I will credit the OP for including this important piece of information though. Many leave this out and have folks guessing.
  12. May 26, 2023 at 7:52 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    How difficult is it to build a car/truck that will still crank even if a light bulb is out.
    JimminyCricket has it come to this?
  13. May 26, 2023 at 8:14 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I’d guess (more like bet) it would still start with a bulb out. Now, if you go adding electrical doodads? All bets are off, but let’s not pretend that’s as of recent.
    HondaGM likes this.
  14. May 26, 2023 at 10:55 PM
    RIX TUX
    brakes systems used to be simple when they were mechanical (hydraulic) but now they are also part electrical and electronics, and could effect the starting
  15. May 26, 2023 at 11:18 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Taca Friday!
    Chew likes this.
