tach not working anyone that can help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by allrsdup, Dec 3, 2010.
  1. Dec 3, 2010 at 6:22 PM
    allrsdup
    allrsdup [OP] Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    in the morning when it is first started the tach wont move at all. after a minute it starts jumping around then its fine the rest of the day. only when its really cold out. anyone know how i can troubleshoot this?
  2. Dec 4, 2010 at 6:38 AM
    allrsdup
    Sahuarita AZ.
    bump..anyone?
  3. Dec 4, 2010 at 3:46 PM
    spamy
    spamy Truck guy
    NorCal
    07 4X4 Tacoma Sport SR5 Access Cab
    Have you taken the cluster out at any time? If so I would check that the connections on the back are ok.
    Im not familiar with the tach setup, but I would imagine that its tied into the computer and shift points, so if the sensor had issues you would get a check engine light. So that just leaves the connections between the computer and the tach and the possibility of the tach itself being bad. Its just a would wire, basically an ammeter, not much to it and not prone to failure because of its simplicity. So my bet would be on connections.
    Other than that, then see the dealer.
  4. Dec 4, 2010 at 9:28 PM
    allrsdup
    Sahuarita AZ.
    no i have never taken it out. just seems wierd that its only when it is really cold out it happens ya know then i go down the block and bam it comes alive. strange
  5. Dec 4, 2010 at 9:37 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Since the tach gauge is electronic and your symptoms occur only in cold conditions my hypothesis is that it involves the electrical contacts. Cold temps are causing retraction in the metal and a "flex" is in the gauges near the contacts that causes the gauges not to work, or to work intermittently when it is cold. I say take out the gauge cluster and see if there is anyway to minimize the flex (possibly tighten screws or add solder to contacts). If that does not fix the problem I'd get an aftermarket gauge - because if it is not the contacts that are causing it then it's a something internally inside the gauge.
  6. Dec 4, 2010 at 9:37 PM
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    try a cup of coffee that always work to get me moving......:D
