Tachometer doesn't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tovar28, Nov 27, 2014.
  1. Nov 27, 2014 at 10:28 PM
    Tovar28
    Tovar28 [OP] Well-Known Member
    David
    Chino,California
    05 prerunner TRD sport
    bilstien 5100s in front @ 1.75 bilstien 5160 in rear,general HD 4 leaf pack, 20% tint in front 5% rear, 40 inch led bar ,Kc daylighters , Aries bully bar , aries side steps ,black housing headlights ,factory roof racks ,snugtop camper shell, plastidip rims, bfg ko2 tires
    My tachometer on my 2005 tacoma is not reading anything but every other one works ? Any ideas :( I need help!
  2. Nov 28, 2014 at 3:24 AM
    devkurf
    devkurf Member at Large
    midwest
    I would start by checking fuses. On the old 80's toyota's the tach and the speedometer were on seperate fuses. I know a lot has changed since then, but its a good place to start.
  3. Nov 28, 2014 at 6:51 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Doesn't move at all or points in the wrong direction? My mustang's tach pointed wherever it damn well pleased. Fix was a cheap stepper motor purchased on eBay.
  4. Nov 28, 2014 at 7:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    (4) RPM signal circuit
    The camshaft position is detected by the VVT sensor LH and RH, and is input into TERMINALS VV1+ and VV2+ of the engine control module as a control signal. Also, the engine RPM is detected by the crankshaft position sensor and the signal is input into TERMINAL NE+ of the engine control module.
    The ECU sends the RPM Signal to the Combination meter via the Black wire with a white stripe.
  5. Nov 28, 2014 at 1:05 PM
    Tovar28
    David
    Chino,California
    Would you know where to find said fuse?
  6. Nov 28, 2014 at 1:06 PM
    Tovar28
    David
    Chino,California
    It doesn't move at all I just stays at 0
  7. Nov 28, 2014 at 1:30 PM
    Tovar28
    David
    Chino,California
    I also installed my 40 inch led bar and grounded it near where the negative terminal from the battery grounds out. Would this affect anything?
  8. Nov 29, 2014 at 7:44 AM
    devkurf
    midwest
  9. Nov 29, 2014 at 7:48 AM
    Tovar28
    David
    Chino,California
    Thanks for the thread!! I'm going to try the scan tool nd thanks jimmy!!
  10. Nov 29, 2014 at 1:15 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There is no fuse for just the Tachometer.
  11. Nov 29, 2014 at 1:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No effect. A ground is a ground.
  12. Nov 29, 2014 at 1:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Shit I forgot about posting that... Good find.
    OP let us know what you find.
  13. Nov 29, 2014 at 6:17 PM
    Tovar28
    David
    Chino,California
    I will but it works sometimes and there is a strange buzz when I turn on
  14. Nov 29, 2014 at 6:24 PM
    Tovar28
    David
    Chino,California
    It all started when i tried wiring it
  15. Nov 30, 2014 at 5:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    A good rule to follow in these cases.
    It was working fine.
    I did X, Y or Z and now it doesn't work anymore.
    Undo what ever it was you did, all of it.
    99% of the time that will fix the issue. The other 1% is other causes or it was damaged.
  16. Nov 30, 2014 at 6:37 PM
    Tovar28
    David
    Chino,California
    Took it off now it just works when it wants
  17. Dec 1, 2014 at 1:15 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you try a scan tool?
  18. Dec 1, 2014 at 5:41 PM
    Tovar28
    David
    Chino,California
    My brother is going to try it he goes to UTI see if he tries it
  19. Mar 21, 2019 at 10:14 PM
    TerrorTaco808
    TerrorTaco808 KANAKA MAOLI
    Philip
    Hilo, Hawaii
    08' SSM DCSB SR5 4x4
    6" Fabtech suspention lift (Basic system),B110 5100 Billy's in the rear, 3" Body lift, 17x8.5 Fuel Trophy's wraped with 35x12.50 Kumho Road Ventures(KL71), custom BHLM retrofit heads with 6k morimoto D2S bulbs, Morimoto HID ballasts with ignighter, Opt7 3k LED Fogs, anytime fog light mod, Semi-Debadged, Dipped valance, badges, and emblem, custom 4 ft RGB LED lighted whip with custom mount, EZ down tailgate strut, 50" 5D LED light bar roof mounted via custom low profile mounts by MCM Fab & Design, custom cat back exhaust, muffler delete and replaced with a Flowmaster super44
    Any fixes for this issue?
  20. Mar 7, 2020 at 3:22 PM
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Mine ended up being the 4wd fuse on my 96 3.4L
