Tachometer is off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dawgspit, Jan 22, 2018.
  1. Jan 22, 2018 at 8:21 PM
    dawgspit
    dawgspit [OP] Member
    Ben
    Monte Vista, CO
    2010 Timberland Mica 4x4 DCLB
    OME 887 coils, Dakar leafs w/ Bili's 275/75/17 BFG KO2, Level 8 MK6 wheels "Infamous" eBay bumpers
    When I first got my truck for a couple of months I noticed that the RPM’s seemed a little high. I have recently installed a scan gauge and stereo that connects to the OBII port. Both of them show my rpm’s around 1500 to 1600 less than the gauge. Anyone have an idea why?
  2. Jan 22, 2018 at 8:46 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    I have a scangauge - no difference in rpm between it and the dashboard. What are you showing on dash and scangauge at idle with a/c off (and fan speed off)?
  3. Jan 22, 2018 at 8:53 PM
    dawgspit
    Ben
    Monte Vista, CO
    2,000 on the tach and 1350 on the scanguage.
  4. Jan 23, 2018 at 8:51 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  5. Jan 23, 2018 at 10:35 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    dawgspit
    My Tacoma is a V6-6 speed manual. Have had ScanGauge about 7 years. Today on a 45 degree day I observed the following with truck fully warmed up (10 mile drive) : HVAC fan off (insures a/c not running) ScanGauge shows 720rpm with transmission in neutral and dashboard very close. Try your truck in Park or Neutral if automatic. Also my experience on cruise control at highway speed if dashboard says 3000 rpm, ScanGauge shows 2950-3050 - close enough for me!
    Both of your readings at idle seem way high, at least on an engine that is fully warmed up. One thing you might try is record dash rpm as above, then unplug your accessories from the OBII port and see if your rpm (dash display) changes.
  6. Jan 23, 2018 at 10:49 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Do you have the options wrong on your scangauge? IE your scangauge is setup for a 4cyl when you actually have a 6cyl?
    2000RPM / 6 cyl = ~333
    333 x 4 cyl = ~1350RPM :notsure:
  7. Jan 23, 2018 at 12:45 PM
    Canufixit
    New England
    Not completely sure - but be sure the H controls are not on defrost as well as it may kick in the AC .
  8. Jan 23, 2018 at 4:39 PM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    HVAC fan off prevents the a/c compressor from running at all.
  9. Jan 23, 2018 at 6:25 PM
    Canufixit
    New England
    OK I may be way off on this (Or it was so long ago it has since been changed ) - but I remember reading something about the vehicle MFG's wanting to be sure that there is no buildup of fumes in the cab/interior so the fan would go to low low but not shut off when the engine is running .... ????
