Tachometer is on STRIKE!
Discussion in 'Technical Chat' started by toyby4, Dec 8, 2009.
  1. Dec 8, 2009 at 11:28 PM
    toyby4
    toyby4 [OP] Well-Known Member
    05 INDIGO INK PEARL TRD Sport
    Black HID Headlights, HID FOGs, Leer Tonneau, Tint, Pioneer NAV, Backup CAM
    My tachometer stopped working today.. Very strange as it seems all fuses are good and everything else seems to be working as normal... fuel and temp gauge seem to be ok too..... I have searched but this does not seem that common... any thoughts outside of a bad connection before i gotta get a cashectomie to diagnose?
    Thanks...
    Cheers,
    Mark:confused:
  2. Dec 9, 2009 at 10:31 AM
    toyby4
    Update.... this morning it worked...went for a drive... stopped for a coffee... then it didnt! :mad:
  3. Dec 9, 2009 at 10:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    There is a black and white wire that runs from the ECU ->connector-> combination meter. It may be possible that you have a loose connection at one of these points.
  4. Dec 9, 2009 at 1:35 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Looks like you will have to stop drinking coffee.
  5. Dec 10, 2009 at 12:51 AM
    toyby4
    So I took it all apart tonight... checked everything right down to the needle being stuck... Still doesnt work.. tho when I plugged it back in i heard like a little grinding noise and a slight wiggle from the tach.. i am thinkin its the cluster... now Ill start looking for one!!!
    M:eek::confused:
