Tachometer Not Working
Discussion in '1st Gen. Tacomas (1995-2004)' started by PhdNPrerunners, Apr 30, 2012.
  1. Apr 30, 2012 at 1:44 PM
    PhdNPrerunners
    PhdNPrerunners [OP] Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    I am looking at purchasing a 97 tacoma but the tach is not working. The speedometer is working but I did noticed that the cruise light was not working. What do you guys think it could be? Thanks
  2. Apr 30, 2012 at 1:46 PM
    saundern
    saundern Swerve for nothing
    Nick
    Greenville, SC
    2005 TRD Sport
  3. Apr 30, 2012 at 2:36 PM
    PhdNPrerunners
    Justin
    The Woodlands, TX
    Could it be anything else besides the fuse?
  4. Apr 30, 2012 at 2:42 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I think me and my buddy were talking about something like this yesturday, im not quite sure, but I think he said that a chipped tooth on the crank gear can cause your tach to not work.
  5. Apr 30, 2012 at 4:42 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    If the cruise light is not coming on could be a bad cruise ecm. If it was blinking you have a fault.
    So for the tach not working it could be a fuse or the lead coming from the Ecm is bad. Or the motor in the tach itself has gone bad(in the cluster itself). ( yes the motors do go bad).
    You dont have a check engine light on do you?
  6. Jan 5, 2016 at 10:28 AM
    aallen200010
    aallen200010 New Member
    Adam
    2016 Tacoma trd
    I also recently got a 2016 Tacoma trd my tach is also not working and if it does work it's sticking it just started today speedo seems to work fine it goes to dealership Thursday
