Tachometer shows idle as 4000 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by redlined_b16a, Nov 9, 2016.
  1. Nov 9, 2016 at 1:47 PM
    redlined_b16a
    redlined_b16a [OP] Member
    Louisiana
    05 Tacoma 2.7 Regular Cab
    Just bought a used 05 regular cab base,2.7 and 5 speed.
    Its the plain truck.No cruise control,manual windows and locks.
    Anyway Ran great for first 200 miles,tach was normal.
    Taught my 13 year old son to drive a standard,rode for about an hour with me perfecting take off on first.Nothing over 2000 rpm,lol lots of staling.
    Turned him loose in the yard by himself,1st gear only pratice start and stop.
    After about 40 minutes he came back and said tach was acting weird.
    At idle which was about 800 rpm,the tach is showing 4000 rpm,even when truck is off it wont drop lower than 4000 rpm.
    I tried search function but I had no luck getting it to work.
    ChadsPride likes this.
  2. Nov 9, 2016 at 1:48 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Damn. Subd for outcome.
  3. Nov 9, 2016 at 1:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm assuming the truck really isn't at 4k?
    So you are asking about dealing with a funky tach?
    ManBeast and ChadsPride like this.
  4. Nov 9, 2016 at 1:53 PM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    what about when you turn the truck off? stays at 4k?
  5. Nov 9, 2016 at 1:54 PM
    redlined_b16a
    Louisiana
    Engine is at normal idle,tach starts at 4k
    Engine off tach acts as if 4k is the zero point
  6. Nov 9, 2016 at 1:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd pull the tach and experiment with the needle mechanism to see if it's clean and free moving. Even a drop of light machine oil if you see a place to do that.
    Otherwise, I'd look for a junkyard cluster and swap in the 'new' tach.
    Or if its a real budget rig, just ignore the fact that it doesn't work. It's user eye candy for the most part.
    How many miles on the truck? What kind of 'life' has it led?
  7. Nov 9, 2016 at 2:03 PM
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    tach is either broken or the cable that receives the reading has become disconnected from one end(if there is no cable then correct me someone)
  8. Nov 9, 2016 at 2:07 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Stepper motor.
    nc300d and ChadsPride like this.
  9. Nov 9, 2016 at 2:12 PM
    redlined_b16a
    Louisiana
    110k miles,I dont use tach anyway,I shift by feel and sound.1800-2000 rpm.Im a gas saver.
    Don't know history of the truck.Bought it used from a dealership
  10. Nov 9, 2016 at 2:33 PM
    redlined_b16a
    Louisiana
    I let it sit awhile and keep checking on it,it returned to zero slowly,ticking like a stepper motor
  11. Nov 9, 2016 at 2:40 PM
    T4RFTMFW
  12. Nov 9, 2016 at 2:50 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
  13. Nov 9, 2016 at 4:53 PM
    Frogging
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ouch haha i must be wrong. i thought my data might be dated
  14. Nov 14, 2016 at 7:18 AM
    redlined_b16a
    Louisiana
    So after about 1/2 or running the rim drops to a lower reading.
    So there is an issue I'll have to investigate.
    Maybe clean a sensor,voltage issue.
    I'll keep it posted as I troubleshoot.
