Taco 17’ New Wheels *HELP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by A30v, Jun 16, 2021.
  1. Jun 16, 2021 at 10:56 AM
    A30v
    A30v [OP] New Member
    Andy
    17’ Toyota Tacoma TRD
    Looking to get a lift on my stock 2017 Tacoma TRD. My plan is to lift it 2-3 inches from stock height.
    What size wheels and tires will I be able to fit? Would 18s fit without rubbing or cuts? My wheels are currently 16s
  2. Jun 16, 2021 at 10:57 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No idea. Welcome to TW.
  3. Jun 16, 2021 at 11:07 AM
    RepoMarket
    RepoMarket Well-Known Member
    Scott
    Lehigh Valley, PA
    2017 DCSB SR5
    Eibach Pro / ICON Leafs
    there are about 6487 threads on here with sizes, lifts etc.. maybe more. that being said, I found it useful to learn what an offset is, what tire diameter means and how to search threads.
    you'll find what you're looking for.. guaranteed
  4. Jun 16, 2021 at 11:11 AM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    The options are many. What you can fit really depends on a lot of things. What do you want? you don't "need" huge tires, some guys (and there's threads on this) prefer a skinny tire. you can go with 16's, 17's, or 18's. You can have different type of offsets and rim widths. All of those factors will dictate which tire you can and cannot use. I would browse and see what people have and what you like. Unfortunately, no one can really answer this question for you.
  5. Jun 16, 2021 at 12:15 PM
    charliehex
    charliehex I belong in the dirt.
    Charlie
    Phoenix, AZ
    2021 Barcelona Red TRD OR DCSB
    285/70/17C BFG All Terrain TA KO2 Method 701 - Bronze 3”F/1"R Spacer Lift Sprint Booster MESO: Gasshole, Map Lights, Sequential Turn Signals Rough Country: Speedometer Calibrator, F/R Seat Covers R4T: Tail Gate Remote Rago: Center Console Molle Panel sPOD: Switch Controller Lamin-x: Amber Fog Light Covers ARB: Twin Compressor Slee Off Road: ARB Twin Compressor Mount Expedition Essentials: 3TPAM Accessory Mount RAM Mounts: Short, Long, Long arm, GoPro Mount
    The type of lift, wheels, tires and application matters. What lifts are you looking at buying? Are you looking for a wide tire stance? Are you going to drive your truck on some gnarly trails? Are you going long travel? Do you just want a different aesthetic?
    Without doing some super expensive and technical modifications, 35” tall tires are the limit for our trucks. For reference, this guy is running 35” BFG KM3 with a 2.5” Eibach lift and he had to do a significant amount of work to get them in there.
    https://youtu.be/ccx-rwtxevs
    And he still rubs on really flex trails…
    https://youtu.be/E16cnTTKkY0
    This isn’t perfect advice but for a 3”/2” spacer lift like I’ve got you can run 285/70/17 (32.75”) BFG KO2 (or similar) on a 17” Method 701 without rub. I’ve only had the rear axle twisted as much as it could handle in some rutted roads once and my rear tires never touched my fender. I’m not doing anything more technical than that until I upgrade tires, suspension and gearing but what I’ve got gets me to the hills and over basic stuff pretty easy with no rub.
    As far as 18” wheels go, I prefer smaller diameters because I want more tire sidewall than wheel. Less chance of rashing the wheels up. I guess 18” would give you more clearance around the caliper for super muddy situations when you could get gravel and other debris bound up in the wheel but I don’t take my truck through that stuff just yet. Method makes the 701 in an 18” but the width and backspacing are very different so I can’t make any recommendations.
    Welcome and hope this helps.
