taco 2.5 lift
Discussion in 'Suspension' started by 17hmrtaco, Jun 9, 2010.
  1. Jun 9, 2010 at 8:51 PM
    17hmrtaco
    17hmrtaco [OP] Active Member
    jake
    03 4wd 4door black
    rims,2.5 lift
    help needed
    i have a 2.5 inch lift on my 03 4 door taco im not sure what kind it was on there when i got the truck but i want to replace the shocks with billys but idk what size could someone plz help me
  2. Jun 10, 2010 at 12:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Need more info. Are the shocks shot and you just want news ones and want to keep the lift?
    Are you wanting to go to stock height?
    Post a picture of the front suspension and we can help you identify what kind of lift you have.
  3. Jun 10, 2010 at 3:39 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Someone correct me if I'm wrong.. but the OP has possibly 1 of 3 or more lifts/combinations.
    1. 5100's already (set at 2.5)
    2. Higher Spring Coils
    3. Spacer
    4. Combination of one or more..
    If you just want to change out to billy's and keep everything else the same, then just order from one of the many vendors (DSM, Wheelers, Toytec, etc) for billy's for the '03 taco, set them at "0".. and there is nothing else to do..
    If you want to "just" run billy's at 2.5, then your gonna have to make sure that you have the stock height coils..or your gonna wind up with a higher lift than just 2.5
    If you are just looking for the model/code for billy's that fit your '03..(which I hope you didn't start a thread just asking for that) type in bilstein 5100 03 tacoma in google and look around....
  4. Jun 12, 2010 at 2:46 PM
    17hmrtaco
    jake
    03 4wd 4door black
    rims,2.5 lift
    [​IMG] will this work
  5. Jun 12, 2010 at 4:39 PM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Take a little higher resolution pic and it will show up a little larger. I can't enlarge your pic enough to see exactly, but looks to me like you have a spacer.
    Depends on what you want to run. Do you want to keep your spacer?
  6. Jun 13, 2010 at 9:23 PM
    17hmrtaco
    jake
    03 4wd 4door black
    rims,2.5 lift
    i do want to keep the spacer and i also have a 2.5 block on the rear axal
  7. Jun 14, 2010 at 8:00 AM
    KPT
    09 Prerunner
    Still confused.....you want new shocks or no? You want to keep the spacer in particular, or just keep the truck lifted some other way?
  8. Jun 17, 2010 at 9:26 PM
    17hmrtaco
    jake
    03 4wd 4door black
    rims,2.5 lift
    i want to keep everything i just want to put billys on the truck
  9. Jun 18, 2010 at 12:55 AM
    raycie
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Now I'm confused... If you just want to replace with billy's, then your actual question is what???? Go to one of the dealers here on TW and order replacements for your year...
