Taco Bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akyota, Jan 3, 2010.
  1. Jan 3, 2010 at 11:09 AM
    akyota
    akyota [OP] Well-Known Member
    Fairbanks, Alaska
    10' DC trd-offroad mag gray
    none yet
    Just wondering if anyone has cracked or broken there plastic bed. When I bought my first taco in 08' I asked the owner of the stealership if he had heard of any flaws in the new bed's, of course he said no. Whats ur take taco friends?
  2. Jan 3, 2010 at 11:16 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    i have never heard of anyhting bad about them. the only thing that you cant do is if you install a bed bar like this [​IMG]
  3. Jan 3, 2010 at 11:27 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Seems pretty durable. Scratches really easy though I'd definitely get a bed mat.
  4. Jan 3, 2010 at 11:38 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Back in the early years of this generation (2005 - 2007) there were a handful of owners who managed to crack or tear the composite bed panels. In those cases where details were provided, it always turned out the owner had either (a) severely abused or overloaded the bed or (b) stressed the composite panels with poor attachment of add-ons (canopy; bed bars).
  5. Jan 3, 2010 at 11:41 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    How about spraying on a bed liner to add some strength
  6. Jan 3, 2010 at 11:46 AM
    akyota
    Fairbanks, Alaska
    none yet
    I like that idea, plus things wont slide around as much!!
  7. Jan 3, 2010 at 11:50 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I have a chip (not all the way through) in it thanks to a 700R4 transmission and a corner I took way to fast (bedmat too)
  8. Jan 3, 2010 at 2:15 PM
    chrisd540
    chrisd540 Member
    Northern Colo
    09 White TRD Sport
    Anthracite FJ TRD wheels, N-fab nerf bars, Bed mat
    I have called around to some local spray-in bedliner places and they have all said the same thing, they can't spray into our beds cause the rubber material won't stick. Anyone figure out a company or certain style that does work?
  9. Jan 3, 2010 at 2:56 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Honestly the strength of the bed is fine. Mine only chipped because a 300lb transmission slammed into the side of it... it'd have done a number on a metal bed too, if not more. Spraying it with bedliner might help the slickness... but a bedmat will take care of that...
  10. Jan 3, 2010 at 2:58 PM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    My buddy dropped his massive toolbox in the back of my bed from an overhead crane and all I got was a little scratch!
    The bed is very durable in my opinion!
  11. Jan 3, 2010 at 3:13 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    Mine is fine other than scratches. but imo i would rather have a metal bed with a spray in liner. It is what it is.
  12. Jan 3, 2010 at 3:36 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Mine is scratched up too, but I've hauled stuff like 50-100lb. rocks with no bed mat. Just this last week I drilled 8 holes through the bed to mount a hi-lift jack and it was almost identical to drilling though fiberglass. I know the bed composite material is more durable than fiberglass, but the debris from the hole was almost identical to fiberglass. I can't imagine you would "break" the bed unless you abused it and tried to break it.
  13. Jan 4, 2010 at 4:52 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    not even if you scuff it up w/a brillo pad first?
  14. Jan 4, 2010 at 6:34 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    ive been wanting to apply bed liner on mine but with all the research i have done 99% people suggested that i should not paint/apply bedliner ......
