Taco brakes on T100 axle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by FlapJack935, Nov 18, 2014.
  1. Nov 18, 2014 at 8:02 AM
    FlapJack935
    FlapJack935 [OP] i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    The title pretty much says it. i picked up a T100 for my long travel build this past weekend and want to know if my 2002 taco brakes can be swapped onto the T100 axle. i know the diffs are the same so im swapping the 4.10s i have now to get rid of the 3.91s.
    ive taken a look at both axles and it seems as if they use the same breaks aswell. any info would help. thanks
  2. Nov 18, 2014 at 8:18 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  3. Nov 18, 2014 at 11:06 AM
    FlapJack935
    Jack
    Abq New Mexico
    Because my T100 axle is complete besides the brake assembly. I don't want to drop more $$$ if my perfectly good brakes on the taco would work on the T100 axle. I've spent enough money on my front and rear long travel. I I thought why not use the best of what I got. Thanks for the input.
  4. Nov 18, 2014 at 11:29 AM
    keakar
    karl
    louisiana
    well that makes sense and is smart, its just most people swap for upgrades to go bigger tires and such so its expected someone doing it needs, or definitely could use, a brake upgrade as well.
    im no expert but I expect you will find it all swaps out and works but wait for someone who knows more then me to listen too
  5. Nov 18, 2014 at 11:45 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Short answer...it depends. T100 came with two different shoes. One that is identical to the 1st gen tacoma shoes (and 4rd gen 4runner, and pickup/pre-taco, and tundra), while the other was the same as the late 80s/early 90s land cruiser.
    The holes drilled in the shoe frame for the springs and clips are slightly different between the two. If you compare your taco shoes to the t100 shoes and they are the same...you're good to go.
    He's talking about rear brakes, not front.
    The swap is because the t100 axle is 6" wider than the 1st gen tacoma. Has nothing to do with better braking. WMS-WMS is 66" instead of 60". It pairs up with a front LT much better and allows you to outboard the shocks if you're clever with shock placement and fabrication.
  6. Nov 18, 2014 at 11:46 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Well for one, a T-100 and a Tundra are not the same so telling OP to ditch his idea and do a Tundra brake swap isn't helpful to his cause.
    OP I'm petty sure they'll fit. The T-100 was a bastard child that came about so that Toyota could finally break into the big boy truck market. It utilizes mainly Tacoma parts on the new, larger T-100 frame and body. Hell it even uses the same V6.
  7. Nov 18, 2014 at 12:03 PM
    FlapJack935
    Jack
    Abq New Mexico
    Thanks for all the info guys. I've read a lot that the T100s are the same thing but just 6" wider. Brake upgrading is not really important to me. I'll let you guys know how it all turns out. From what I've read I can swap my 4.10 diff and able to swap the brakes.
  8. Nov 18, 2014 at 12:07 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    As long as your taco diff is the 8.4 (non e-locker) then yes, it fits. Drops right in.
    BTW I put in a tundra rear end in my truck a couple years ago, so feel free to ask questions if you have any.
  9. Nov 18, 2014 at 12:11 PM
    FlapJack935
    Jack
    Abq New Mexico
    Yupp none e-locker thanks man I appreciate the info. If I have any questions I'll either PM your or DM though instagram
  10. Nov 22, 2014 at 1:53 AM
    Mikey949
    Mikey949 Member
    Mikey
    If you still have the 3:91 ring and pinion I'm interested. Shoot me a text 9496064409. Thanks
