Taco Bros - Technical Thread/Mazn Build Thred
Discussion in 'Off-Topic Discussion' started by dakotasyota, Dec 3, 2014.
  1. Jun 5, 2015 at 10:07 AM
    #2521
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    I think so
  2. Jun 5, 2015 at 1:15 PM
    #2522
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Yeah the whole teen thing irritated me haha
  3. Jun 5, 2015 at 1:15 PM
    #2523
    HHIRunner
    Jake
    ATX
    ‘20 Taco
    Damn elderly folk trying to ruin our fun
  4. Jun 5, 2015 at 2:30 PM
    #2524
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Well alright then
  5. Jun 20, 2015 at 10:44 AM
    #2525
    dakotasyota
    Dakota
    Ellensburg, WA
    Since I'm already in there resealing my timing cover, would you guys replace the water pump too? Do they commonly go out? I have 166k miles...
  6. Jun 20, 2015 at 10:45 AM
    #2526
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If you're already in there, I'm on the team of might as well.
  7. Jun 20, 2015 at 10:46 AM
    #2527
    HHIRunner
    Jake
    ATX
    ‘20 Taco
  8. Jun 20, 2015 at 10:47 AM
    #2528
    dakotasyota
    Dakota
    Ellensburg, WA
    That's what I'm thinking... it's not too expensive for OEM...
  9. Jun 20, 2015 at 12:00 PM
    #2529
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The way I was taught you always replace the WP if you're in doing the timing belt/chain.
    Thinking about buying some plate steel instead of my tax stamp for the suppressor, Dad told me yesterday that a friend of his is going to store his plasma cutter at our house and that we can use it whenever we want.
    Be a lot easier to cut out the plates for a bumper with a plasma cutter rather than a cutting torch.
  10. Jun 20, 2015 at 12:09 PM
    #2530
    dakotasyota
    Dakota
    Ellensburg, WA
    Hmm well the timing chain is supposed to last the life of the engine...
    Damn in jelly; I want a plasma cutter
  11. Jun 20, 2015 at 1:31 PM
    #2531
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  12. Jun 20, 2015 at 5:24 PM
    #2532
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    Okay guys.. Just did projectors on my truck. How does the wiring work for halos? I didn't order them but I'm curious what you wire them to?
  13. Jun 20, 2015 at 5:42 PM
    #2533
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I did mine to my fog light switch. You don't want them running with your DRLS because then they'll run when your headlights are and that causes unnessicary heat and causes the leds to burn up prematurely
  14. Jun 20, 2015 at 6:05 PM
    #2534
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    I was hoping you'd see my question! hmm okay, thanks Phoenix
  15. Jun 20, 2015 at 7:06 PM
    #2535
    Boogyman
    Phoenix
    Corpus Christi, TX
    No prob. Pick up a decent switch you want and run it to there
  16. Aug 12, 2015 at 10:29 AM
    #2536
    dakotasyota
    Dakota
    Ellensburg, WA
    @tacobell007
    Here lets try this. What things do I need from this diagram?
    The shaft bearing (number 5) is quite cheap...
    I'm hoping I don't need all of these
    [ 4 ] UNIVERSALS & REAR AXLE / REAR AXLE / REAR AXLE / AXLE SEALS
    Part Number: 9031058003
    axle seals Tacoma
    MSRP Core ? Online Price
    $8.26 $0.00 $5.95
    [ 5 ] UNIVERSALS & REAR AXLE / REAR AXLE / REAR AXLE / SHAFT BEARINGS
    Part Number: 4242360050
    shaft bearings Tacoma
    $25.46 $0.00 $18.36
    [ 6 ] UNIVERSALS & REAR AXLE / REAR AXLE / REAR AXLE / BEARING HOUSING
    Part Number: 4245004010
    bearing housing Tacoma; Right
    $406.27 $0.00 $293.10
  17. Aug 12, 2015 at 1:09 PM
    #2537
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    @dakotasyota
    I would say number 5 and number 10 (if its a bearing) at the very least is what you should get besides the axle shaft itself but I don't see a number for the bearing housing unless you tear it apart and its trashed
  18. Aug 12, 2015 at 3:00 PM
    #2538
    dakotasyota
    Dakota
    Ellensburg, WA
    Cool thank You!
  19. Sep 9, 2016 at 11:28 PM
    #2539
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    :rofl:
  20. Sep 10, 2016 at 8:37 PM
    #2540
    MatthewMay1
    Matthew
    Lone Star Republic
