Taco Bros - Technical Thread/Mazn Build Thred
Discussion in 'Off-Topic Discussion' started by dakotasyota, Dec 3, 2014.
  1. Jan 4, 2015 at 3:50 PM
    #1581
    Tcgator
    Tcgator Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
  2. Jan 4, 2015 at 4:00 PM
    #1582
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I feel like 4wheelparts would know their stuff... You're just worried the wires leading to the harness are too small?
  3. Jan 4, 2015 at 4:03 PM
    #1583
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    14 gauge wire is good. Do you have an auxiliary fuse block?
    If not, you have to use a 4 pin relay. I recommend an OTRATTW brand or aironboard.com switch. They have ones very similar to the OEM fog light switch.
  4. Jan 4, 2015 at 4:05 PM
    #1584
    MTopp
    05 SR5 4x4
    If you need instructions on how to wire it, pm me.
  5. Jan 4, 2015 at 4:43 PM
    #1585
    Tcgator
    Tyler
    Fernandina beach
    Soo the led bar is 50" and its 288 watts with 96 leds.. But I'm concerned about the gauge of the wire.. The harnes they wanna use is 14awg and doesn't that only power about 208ish watts? And if it did work, WOulfnt it cut down the power and lighting of the led bar? Or should i build my own harness with a. 10 gauge wire?...
  6. Jan 5, 2015 at 6:29 AM
    #1586
    MTopp
    05 SR5 4x4
    Build your own like we said in PMs, and then cover it all with wire loom.
  7. Jan 5, 2015 at 12:30 PM
    #1587
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I know this is off topic from what yall have been talking about, but found out the magic pressure is 12psi for my tires and weight. Went through 2 feet up snow with them until I almost went in the ditch and lost momentum :(
  8. Jan 5, 2015 at 12:45 PM
    #1588
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Ultragauge finally emailed me, i can still get my repair done!!
  9. Jan 5, 2015 at 12:45 PM
    #1589
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    :woot:
  10. Jan 5, 2015 at 12:46 PM
    #1590
    dakotasyota
    Dakota
    Ellensburg, WA
    yee yee
  11. Jan 6, 2015 at 12:29 PM
    #1591
    MTopp
    05 SR5 4x4
    Magic as in good? Is lower psi better in snow
  12. Jan 6, 2015 at 12:40 PM
    #1592
    dakotasyota
    Dakota
    Ellensburg, WA
    Does anyone know how big the 2nd gen gas tank is?
  13. Jan 6, 2015 at 1:59 PM
    #1593
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    21 gallons. Owner's manual bud ;)
  14. Jan 6, 2015 at 2:31 PM
    #1594
    dakotasyota
    Dakota
    Ellensburg, WA
    Haha wow that's bigger than I thought. I always though it was 17 until I just pumped 17.5 gallons into it :facepalm:
  15. Jan 6, 2015 at 2:37 PM
    #1595
    tacobell007
    Drew
    Western MA
    Lol the old trucks hold that much I believe. Pretty sure my 88 was 17 gallon
  16. Jan 6, 2015 at 3:20 PM
    #1596
    AR15xAR10
    Ultragauge repair should commence thurs.
    Hopefully i'll have it back early next week.
  17. Jan 6, 2015 at 3:21 PM
    #1597
    AR15xAR10
    21.1
    It'll hold about 22.75 all the way up to the gas cap if anyone is curious
  18. Jan 6, 2015 at 3:43 PM
    #1598
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yup. The lower you go the more tread surface is on the ground, plus if you have side tread and go low enough that will dig in too. Thats why people have beadlock wheels is so they can go extremely low pressure and not worry about blowing a bead
  19. Jan 6, 2015 at 4:10 PM
    #1599
    MTopp
    05 SR5 4x4
    Cool, that's what I thought you were getting at. Knew it was good to air down for most things, wasn't sure on snow :thumbsup:
  20. Jan 6, 2015 at 6:48 PM
    #1600
    dakotasyota
    Dakota
    Ellensburg, WA
    How'd ya figure that one out? Ran her out of gas?
