Taco Bros - Technical Thread/Mazn Build Thred
Discussion in 'Off-Topic Discussion' started by dakotasyota, Dec 3, 2014.
  1. Jan 9, 2015 at 10:27 PM
    #1701
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    thats right. the ifps are definitely progressive. i drove all over the parking lot medians at work tonight and you could barely tell you were dropping off of them. but i have taken them to 50+ off road and they still do great hitting pot holes. they were way better before i put my bumper on but they still rock
  2. Jan 9, 2015 at 10:28 PM
    #1702
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Oh and emulsion shocks, usually seen in rear shocks, are were the nitrogen and oil is mixed together in the shock, a remote resivore usually will hold a floating piston dividing the nitrogen from the oil, same with the piggy back.
  3. Jan 9, 2015 at 10:42 PM
    #1703
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
  4. Jan 9, 2015 at 11:38 PM
    #1704
    gray223
    SE Missouri
    2014 Tundra Limited
    Ya I think your right.
  5. Jan 9, 2015 at 11:58 PM
    #1705
    gray223
    SE Missouri
    2014 Tundra Limited
    Here is what the coilover bible says , If the valving is progressive, the rate of change of stiffness increases as velocity increases; and if the valving is digressive, the rate of change of damping gets less as the shocks velocity increases.
    So ya I think you want progressive since the stiffness increases as velocity increases. Unless you want more dampening when your going slow? I'm not sure. Are you suppose to want more dampening when going slow since you won't be going fast, or less dampening?
    And if your wanting to go fast, do you need more dampening when going fast, or less dampening?
  6. Jan 10, 2015 at 12:03 AM
    #1706
    gray223
    SE Missouri
    2014 Tundra Limited
    OK looked around some more and progressive is for low speed stuff, rock crawling etc. Digressive is for high speed stuff. Each have there draw backs and each which will be different on a number of factors not just, digressive vs. Progressive.
  7. Jan 10, 2015 at 8:35 AM
    #1707
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I want a soft suspension at low speeds that will soak up the rocks and bumps. Ill never be going over 20mph off road so I feel like I won't need a digressive shock. But then again everyone says how they love their icons off road so Im not sure. Guess I gotta do more research
  8. Jan 10, 2015 at 9:50 AM
    #1708
    Boogyman
    Phoenix
    Corpus Christi, TX
    Icons are great for everything but crawling imo. Stiff suspension at low speeds in the rocks? No thanks lol. Foxes kings and ORIs are all I'll go with
  9. Jan 10, 2015 at 9:58 AM
    #1709
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yeah im leaning towards the fox's. A bit less $$$ too since I have to get Uniball UCA's right?
  10. Jan 10, 2015 at 9:59 AM
    #1710
    Boogyman
    Phoenix
    Corpus Christi, TX
    You don't have to. I'm running LRs which are ball joint
  11. Jan 10, 2015 at 9:59 AM
    #1711
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    But your CO's arent extended length are they?
  12. Jan 10, 2015 at 10:01 AM
    #1712
    Boogyman
    Phoenix
    Corpus Christi, TX
    I don't think so but it shouldn't matter. I think it just depends on personal preference and budget
  13. Jan 10, 2015 at 10:02 AM
    #1713
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Oh okay, I thought with extended CO's you have to have uniball uca's
  14. Jan 10, 2015 at 10:02 AM
    #1714
    Boogyman
    Phoenix
    Corpus Christi, TX
    Never heard that lol. What coilovers are you looking at
  15. Jan 10, 2015 at 10:08 AM
    #1715
    gray223
    SE Missouri
    2014 Tundra Limited
    Ya you have to get aftermarket UCA's if you get the extended travel shock, at least that what I've heard. It doesn't necessary have to be a uni ball.
  16. Jan 10, 2015 at 10:33 AM
    #1716
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Oh okay never mind then.
    And im looking at either the icons or fox's, top 2
    http://www.headstrongoffroad.com/coilovers-tacoma-05-6-lug.html
    What I don't like about icon is that its a 13 inch coil so you have to preload it that much more to get height, I haven't been able to find what fox's coil is.
  17. Jan 10, 2015 at 10:38 AM
    #1717
    Boogyman
    Phoenix
    Corpus Christi, TX
    My 2.0 ifps have a 14in coil
  18. Jan 10, 2015 at 11:01 AM
    #1718
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Less preload then to get the same amount of lift compared to the icons then correct? I'd assume its probably the same spring rate and length. What do you think about those fox ones Phoenix?
  19. Jan 10, 2015 at 10:43 PM
    #1719
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I'm still lost on what coilovers i need :/
  20. Jan 10, 2015 at 10:43 PM
    #1720
    Boogyman
    Phoenix
    Corpus Christi, TX
    I woulda ran them if I could've afforded them at the time lol
