Taco Bump Steer? Where to Start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColeRedRubi, Mar 14, 2016.
  1. Sep 17, 2023 at 11:11 AM
    #41
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I would want it to be at least 3 degrees. If your truck is lifted and you do not have aftermarket UCA's, 3 degrees might not be obtainable. On my truck with 37's, I run about 4 degrees. When my truck first had about a 3" lift with no aftermarket UCA's, it would wander on the freeway when hitting small bumps, caster #'s were at the lower end of the acceptable OEM spec, and that was with about 33" tires.
    BlueTaco9486[QUOTED] likes this.
  2. Sep 17, 2023 at 11:19 AM
    #42
    deeezy
    Dana
    Hawaii
    And, wandering can also be caused by having any play in the steering system to the tires, steering shaft, steering rack, steering rack bushings, inner and outer tie rods, bad wheel bearings, etc.....
  3. Sep 17, 2023 at 11:28 AM
    #43
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Your toe numbers are very low. This will cause instability over bumps (wants to dart rather than being stable at center). Get at least in the middle of the range for total toe.
  4. Sep 17, 2023 at 1:30 PM
    #44
    BlueTaco9486
    BlueTaco9486 Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    Thank you. I’ve replaced all the ball joints in an outer tie, rods, rack and pinion steering intermediate shaft, sway bar links, and sway bar bushings. Tires are brand new and I’ve got a regular factory spec alignment. I think the caster sit at about 1.5-2.0
    deeezy[QUOTED] likes this.
  5. Sep 17, 2023 at 2:01 PM
    #45
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    Those large tires can exacerbate the wander / tracking issues for sure . As others have said maxing out the caster will probably help. FYI Most of these alignment places won’t touch the adjustments if it’s in spec, so good luck.
    btw, you asked before about bumping up the 5100s; that will limit your ability to get enough camber without aftermarket UCAs, so that would make it worse.
    You’ll notice folks with tires and lift will also do UCAs primarily to get more caster. (Myself included, and it 3 degs helped tremendously)
  6. Jun 9, 2025 at 6:31 PM
    #46
    noah_sobel
    noah_sobel Well-Known Member
    Noah
    Army Green 2020 Toyota Tacoma TRD Pro
    Wescott lift and 33”s
    Did this fix the issue I’m having the same issue with my 2020 TRD pro
