Taco Differential spacer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoguy05, Jul 30, 2021.
  1. Jul 30, 2021 at 7:26 PM
    Tacoguy05
    Tacoguy05 [OP] Active Member
    2018 TRD Sport
    If you install the ECGS bearing when doing a lift, do you still need to install a differential spacer?
    I’ve heard some say a diff spacer isn’t good because it pools oil and makes it difficult to Lubricant.
    Wondering what everyone’s thoughts are.
  2. Jul 30, 2021 at 7:34 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    A lift does not affect the front diff driveshaft angle. The diff bushing is a solid brass-type. It’s there to eliminate the up/down play with the stock needle bearing after a lift because the axle shaft is at a higher angle and begins to destroy the needles after a lift. A diff spacer (assuming you mean a driveshaft spacer) is not necessary.
  3. Jul 30, 2021 at 7:53 PM
    Tacoguy05
    2018 TRD Sport
    Yeah, the drivers side CV axle on the Tacoma. It has a bunch of play. When I lifted my Tacoma I got the infamous hum noise. After the install of the ECGS it did go away.
    Just wanted to make sure I didn’t have to install it.
  4. Jul 30, 2021 at 8:24 PM
    bijick
    E
    Stl
