Taco Down:(
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Tyrant, Jun 27, 2022.
  1. Jul 6, 2022 at 2:58 PM
    #241
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    Oof, mpp... Should have gotten the Toyota VSA.
  2. Jul 6, 2022 at 3:07 PM
    #242
    Taco Tyrant
    Taco Tyrant [OP] Well-Known Member
    Hondo Tx
    2020 SR V6 4WD
    Is that on better? I got MPP platinum warranty, but didn’t remember I bought it or how much I payed for it. Will be interesting to see how it shakes out
  3. Jul 6, 2022 at 4:35 PM
    #243
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    screwy is a relative term :bananadance:.. That being said everything I’ve posted on here has been 100% honest and I’ve given all the info I can think might be relevant in order to try to figure out what the hell happened because to be honest my truck breaking down is a bummer cause I love my little taco and want to figure out what the hell happened at the end of the day.
    just spoke to Toyota customer service advisor and they’re going to escalate it to a “senior advisor”, but they said “it’s really for the tech at the dealership to diagnose and Toyota corporate doesn’t do that.” I should hear back by end of day tomorrow.
  4. Jul 6, 2022 at 4:35 PM
    #244
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I agree a thermostat usually fails open and even if it fails closed the car will gradually overheat. As for the sensor I don’t see how it’s the issue here. A faulty sensor may not report the overheating but won’t cause it.
    Your guess is as good as mine what truly caused this. But based on what you’re saying here I can’t see how either are the culprit here.
  5. Jul 6, 2022 at 4:45 PM
    #245
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    bad temp sensor wouldn’t cause the overheat, but could cause a bad water pump to escalate to blown head gasket, warped head etc. I was thinking that knowing if the temp sensor was faulty or not would help reduce the possible causes for over heat or blow head gasket. Seems like if that temp sensor is good then it was a bad / failed head gasket.
  6. Jul 6, 2022 at 5:06 PM
    #246
    RX1cobra
    19 OR
    Don’t disagree just seems like a long shot. To me the sensor works or it doesn’t. And if it the gauge went from cold to normal on the drive it leads me to think it was working.
    You unfortunately seem to have a rare situation here and might just be one of those shit happens types of deals. And never 100% know what caused it.
    But I’m far from an expert. In the end hopefully you get it covered one way or another.
  7. Jul 6, 2022 at 5:11 PM
    #247
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    I hear ya. It’s good to have folks to help think through it. I’m feeling like it was bad head gasket if I was a betting man I’d put cash on that as the cause. May never know but I really want to haha
    RX1cobra[QUOTED] likes this.
  8. Jul 6, 2022 at 8:36 PM
    #248
    6mtTRD
    6mtTRD Well-Known Member
    2022 Celestial Silver Metallic TRD Off-Road
    Cilajet ceramic coating
    I hope this works out for you OP but why aren’t you satisfied if they replace it with a rebuilt engine? Your engine had 65k miles on it; it’s used. If they replace it with an engine with 65k miles on it, you’re made whole. If they replace it with an engine with less than 65k miles, you made out better. Just because you purchased the truck new doesn’t mean it’s a new truck anymore. Your truck was used 65k miles, so a rebuilt engine makes perfect sense. It’s the same thing if your iPhone shits the bed on day 364; Apple will give you a refurbished iPhone that will have the remainder of your factory warranty or 90 day warranty, whichever is greater.
  9. Jul 6, 2022 at 9:01 PM
    #249
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    Thank you. All good points and I see why anyone would ask the question and take that angle, but the biggest thing to me is that miles are relative. Let say someone was ragging their shit for 20k, 65k or 95k miles and didn’t take care of it or didn’t maintain it and that’s the motor I get? I drove 64.5k miles of my 65k miles and took care of my shit in a way most humans don’t these days. I changed the oil every 5k not that 10k bullshit, it was mine and I took care of it. What if they replace it with an engine that has 90k miles on it driven by some idiot that didn’t give a shit about it? It’s not the same and the failure wasn’t caused by me. Why should I not expect them to make me whole at the minimum (fix my shit) and if the can’t then they should make it right, but not less than before.
    Superdave1.0 and ColoradoTJ like this.
  10. Jul 6, 2022 at 9:16 PM
    #250
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Because Toyota owes you nothing on a truck that is outside of warranty coverage. The extended warranty you bought likely says in your paperwork that they can use new, used or remanufactured parts at their discretion, something you agreed to when buying it.
    Hoping you luck out with a free repair covered by someone though.
  11. Jul 6, 2022 at 9:18 PM
    #251
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    The motor should be 64k miles or less. I agree that you have no idea what/how the motor was cared for. Even if the oil was changed every 5k was it the right oil? I have heard that sad song a lot.
  12. Jul 6, 2022 at 10:37 PM
    #252
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    Thank you. To clarify, nothing about this situation is free to me. The cost of towing, borrowing another vehicle, initial cost of the truck and extended warranty, the hours on the phone, the loss of my beloved lil truck etc. if you think this is free to me you’re an idiot. What I’m realizing through this is that, as you say Toyota may not owe me anything, and I mistakingly placed my trust and respect with them as a company, engineers and manufacturers. I’m pretty bummed about it to be honest. Willing to give it a few more days but also thinking about how to move forward to make me feel better which include a whole lot of negative marketing and childishly annoying people in a big way with internet trolling.
  13. Jul 7, 2022 at 5:56 AM
    #253
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Is it even possible to find a low mileage donor motor these days? Another good question is who is doing the motor swap? Is it the same guys that just do oil changes and basic maintenance everyday? How many things will they screw up or forget to tighten properly. I would trade that truck in as soon as it was fixed.
    usmc2msu and Taco Tyrant[OP] like this.
  14. Jul 7, 2022 at 6:35 AM
    #254
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    People crash them every day, even brand new ones.
    I did a quick search and found 5 engines under 20,000 miles on the first page.
    https://www.car-part.com/
  15. Jul 7, 2022 at 6:44 AM
    #255
    ColoradoTJ
    Colorado
    There are plenty of low mileage vehicles engines. How many “is it totaled” threads are on here alone?
    I have never used a 3rd party warranty coverage, but have seen plenty that do in my personal life. In the past year two of my associates at work did. One in a Kia Stinger and one in an Infinity G37. No issues since. I know swapping out a modern engine isn’t easier than a 1970 Chevelle, but a shade tree mechanic can do it.
  16. Jul 7, 2022 at 6:49 AM
    #256
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I don't think you mistakenly put your trust in them. Toyota is known to build vehicles that last and rarely have major issues and you are part of the unlucky small percentage that ended up with an issue. You just won the shitty lottery unfortunately which is bound to happen to somebody with mass production of anything.
  17. Jul 7, 2022 at 7:00 AM
    #257
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    I agree. Trying to decide if I should swap it for a newer one just like it or go with something else. I really like the tacoma, and if it was just luck what are the odds I get 2 in a row??? Haha:taco:
    TACOTU3 likes this.
  18. Jul 7, 2022 at 7:14 AM
    #258
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Better question is , what are the chances of something catastrophic happening twice to an otherwise reliable vehicle (another Taco), compared to the chances of buying another vehicle and something happening to that?
    I say chances are LESS on getting another Taco. Both scenarios have risks. Nothing guaranteed. But one has less IMo.
    I say Taco Tuesday 365 24/7
  19. Jul 7, 2022 at 7:28 AM
    #259
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    :rofl:
    Junkhead likes this.
  20. Jul 7, 2022 at 7:29 AM
    #260
    Taco Tyrant
    Hondo Tx
    2020 SR V6 4WD
    I think you’re right and this time I can order the 5 speed SR
    stealthmode[QUOTED] likes this.
