Taco floats around the road, makes me motion sick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicholishen, Feb 11, 2015.
  1. Feb 12, 2015 at 8:49 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Put some smooth Michelin tires on it if it's mainly a highway ride. It made a big difference on mine when my old TA/ KO's wore out that were jarring fillings loose in my teeth.
  2. Feb 12, 2015 at 9:00 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    What tire pressure are you running ? It may be part of the problem.
  3. Feb 12, 2015 at 9:07 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I have never noticed that on mine, maybe it's the bilstein shocks.
  4. Feb 13, 2015 at 7:52 AM
    nicholishen
    nicholishen [OP] Member
    FL
    15 PreRunner
    The problem is the bouncing floating sensation. I'm thinking new tires, sway bar, with some aftermarket coil overs. When I'm on the highway now it feels like the suspension loads up on the dips and then springs back launching the truck up like it wants to jump. This would be fun as hell on dirt roads, but not a smooth ride on the highway. I'd rather feel the road harshness vs the bouncing pogo stick.
    A truck shop has recommended fox 2.0 performance coil overs. Is that over kill? They're asking $1750 for front and back installed, out the door with alignment.
  5. Feb 13, 2015 at 8:42 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Overkill, yes, if you plan to stay on road. I would just get some Bilstein 5100s to start with, then set them at .85 lift, which will pre-load the existing springs. If that's not enough, can always set them higher.
    If it's still not enough, try some stiffer springs.
    Also keep in mind that a swaybar only comes into play in corners, not straight line.
  6. Feb 13, 2015 at 10:43 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I found the stock non-TRD suspension is soft and mushy. But the TRD suspension is stiff and harsh.
    But the Icon suspension is perfect.
  7. Feb 13, 2015 at 10:48 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    My dog gets carsick in my truck. She rides in the bed now :anonymous:
  8. Feb 13, 2015 at 11:07 AM
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    Early on my TRD would make me motion sick because it would sway a bit. But I changed tires and broke in the suspension a bit and it doesn't sway. Some would consider it harsh but compared to my other car, the Taco is soft.
  9. Feb 23, 2015 at 10:15 AM
    nicholishen
    FL
    15 PreRunner
    I wound up widening the stance with some 16x8 rims and swapped the tires to 255 70 16 Michelin ltx ms2's. I added 200 lbs to the bed and she rides like a dream now.
