TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. Dec 6, 2019 at 9:54 PM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    CAMERA CONTROLLERS ARE IN STOCK AND READY TO SHIP
    USE CODE TW10 FOR 10% OFF ($127 shipped)
    This is a PLUG AND PLAY kit that you connect to the back of your head unit and it allows you to turn on the rear camera at anytime, the kit also allows you to easily wire a front facing camera and turn it on at any time (does not come included, most NTSC cams will work). This system does not interfere with normal operation of the backup cam.
    OPERATING THE SYSTEM: (assuming front cam is also installed)
    Normal operation: When the car switches to REVERSE the rear camera will turn on like normal, when not in REVERSE, pressing the "MODE" button twice will activate the camera for 30 seconds or until speed exceeds 12mph and then go back to normal infotainment screen. When switching from REVERSE to a different gear, front cam will come on for 30 seconds.
    Switch between cams: Press "next" or "previous" track button on your steering wheel to switch between front and rear cams respectively. (up arrow for front and down arrow for rear)
    Camera hold: Press "MODE" button twice, then hold the up arrow or down arrow until you hear a beep and the camera will stay on until you press "MODE" again, once in HOLD mode you can switch between cams and stay in HOLD mode.
    Parallel Parking: When parallel parking, the cam will automatically turn on when you switch to REVERSE, then when you switch to DRIVE the front cam will come on and go back to rear cam when you switch to REVERSE again, and so on for 2 hours until you're done parking...
    So far we can only confirm compatibitily with 2014/2015 second gen and 2016-2019 third gen models. 2013s should be fine too but we cant confirm.
    I installed it on my taco and I could not believe how easy the installation was, the hardest part was drilling a hole on my grill to install the front camera. It is a little bit time consuming but not all that difficult.
    Installation process will be outlined here soon, but for now there is a video below...
    Here is a video by @iampraneel we our working on our version of it.
    Here is some wiring help, this is with our camera.
    2020 pre-pre-order list and promo: (expired)
    The pre orders below will get $25 store credit valid for anything in our store, or $35 if bought bundled with a camera *
    1. 5133 @Devir7
    2. 5141 @Criera
    3. 5139 @dpm89
    4. @CP40
    5. 5132 @mosccat
    6. @rotus
    7. 5138 @mjanmohammad
    8. 5254@Mossman6
    9. @badstainless
      File size:
      28.5 KB
      637
  2. Dec 6, 2019 at 10:30 PM
    Meeks13
    Meeks13 Well-Known Member
    Seattle
    2017 4Runner Cement Pro
    King Suspension-SPC UCAS and Dobinson C59-327 Rear Springs-Duratracs 285/70/17-Shrockworks Sliders-K9 Full Roof Rack-CVT Awning 79”-Canvasback Liners -Morimoto HID -SCS Ray 10s 17x9 -38 Matte Black -OEM Audio Plus Reference Package with Gain Adjuster and Second Dedicated Sub Amp -TRD CAI-ARB Twin air compressor -Rago Fabrication Driver Side Panel -C4 Rear Dual Swingout-C4 Lo Pro- Baja S8-Anytime Front/Rear Camera-Nitro Gears 4.88-RCI Aluminum Transmission/Integration Skids
    Will these work for the 2020 new infotainment system??
  3. Dec 6, 2019 at 10:48 PM
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
    Does this kit include the camera?
    THE_KiRRAx likes this.
  4. Dec 7, 2019 at 5:09 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    is this a complete kit with the camera?
  5. Dec 7, 2019 at 5:57 AM
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Those were the exact parts I was getting from Amazon and direct. Guess that means I chose well!
  6. Dec 9, 2019 at 8:37 AM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    Not sure if these are still available. Sent PM a couple of days ago and no response.
  7. Dec 10, 2019 at 10:11 AM
    xconaty
    xconaty Well-Known Member
    Ash
    Pinehurst, NC
    2017 Silver Taco TRD Off Road
    TRD Pro Fox Suspension TRD Pro Skid Plate Katzkin Leather Interior 17" TRD Pro Wheels BFG KO2 Tires
    I’m in for one. Still available?
  8. Dec 10, 2019 at 3:20 PM
    FreshMexicanTaco
    AJ
    San Diego
    I'm going through the messages now, ill be responding in order received.
    @Meeks13 I dont know if the work for new infotainment sorry...
  9. Dec 10, 2019 at 10:45 PM
    nivragni24
    nivragni24 Well-Known Member
    Los Angeles, CA
    2019 TRD OR 4x4
    Do u do installation as well?
  10. Dec 10, 2019 at 11:17 PM
    dc2’s
    California
    Added a driver
  11. Dec 10, 2019 at 11:18 PM
    richwhat03
    richwhat03 Well-Known Member
    Rich
    Interested to know if this includes cameras as well
  12. Dec 10, 2019 at 11:22 PM
    dc2’s
    California
    Added a driver
    I just order mine and I don’t think it does
    Lpulford likes this.
  13. Dec 15, 2019 at 9:13 AM
    FreshMexicanTaco
    AJ
    San Diego
    So I was able to get a deal on these and I will be stocking them from now on, price is now reduced to 139.50 and you can all buy it directly from our store here. Also if you bought this from our first batch let me know and I will send you a partial refund!
    dc2’s likes this.
  14. Dec 15, 2019 at 12:15 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Sub'd!! I want this!!! Need to wait until after Xmas bills though. Awesome!!!
    Also interested in knowing more about front camera.
  15. Dec 15, 2019 at 1:56 PM
    FreshMexicanTaco
    AJ
    San Diego
    Like I mention on the first post, the group discount will go through 1/15 so you can still get in after Christmas.
    davidstacoma likes this.
  16. Dec 15, 2019 at 3:18 PM
    velomutt
    velomutt Well-Known Member
    2018 Taco DCLB OR INFERNO
    A bunch of Meso Custom stuff.
    In and purchased.
    FreshMexicanTaco[OP] likes this.
  17. Dec 15, 2019 at 3:52 PM
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    Any recommendations on a front camera to go with this kit or known list of working cameras for it?
  18. Dec 15, 2019 at 4:09 PM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    lol, my wallet hates you, but my truck loves you.
    SD_Taco likes this.
  19. Dec 15, 2019 at 8:00 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
  20. Dec 15, 2019 at 8:26 PM
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    Anybody know where the front camera location is on the new 2020 model?
