TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. Dec 26, 2019 at 4:15 PM
    #221
    StokeTRD
    StokeTRD Well-Known Member
    2019 TRD OFFROAD
    @FreshMexicanTaco can I set up a local pick up.? I sent you a txt a few days ago. never got a reply
  2. Dec 26, 2019 at 4:25 PM
    #222
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Order #3975, thanks for putting this together.
    FreshMexicanTaco[OP] likes this.
  3. Dec 26, 2019 at 4:28 PM
    #223
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    sure thing man! I don’t know how we missed your text, even looking for it now Ím not sure if it’s you or not. Text us again, 6196938907, you could come by right now if you want.
  4. Dec 26, 2019 at 4:29 PM
    #224
    FreshMexicanTaco
    AJ
    San Diego
    Mostly but there’s more on the way. You can still order but it will take couple days before I can ship new orders, most of these took less than 5 days to ship out though...
  5. Dec 26, 2019 at 5:09 PM
    #225
    3rdcoma
    3rdcoma Member
    Northern CA
    2019 Super White Tacoma OR DCSB
    I installed a full front camera kit from anytimebackupcamera.com a few months ago, recently it stopped working. When I hit the switch to view the front camera my display goes completely black. I plugged in another camera and tried again, nothing. Still goes black. Tried a new female RCA cable (in engine bay), new positive cable, new ground cable still nothing. Fuse is good. Can the relay behind the head unit be the issue? Anything else I should/can check before pulling the head unit out? Hope someone can help.
  6. Dec 26, 2019 at 5:33 PM
    #226
    FreshMexicanTaco
    AJ
    San Diego
    This is just a quick overview of what the controller looks like and how it’s installed.
  7. Dec 26, 2019 at 8:23 PM
    #227
    GasPowered
    GasPowered Well-Known Member
    OK
    2016 DCSB TRD OR 4x4 SSM
    Order #3979
    Thank you,
    Cheers
  8. Dec 27, 2019 at 6:43 PM
    #228
    exiquioloza
    exiquioloza Well-Known Member
    Jr
    San Francisco Bay Area
    2019 Toyota Tacoma TRD Sport 4x4
    Has anyone mounted it in the middle of the grill with the garish piece in the front? Did it interfere with tHe sensor?
  9. Dec 27, 2019 at 6:51 PM
    #229
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    @FreshMexicanTaco ordered Monday and received today. Thank you sir! Already installed it too. That Natika camera is so much clearer than the factory Toyota one.
  10. Dec 27, 2019 at 6:58 PM
    #230
    Theclclass
    Theclclass Well-Known Member
    CL
    SoCal
    2018 BLK TRD Sport 4x4 DCSB
    Thanks AJ @FreshMexicanTaco for the install. It was well worth the drive down to Chula Vista. Everything works great with the front/back camera and the DMM. Can’t wait till u guys get your shop going! Good Luck!
  11. Dec 27, 2019 at 7:03 PM
    #231
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    Where did you tap in for the 12v supply? Looks like there are two wires that needs to tap into somethings.
  12. Dec 27, 2019 at 7:30 PM
    #232
    shaggy135
    The side with the yellow plug has a "trigger" wire according to the install sheet. I plugged that into the +12V wire on the Germes Lab connector. Capped the red and black on the camera side. Those won't be used. Everything works like it should.
  13. Dec 27, 2019 at 8:16 PM
    #233
    shaggy135
    I did. No issues yet.
  14. Dec 27, 2019 at 8:28 PM
    #234
    exiquioloza
    Jr
    nice! You got any pictures of what the camera looks like in the middle of the grill?
  15. Dec 27, 2019 at 9:10 PM
    #235
    shaggy135
    Its not perfectly center because on the back of the grill where the sensor mounts, the frame around it doesn't have enough room for the nut to attach to the camera. So it is ever so slightly to the side.
  16. Dec 27, 2019 at 9:15 PM
    #236
    Theclclass
    CL
    SoCal
    exiquioloza and spilledmilk like this.
  17. Dec 27, 2019 at 9:57 PM
    #237
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
  18. Dec 28, 2019 at 7:36 AM
    #238
    FreshMexicanTaco
    AJ
    San Diego
    I have mine installed like that, again it’s just a little off to the side but works perfect, no radar issues.
  19. Dec 28, 2019 at 7:38 AM
    #239
    FreshMexicanTaco
    AJ
    San Diego
    The controller has a 12v output for the camera to connect to.
  20. Dec 28, 2019 at 8:02 AM
    #240
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Received yesterday installing now:dancingbacon:
