TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. Dec 28, 2019 at 9:01 AM
    #241
    PinoyTaco27
    PinoyTaco27 Well-Known Member
    East Stroudsburg, PA
    2018 TRD Sport Double Cab
    @FreshMexicanTaco Mine just arrived! Can’t wait to get it installed. Pairing with Natika camera.
  2. Dec 28, 2019 at 10:35 AM
    #242
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    it looks like the shim has a single hole going through it which goes over the post of the camera, how are you all installing the shim later when needed, are you loosening the nut, cutting the shim and sliding it in then retightening the nut?
  3. Dec 28, 2019 at 10:41 AM
    #243
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    So I got my kit and installed it. I have the manual transmission and it shows the front camera when you go from reverse to 1st gear..
    Kit was easy to install and everything works as advertised.
    I got the Natika camera, threw the instructions away. Can someone tell me what wires to cut to make the guidelines disappear and to flip the camera picture?
    corgimas and RallySOP like this.
  4. Dec 28, 2019 at 10:44 AM
    #244
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I can post instruction pics when I get home. Great camera.
    Ulfr[QUOTED] likes this.
  5. Dec 28, 2019 at 11:55 AM
    #245
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @FreshMexicanTaco
    I need some help here. This is the camera I ordered and am in the middle of installing it. I have the harness from the kit plugged in ,camera mounted and av cable routed to the head unit. I am stuck at what wires I need to connect together to power the camera since the video and the instructions kinda leave that out.
  6. Dec 28, 2019 at 12:29 PM
    #246
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Instructions are on the Amazon page, scroll down to "Product Description" or look at the 4th picture:
    https://www.amazon.com/gp/product/B07H852D49/
  7. Dec 28, 2019 at 1:36 PM
    #247
    Ulfr
    Tampa, FL
  8. Dec 28, 2019 at 4:14 PM
    #248
    RushT
    North Texas
    Good thing I took my time. TW saved me the trouble. :)
  9. Dec 28, 2019 at 4:29 PM
    #249
    RallySOP
    RallySOP Well-Known Member
    Tom
    2018 Tacoma OR DCSB
    Thank you! I appreciate the info. I bought the module either way, and will hopefully get it installed one day. It’s nice to know this works that way.
  10. Dec 28, 2019 at 5:08 PM
    #250
    M1Awolf
    Rob
    Montana
    A shout out to @FreshMexicanTaco Thanks for the call,it got me squared away, big +1 for customer service.
    FreshMexicanTaco[OP] likes this.
  11. Dec 28, 2019 at 5:16 PM
    #251
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    Happy to help!
  12. Dec 28, 2019 at 5:32 PM
    #252
    whatarush
    whatarush Active Member
    Missouri
    2015 Blue Tacoma DCLB TRD Sport
    @FreshMexicanTaco I got it installed on my 15 today and all is good. Thanks for setting up the group buy.
  13. Dec 28, 2019 at 6:11 PM
    #253
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    Order #3988
  14. Dec 29, 2019 at 6:49 AM
    #254
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    So I've noticed that a bunch of these cameras require loops to be cut for front use. The directions say to make sure to ground one side of the cut loop in order for it to work. Where is everyone grounding their cut wires?
  15. Dec 29, 2019 at 8:19 AM
    #255
    mlr69
    South Carolina
    My Natika (WD011) camera instructions don't say anything about grounding the cut loops. What camera did you get?
  16. Dec 29, 2019 at 11:54 PM
    #256
    tpp4
    Memphis
    2018 DCSB SR
    I haven't yet. I was thinking about either the square natika camera on a hinge plate or a side mirror camera I found by raayoo. I have an SR, so there are quite large gaps for me to mount the camera. I am not too fond of drilling a hole in my grill, coupled with the difficulty of getting the angle correct, so I'm just going to secure it with some 3M double-sided tape.
  17. Dec 30, 2019 at 8:33 AM
    #257
    Dswieca
    Dswieca Well-Known Member
    Dan
    2017 Quicksand Limited
    None yet..
    When does the refund happen?
    corgimas likes this.
  18. Dec 30, 2019 at 9:00 AM
    #258
    mlr69
    South Carolina
    Post #1 says January 10th.
  19. Dec 30, 2019 at 1:35 PM
    #259
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    installed mine today, all went well and works excellent....
  20. Dec 30, 2019 at 3:25 PM
    #260
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Loving mine thanks again op!!!
