TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. Jan 12, 2020 at 4:33 PM
    #361
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    @FreshMexicanTaco
    What’s the plan with usps? Do you have another you could send out?
  2. Jan 12, 2020 at 6:12 PM
    #362
    GasPowered
    GasPowered Well-Known Member
    OK
    2016 DCSB TRD OR 4x4 SSM
    I used the Natika camera.
    The two wires from the camera end are not used.
    The red wire by the RCA plug is connected to the red 12+ wire on the module harness. That's it.
    Cheers
  3. Jan 12, 2020 at 6:14 PM
    #363
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Thanks mate, just what I needed to know. Can't wait till the camera gets here.
    GasPowered[QUOTED] likes this.
  4. Jan 13, 2020 at 8:53 AM
    #364
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    If anyone is wondering if you need to trim part of the grill near the TSS to get the camera to center, you do not need to cut it.
    I have mine right next to the area where people are trimming, but it could've gone even more away from it, for the camera to truly center on-screen (it's off by a few mm)
    I hope these pictures will explain better than I did...
    Nakita camera with medium shim
    JIMMEISTER, THE_KiRRAx and DSRamsey13 like this.
  5. Jan 13, 2020 at 2:00 PM
    #365
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
  6. Jan 13, 2020 at 3:11 PM
    #366
    Twister
    Twister Well-Known Member
    CJ
    #BBN , KY
    22 Lariat
    Yeah I saw some just wad up the long red/black wiring from the camera end and zip tie and tuck away. I just cut that crap completely off and tossed it.
    jamesfishn09 likes this.
  7. Jan 13, 2020 at 3:19 PM
    #367
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  8. Jan 14, 2020 at 9:26 AM
    #368
    JEM1BLK2019
    JEM1BLK2019 Truck doing truck stuff......
    2019 Sport 4DR Shortbed..
    Still putting all the pieces together..
    Got mine!! Thank you!!!
  9. Jan 14, 2020 at 1:50 PM
    #369
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I installed all of the HU harnesses and confirmed that it will work on my 2018 Tundra since i do have an entune HU. I have not ran the front camera or hooked it up however it will switch over when the hold button is double tapped. When pressing the down button it will kick on the factory rear camera. I would consider this a partial install, but confirmed basic function.
    What i am curious about is that there are (2) RCA plugs on the kit harness. The factory rear camera does not use the kit harness, so does that mean i can run (3) cameras total?
    Ulfr[QUOTED] likes this.
  10. Jan 14, 2020 at 3:30 PM
    #370
    JIMMEISTER
    JIMMEISTER LIFTd Customs
    Hawaii
    2018 Tacoma DCLB TRD 4X4 OR
    For those that are using the Natika front camera, which shim did you guys use to get the front bumper just in view of the camera?
    Thanks!
    THE_KiRRAx likes this.
  11. Jan 14, 2020 at 3:45 PM
    #371
    jamesfishn09
    jamesfishn09 Well-Known Member
    2003 Tundra
    I used largest and smallest, that is with Pro Grill
    JIMMEISTER[QUOTED] likes this.
  12. Jan 14, 2020 at 9:31 PM
    #372
    Snowboards
    Snowboards Active Member
    2018 Tacoma TRD OR Tech
    Kings Adjustable Reservoir - 2.5 front and rear SCS Ray 10 265/75/16 - Cooper AT3 Icon progressive AAL Meso- ECT Shifter, Gas Hole Anytime Front and Rear Camera Relentless Fab- Tslot mounts for shovel and farm jack.
    @JIMMEISTER I have the pro grille and put it in the dead center if the grille with the TSS system. Mounted great and did not use a shim. The front bumper is barely in view.
    JIMMEISTER likes this.
  13. Jan 15, 2020 at 2:30 PM
    #373
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Hey @FreshMexicanTaco you missed my Order for the Groupbuy Post#307 ordered Jan 4th.
    FYI @bonifacio is in the same boat as me post#304
  14. Jan 15, 2020 at 7:30 PM
    #374
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    1/4.
    Also messaged @FreshMexicanTaco, no response.
  15. Jan 16, 2020 at 2:56 AM
    #375
    Dryvah
    MA
    2019 Tacoma TRD
    Mine apparently was lost By the shipper. No response from the freshmexicantaco.
    Hmm. Hope everything is ok. Also have not heard from him in regards in my lost order.
  16. Jan 16, 2020 at 11:33 AM
    #376
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    We have been very busy but I’m going through pms right now, I will take care of all of you, both the refunds and the missing cam.
  17. Jan 16, 2020 at 11:50 AM
    #377
    bonifacio
    Central PA
    Thank you!
    Everything has been resolved.
  18. Jan 16, 2020 at 12:44 PM
    #378
    bonifacio
    Central PA
    Which shim did you use?
  19. Jan 16, 2020 at 12:47 PM
    #379
    S2KON2
    So Cal (SFV)
    The medium one.
  20. Jan 16, 2020 at 3:20 PM
    #380
    bonifacio
    Central PA
    So basically with the Nakita, cut the green for no parking lines and the white since it's going in the front?
    Just triple checking because I get cut happy.
