TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. Apr 6, 2020 at 1:25 PM
    #441
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    I’ve wanted another front camera for a while but bought a previous version from a member that required some soldering of diodes for switches and grounding of some wires behind the head unit. Within the first week, the truck blew fuses and I ran into systems shutting down etc. So i uninstalled it, replaced fuses and 30k miles later no issues, so I think I’m ready to try another option. I like that this doesn’t have any switches to deal with. Does it require any wires to be grounded behind the dash or any where else? Also, if I’m reading correctly, the front camera activates every time after putting the car into drive? Then it goes off at 30 sec or after 30mph? If we have a manual, does that mean everytime I start my truck and put it in gear it will turn the camera on? I’d really prefer that the front camera never turns on unless I switch it on, is that possible with this kit?
  2. Apr 6, 2020 at 1:36 PM
    #442
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    An MT guy would have to chime it to answer your questions, but for us AT... the front camera only comes on automatically when it comes out of Reverse. So going from Park to Drive, camera doesn't come on automatically.
    FreshMexicanTaco[OP] likes this.
  3. Apr 6, 2020 at 2:10 PM
    #443
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    After thinking about this a bit more...
    When driving WITHOUT your trailer connected you may have a period of "blank screen" when going from reverse to forward, due to the auto-switching to a non-existent camera in that scenario. Possibly you could avoid that situation by also installing a front camera, and then manually plugging the front cam into the RCA connector (and 12vdc power) when you unhitch your trailer. You would need to wire a video extension cable from behind your HU to a convenient location to make physically swapping the camera cables feasible.
  4. Apr 6, 2020 at 2:51 PM
    #444
    Hawks4life
    Hawks4life Well-Known Member
    Joe
    25 Tacoma Pro
    Full PPF, tinted windows, hood struts, hitch pod reverse light.
    I have a question, I installed mine the same way. Went in easy but only issue I have is the picture on front cam is mirrored. its right side up but what is on left of truck is on right on the cam. Any help??
  5. Apr 6, 2020 at 2:58 PM
    #445
    DSRamsey13
    DryWaterSildeGuy and Bastek like this.
  6. Apr 6, 2020 at 3:20 PM
    #446
    Hawks4life
    Joe
    25 Tacoma Pro
    thanks, I just cut the white and all is good.
    DSRamsey13[QUOTED] likes this.
  7. Apr 6, 2020 at 3:57 PM
    #447
    DSRamsey13
    Cut the GREEN too, if you don’t want those lines.
  8. Apr 6, 2020 at 4:06 PM
    #448
    siniquezu
    siniquezu Well-Known Member
    I have the anytime front camera with the separate button installed. Can I use this for the steering wheel control option?
  9. Apr 6, 2020 at 5:31 PM
    #449
    DSRamsey13
    You can reuse the camera, yes. You will lose button functionality, but gain steering wheel control option.
  10. Apr 6, 2020 at 9:02 PM
    #450
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    the controller also has an additional input in case you don’t have a factory backup camera, I haven’t tried but it may be possible to connect three cameras to the system... I’ll test it.
  11. Apr 8, 2020 at 6:30 AM
    #451
    siniquezu
    Gonna try this
  12. Apr 8, 2020 at 6:41 AM
    #452
    IMXPLRN
    IMXPLRN Well-Known Member
    Folsom, CA
    2003 Prerunner
    The more I think about this, the more it might not be what I'm after.
    I would want my regular back up cam to function as normal and the secondary one to only function from a push switch.
    DES2009[QUOTED] likes this.
  13. Apr 12, 2020 at 5:58 PM
    #453
    murfysflaw
    murfysflaw Member
    Patrick
    Just ordered mine along with the DMM kit. Looking forward to installing this one in particular!
  14. Apr 12, 2020 at 7:24 PM
    #454
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    Just installed today, fantastic product.
    Inferno__Taco likes this.
  15. Apr 12, 2020 at 8:56 PM
    #455
    Heffe
    Heffe New Member
    Saint Petersburg, FL
    2018 White Tacoma TRD Pro
    When did you order it? Showing sold out every time I look.
    Also, what's the DMM?
  16. Apr 12, 2020 at 9:01 PM
    #456
    FreshMexicanTaco
    AJ
    San Diego
    This is still available let me check the website...
    UPDATE: I checked the website, it all looks good on my end, you should be able to purchase.
  17. Apr 12, 2020 at 9:03 PM
    #457
    FreshMexicanTaco
    AJ
    San Diego
    2020 version is on the way...
    I’m going to start pre orders as soon as I know when I will have them in my hands.
    hyrule_trd and Inferno__Taco like this.
  18. Apr 13, 2020 at 11:07 AM
    #458
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Yay another thread to follow for something to spend my money on!
    Lucifer1 likes this.
  19. Apr 13, 2020 at 11:28 AM
    #459
    DSRamsey13
    #TWLife
    hyrule_trd[QUOTED] likes this.
  20. Apr 13, 2020 at 11:44 AM
    #460
    murfysflaw
    murfysflaw Member
    Patrick
    Probably already posted somewhere, but has anyone mounted the camera on the "chickenwire" grill? If so, mind sharing a pic?
