TACO GARAGE - Any camera - anytime, plug and play, steering wheel controlled. 2020!
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 6, 2019.
  1. May 31, 2020 at 10:46 AM
    #761
    jarbarian
    jarbarian Brian
    Brian
    Winter Garden
    2020 Tacoma TRD Sport 4x4
    Mudguards, 3D tailgate lettering, step bumpers, MESO LED tail lights, front facing camera. Coming soon: LED headlights and SuperCharger.
    Wow that is an out of this world grill. Did you see mine? I was thinking below my logo, no?
    CttAznRanger[QUOTED] likes this.
  2. May 31, 2020 at 11:32 AM
    #762
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    The cameras people are linking are no longer available. Does anyone have a recommendation for a pro grill or at least what specs to look for. Thx~
  3. May 31, 2020 at 12:45 PM
    #763
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Does the one gap above the logo not have enough space to put anything? If not, then yes I would put it below it.
  4. May 31, 2020 at 12:50 PM
    #764
    CttAznRanger
    Brandon
    Boston, MA
    Is the first one at the bottom of the page not available? That one is pretty much the one I have.
  5. May 31, 2020 at 2:14 PM
    #765
    Bakersman
    Bakersman Member
    Black 2019 Tacoma pro
    Taco Garage kit has a lip mount camera that people are using, I'm putting mine right smack dab in the middle of the pro grill as post #685 has
  6. May 31, 2020 at 2:21 PM
    #766
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
  7. May 31, 2020 at 3:13 PM
    #767
    Sunsetsearider
    San Francisco
    Thanks. The other links to that one didn’t work anymore.
  8. May 31, 2020 at 4:19 PM
    #768
    jarbarian
    jarbarian Brian
    Brian
    Winter Garden
    I bought that exact camera!
    Do I need the RCA if I already bought the front camera equipment? Gar something err another. One of the higher recommended ones that uses the steering wheel controls rather than external switches.
  9. May 31, 2020 at 5:02 PM
    #769
    THE_KiRRAx
    Tampa, Florida
    I originally bought it as a full kit (the camera & rca cable bundled) but the links to the natika bundles seem to be dead. You will still need the natika rca cable with this module, regardless, it's just a separate purchase now unless you find a different bundle somewhere.
    Not a Taco Garage or camera solutions issue, just a Natika or Amazon hiccup. But yes, that rca cable is required for the camera, it has a special quick connection close to the camera as well as the rca and trigger wires that you connect to the switching module.
  10. May 31, 2020 at 7:06 PM
    #770
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So not an expert here but the Amazon Q&A I believe has a reply about the natika accessories being available 6/10?
    No idea what that means really. Figured I’d check back since that’s soon.
  11. May 31, 2020 at 7:54 PM
    #771
    THE_KiRRAx
    Tampa, Florida
    They may be talking about the rca cable, angle shims, adhesive backing, etc. in regards to "accessories". If you could wait until after the date Natika stated, I would try, just to see if you can then purchase the full camera package to get everything you should. Just my opinion.
  12. May 31, 2020 at 8:03 PM
    #772
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Open your hood and look under the sensor, there are two screws holes meant for a bracket to hold the oem camera. The OP is designing a bracket to hold a camera I believe...
    Or look at post #556 & 558
  13. Jun 1, 2020 at 5:12 AM
    #773
    jarbarian
    jarbarian Brian
    Brian
    Winter Garden
    I did check 556 and 558. However in my case I have the Natika camera, not a bullet camera. So I could either drill under the LOGO on the front grill OR I can make my own bracket. I'm a pretty handy mechanic so I can whip something up. I don't intend to sell the truck so I really don't see an issue drilling the grill. I can always replace if it I have to :)
    mosccat[QUOTED] likes this.
  14. Jun 1, 2020 at 9:53 AM
    #774
    mosccat
    Mark
    2020 OR
    Can you link the camera?
    EDIT: I see a link above....
  15. Jun 1, 2020 at 10:07 AM
    #775
    mosccat
    Mark
    2020 OR
    I’ll be using that style of camera but was planning to mount it so the shaft is horizontal, utilising the oem Bracket design.
    Be interested to see where end up going...
  16. Jun 1, 2020 at 10:16 AM
    #776
    THE_KiRRAx
    Tampa, Florida
    If you're referring to the Natika WD-011 camera and mounting it with the post horizontally on a 2020 grill with the OEM style bracket take some cautions as [I THOUGHT] the bracket is angled to give a downward viewing angle. This already angled in view along with the design of the camera might bring the POV too close back towards the grill. You might want to look into straightening it back out. Just a bit of caution to consider.
    If this isn't what you're referencing then please ignore my useless nonsensical rambling and let me blame it on being a Monday....DAMN MONDAYS.
  17. Jun 1, 2020 at 10:20 AM
    #777
    mosccat
    Mark
    2020 OR
    Thanks! So using these shims would correct that?
  18. Jun 1, 2020 at 10:23 AM
    #778
    THE_KiRRAx
    Tampa, Florida
    You would most likely need to use the shims for sure, just can't comment on if it'll fully correct it or not, but definitely worth a shot. Also note the hole size in the OEM bracket versus the hole size needed for the camera shaft, might need to fab up a little adapter filler plate to shrink that hole down and keep the camera from wobbling.
    Again, I am just speculating as I don't have the 2020 grill with bracket, just going off the fact the hole looks large in that bracket. Just trying to get some gears turning to take these things into account, good luck on it mate. I wanna see how it all comes together as well.
  19. Jun 1, 2020 at 10:27 AM
    #779
    mosccat
    Mark
    2020 OR
    the op on here is designing a bracket for the camera system he sells so I might not have to design anything. I was going to make my own bracket as I’m sure the oem bracket is $1M...
    THE_KiRRAx[QUOTED] likes this.
  20. Jun 1, 2020 at 11:07 AM
    #780
    jarbarian
    jarbarian Brian
    Brian
    Winter Garden
    Where are these shims and the OEM bracket?!
