TACO GARAGE - Dashtop Multi Mount (DMM) CLEAN and SOLID Tacoma accessory mounting
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Aug 30, 2018.
  1. Feb 7, 2022 at 12:23 PM
    #1281
    mrbee2828
    mrbee2828 Well-Known Member
    BJ
    Virginia Beach
    FYI, the mighty magnet will not hold up an iPhone 13 with the magsafe backing or a magsafe case. You have to have the metal plate inside the case or on the back of the phone. This renders the wireless charging useless. It's not a deal-breaker for me as the Carplay requires the cable but just letting everyone know.
  2. Feb 7, 2022 at 12:26 PM
    #1282
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Which flavor of iPhone 13 do you have? (mini, regular, Pro, Pro Max)
  3. Feb 7, 2022 at 12:35 PM
    #1283
    mrbee2828
    BJ
    Virginia Beach
    I have the Pro but I doubt it would hold a mini even without the plate. However, with the plate attached it solid AF lol
  4. Feb 7, 2022 at 1:56 PM
    #1284
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Good to know, I'm about to switch back to Apple and will likely get a regular 13.
  5. Feb 7, 2022 at 6:55 PM
    #1285
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    look a little ways back (post 1239) at my solution for this. Moment makes a great mount for magsafe phones and cases that is easily adapted to the DMM. My 13 Pro Max is very solid on it. I can install and remove the lightning cable while its on the mount without it pulling off, and it handles the light offroading ive done so far without any issue
  6. Feb 10, 2022 at 6:43 PM
    #1286
    R3b3lSon82
    R3b3lSon82 Well-Known Member
    2019 CG TRD OR
    What exactly do I need to order for a RAM mount to ensure I can get it to work with the DMM? Taco Garage makes it easy to see what I need but RAM website doesn't make it easy. Is it just a RAM mount that I can put over the ball mount from TG?
  7. Feb 10, 2022 at 7:26 PM
    #1287
    Absolut_Boost
    Cincinnati, OH
    DMM comes with a 1” ball mount. Any ram or tackform 1” or 25mm mounts should work with it.
  8. Feb 16, 2022 at 1:46 PM
    #1288
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    Our DMM uses 1" ball mount like most other manufacturers so any system that also uses 1" or 25mm ball mounts or arms will be compatible EXCEPT... directly mounted on the DMM plates, the DMM uses 10-32 threads which are not available from any other manufacturer as far as I know so in order to mount something to the DMM you need at least the ball mount from us and then you can attach any other arms or holders that are 1" compatible.
  9. Feb 16, 2022 at 2:42 PM
    #1289
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Just order this part and replace the screw with a 10/32 screw the correct length. https://www.rammount.com/part/RAM-B-367U
  10. Feb 16, 2022 at 3:00 PM
    #1290
    FreshMexicanTaco
    AJ
    San Diego
    We made some small changes to the latest aluminum arm design, here is what we have now, very similar but a bit better looking and slightly improved functionality. I feel weird saying it works better because you wouldn't necessarily think that there's much to these but there is, we improved on articulation, aesthetics, finish, grip, ease of use, ergonomics and manufacturing costs... let us know what you guys think....
    Most Arms on the market vs Taco Garage Arms
    ponts likes this.
  11. Feb 16, 2022 at 3:03 PM
    #1291
    FreshMexicanTaco
    AJ
    San Diego
    That wont necesarily work, the center hole on those balls is too large for a 10-32 screw. Adding a bushing would fix that, we used to do it in the early stages of the DMM but its not ideal... That's one of the reasons we started making out own ball mounts. @R3b3lSon82
    ODSC1[QUOTED] and R3b3lSon82 like this.
  12. Feb 18, 2022 at 6:32 AM
    #1292
    Pyrotech
    Pyrotech Well-Known Member
    oostroma likes this.
  13. Feb 21, 2022 at 12:03 PM
    #1293
    wally11
    wally11 Well-Known Member
    Mark
    2017 Black DCSB
    Will these work with the Quadlock Ball mounts? I would scrap the arm. I have the DMM installed and was thinking of getting into their system. The DMM mount is 1" and it seems there balls are 22mm. Not sure if that is too much of discrepancy. Thanks
  14. Feb 21, 2022 at 12:20 PM
    #1294
    FreshMexicanTaco
    AJ
    San Diego
    The quadlock system's standard balls are 22mm but they do sell a 1" adapter... https://www.quadlockcase.com/products/1-ball-mount-motorcycle-kit-universal-fit?variant=814115094544 if for example you have a quadlock case already all you need is the adapter and then you can use our arms and DMM
  15. Feb 21, 2022 at 12:27 PM
    #1295
    wally11
    Mark
    2017 Black DCSB
  16. Feb 21, 2022 at 4:07 PM
    #1296
    FreshMexicanTaco
    AJ
    San Diego
  17. Feb 21, 2022 at 4:08 PM
    #1297
    FreshMexicanTaco
    AJ
    San Diego
    Sooooooo…..
    I had some 20mm balls in the shop, and I tried the arms on them, they held really well!
    I’m not saying our arms will work on 22mm just yet but it looks like it…
    wally11[QUOTED] likes this.
  18. Feb 22, 2022 at 2:45 PM
    #1298
    FreshMexicanTaco
    AJ
    San Diego
    DMM's are slightly back ordered, we are expecting them to start shipping out by the end of the week (2/26) but no later than tuesday (3/2) so from now until further notice, DMMs and accesories are on sale for 20% OFF using code DMMBO at checkout, minimum $30 purchase.
    IssaGreenTaco and CttAznRanger like this.
  19. Feb 22, 2022 at 3:28 PM
    #1299
    eurowner
    eurowner Duke Sky
    Scoty
    Order #13830 :thumbsup::burnrubber::cheers::drunk::headbang::taco::taco:
  20. Feb 22, 2022 at 3:50 PM
    #1300
    Pyrotech
    The much awaited mic mount arrived today... I of course wasted no time in resetting the DMM to make room for the new additon.
    This will make the next group trail ride a bit more enjoyable by having the GMRS mic up an out of the way.
    FreshMexicanTaco[OP] likes this.
