Taco Garage - Dashtop Multi-Mount (DMM) - Securely mount ANYTHING to your dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jun 10, 2018.
  1. Jun 11, 2018 at 12:01 PM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    Thank you sir! I have received your payment and I really do appreciate you doing that for me!
  2. Jun 11, 2018 at 12:01 PM
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2016 DCSB TRD O/R 4X4
    We handled this via PM before this thread was started. Thanks.
    Vanderjdm and atlsmedic like this.
  3. Jun 11, 2018 at 12:04 PM
    FreshMexicanTaco
    AJ
    San Diego
    I will have that instructions url up and running as soon as I can, but yes there’s a little bit of easy work including drilling that has to be done. Nothing hard, nothing major, but most importantly nothing that will be visible. The DMM remains out of sight as long as you don’t bolt anything to it.
    abaxter41 likes this.
  4. Jun 11, 2018 at 12:23 PM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Ditto
    FreshMexicanTaco[OP] likes this.
  5. Jun 11, 2018 at 12:25 PM
    perkj
    perkj Well-Known Member
    @FreshMexicanTaco how do the Ram balls mount to the DMM? Are the holes on the DMM threaded to where the Ram ball simply screws in? From the picture is doesn't appear the DMM holes are threaded which is why I'm asking. If not threaded do you have to drill a hole for each of the DMM holes?
  6. Jun 11, 2018 at 1:12 PM
    FreshMexicanTaco
    AJ
    San Diego
    The Ram mount does bolt into the DMM, the holes DO have threads and yes you need to drill a hole for each one of the holes unless you know that you are only going to use 1 of the holes in which case you only drill that one and the anchor holes, which hold the top and bottom plates together. Its easier to understand with pictures I know, sorry, I will have that installation page running pretty soon.
    Also for practical purposes that I can explain in detail later, the holes and threads are 10-32 which is not a standard RAM bolt so you have to use a RAM ball with a trough hole and bolt it down with a 10-32 screw (which I am including with all purchases)
  7. Jun 11, 2018 at 1:17 PM
    FreshMexicanTaco
    AJ
    San Diego
    ORDER List
    Shipping on 06/16/2018
    1. VroomVroom
    2. abaxter41
    3. moostache
    4. Bubbles
    5. Double Phister
    6. synaps3
    7. fgeorge097
    8. eabrooke
    9.
    10.
    11.
    12.
    13.
    Bubbles likes this.
  8. Jun 11, 2018 at 1:26 PM
    perkj
    @FreshMexicanTaco Thanks for the reply. I'm not wanting to drill holes for each of the hole in the DDM for Ram ball mounts. Why do holes need to be drilled if the DMM itself are threaded? Is it because of the thickness of the DMM itself not being thick enough? A couple of the other examples folks have made for this idea had the plate itself thick enough to accept the Ram ball mounts that are 0.25" in length.
  9. Jun 11, 2018 at 5:44 PM
    FreshMexicanTaco
    AJ
    San Diego
    The threaded part is underneath the dash that’s why you need a hole, I could make the plate thick and thread it but then it really doesn’t look as good, plus, without drilling the holes you don’t get such a structurally sound assembly. Accessories would vibrate a lot more and the vibration can eventually be cause for even worse damage. Kind of like when tall buildings are constructed, you need a deep foundation for the building to stay upright. My mount is VERY strong. Whatever is mounted on it will sit pretty still. The top and bottom plates spread out the load pretty evenly they way they are set up. Having something heavy connected to something that thick, that just sits on top of that dash is not very sturdy. And it’s kind of an eye sore if you ask me. My mount is invisible unless you want to make use of it.
    Again pictures are worth a million words so keep an eye out, I’ll have them up soon
  10. Jun 11, 2018 at 7:49 PM
    x2GENx
    x2GENx Well-Known Member
    18' DCSB OR 4x4
    ORDER List
    1. VroomVroom
    2. abaxter41
    3. moostache
    4. Bubbles
    5. Double Phister
    6. synaps3
    7. fgeorge097
    8. eabrooke
    9.x2GENx
    10.
    11.
    12.
    13.
    Payment sent
  11. Jun 11, 2018 at 8:23 PM
    RedEmpire
    RedEmpire Well-Known Member
    Southern Pines, NC
    2017 MGM Tacoma DCLB 4X4
    ORDER List Shipping on 06/16/2018
    1. VroomVroom
    2. abaxter41
    3. moostache
    4. Bubbles
    5. Double Phister
    6. synaps3
    7. fgeorge097
    8. eabrooke
    9. x2GENx
    10. RedEmpire
  12. Jun 11, 2018 at 9:02 PM
    perkj
    11. perkj
    12.
    13.
  13. Jun 11, 2018 at 9:29 PM
    FreshMexicanTaco
    AJ
    San Diego
    One member is going to drop out for now so you are going to move up to 10. I’ll do that and update the list.
  14. Jun 11, 2018 at 9:41 PM
    perkj
    Payment sent
  15. Jun 11, 2018 at 9:45 PM
    #35
    FreshMexicanTaco
    AJ
    San Diego
    And received! Thank you!:cheers:
  16. Jun 11, 2018 at 9:49 PM
    #36
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    Any love for the 5th gen 4runner?
  17. Jun 11, 2018 at 10:12 PM
    #37
    buyakkaa
    buyakkaa Active Member
    SoCAL
    2018 Tacoma TRD OR MGM
    Great mount! I would have to say OP hooked it up. Very clean and flush.
    Drilling and minor modification, of course, is needed. But for the structural stability, it’s expected. (If you do not know how to use a power tool or too afraid to drill a few holes holes, this is not for you)
    I originally was looking for something to mount my phone to, and I’ve tried all other solutions (cd insert magnet; double sided 3m magnet mount; vent mounts), they all failed. So I have to give it up him for coming up with this solution.
    I just ordered the attachment mount for the ram ball off Amazon, so I’m excited to get that in. Even without any other attachments, it looks great! Legit&discreet.
    Thanks again OP!
    0D4F7FAA-EE0D-46B6-8A2A-E61817DA2A0C.jpg 565BDDAD-86BA-4E38-873B-1A13FABE28EF.jpg
  18. Jun 11, 2018 at 11:09 PM
    #38
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Might be in for future production runs
  19. Jun 12, 2018 at 8:10 AM
    #39
    Ghser7
    Ghser7 Well-Known Member
    Bonaire, GA
    '16 BlazingBluePearl 4x4 OR DCSB
    Which date should I put my name on? 23rd?
  20. Jun 12, 2018 at 9:47 AM
    #40
    FreshMexicanTaco
    AJ
    San Diego
    I'll add you in just a minute I have to edit the first list.
    Ghser7[QUOTED] likes this.
