Taco Garage - Dashtop Multi-Mount (DMM) - Securely mount ANYTHING to your dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jun 10, 2018.
  1. Oct 15, 2018 at 2:00 AM
    #441
    hcenteno21
    hcenteno21 Well-Known Member
    Tito
    El Paso, TX
    2020 AG Tacoma TRD Pro Supercharged
    Thank you, I received them!
  2. Oct 15, 2018 at 12:37 PM
    #442
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    All of your orders have shipped now, you should have received an email with tracking info, they should all deliver by the end of the week at the latest depending on destination.
    Enjoy!
  3. Oct 15, 2018 at 12:49 PM
    #443
    FreshMexicanTaco
    AJ
    San Diego
    Thanks for that man I appreciate that! That's a bad @$$ rig BTW. :cheers:
    Papadave418[QUOTED] likes this.
  4. Oct 15, 2018 at 1:14 PM
    #444
    Zrouge1
    Zrouge1 Well-Known Member
    Sold
    What is the weight limit, could I mount 3 - 5 lbs of electronics at one time on the dash top mount?
    Thanks,
  5. Oct 15, 2018 at 2:25 PM
    #445
    FreshMexicanTaco
    AJ
    San Diego
    I haven’t done any destructive testing to find the real limit, however the DMM is more than strong enough to hold 5 lbs. the weak point in this system is actually the way Toyota attaches the trim to the vehicle.
    I wouldn’t do 5 pounds while off reading.
    For regular street driving I think 5lbs would be ok as long as you don’t use super long arms because torque multiplication.
    I would do incremental tests before slapping 5lbs.
    tonered likes this.
  6. Oct 15, 2018 at 3:41 PM
    #446
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I finally got mine and haven’t installed it yet, was just putting together the phone mount. It says made for small tablets, but I can’t seem to fit my iPhone XS Max in it. Am I putting it together wrong?
    I got two sets of arms.
    Order 529
  7. Oct 15, 2018 at 4:53 PM
    #447
    FreshMexicanTaco
    AJ
    San Diego
    Yeah you might be doing something wrong. I know it definitely fits the xs max and even bigger phones. I used to have a 7 plus which is basically the same height...
    I don’t think you even need to use the long legs for that but did you?
    The mount stretches in one direction, it is spring loaded...
  8. Oct 15, 2018 at 6:48 PM
    #448
    whitedlite
    USA!
    3RD Gen TRD 4WD
    The problem is the phone is too tall for the mount vertical and not wide enough for the phone horizontal.
    Also What do you mean mount stretches. Are you talking about the arms or the backing plate?
  9. Oct 15, 2018 at 6:56 PM
    #449
    whitedlite
    USA!
    3RD Gen TRD 4WD
    doublethebass and tonered like this.
  10. Oct 15, 2018 at 7:10 PM
    #450
    FreshMexicanTaco
    AJ
    San Diego
    No worries man it happens to the best of us. I’m just glad you figured it out.
    Show us some pictures!
  11. Oct 17, 2018 at 3:12 PM
    #451
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    Don't feel bad, I did the same thing, I was ready to take a pic and send it to AJ. then all of a sudden I moved it just right and WOW it fit LOL.
    Everything looks Great, can't wait for the weekend to install it.
  12. Oct 18, 2018 at 5:05 PM
    #452
    2ayne
    2ayne Well-Known Member
    Zayne
    Ohio
    2017 Cement TRD Pro
    Received mine yesterday and installed today. Install was super easy. Just takes a little common sense.
    I’m super happy with it. Clean finish, very sturdy for my phone and full size iPad. Can’t go wrong with this thing for the price especially compared to competitors that are asking $160 for similar products or something that limits the direction you can move your air vents. 5 stars! Thanks!
    pop.tremuloides and tonered like this.
  13. Oct 18, 2018 at 5:05 PM
    #453
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A minor mod to the mod. This summer I saw the bushings reflect in the windshield on one or two occasions. Definitely minor and also keeping in the blackout tradition, I painted the base and bore of the RAM balls and the bushings:
  14. Oct 18, 2018 at 8:32 PM
    #454
    cockdiesel
    cockdiesel Member
    Scott
    2016 Taco DCSB TRD sporticus
    Just took order @ #624 of the fantabulous product. Thank you for a solution to problem that plagues us and making it affordable! You are a true Mexi"CAN" Taco hero!:thumbsup:
  15. Oct 19, 2018 at 1:17 PM
    #455
    hcenteno21
    Tito
    El Paso, TX
    Just mounted mine. I used a 3/16" drill bit. Worked great. Looking for a better mount for ipad!
  16. Oct 19, 2018 at 1:21 PM
    #456
    hcenteno21
    Tito
    El Paso, TX
    Just had to.
  17. Oct 20, 2018 at 12:03 PM
    #457
    dozer711
    Upstate, NY
    Just finished the install,20181020_145853.jpg piece of cake, went together great.
  18. Oct 20, 2018 at 3:37 PM
    #458
    hcenteno21
    Tito
    El Paso, TX
    Anyone having issues with their ball moving around? I tightened the ball, but it still slides around. Any way to solve this?
    Maybe some sort of rubber washer? @FreshMexicanTaco
  19. Oct 20, 2018 at 3:45 PM
    #459
    hcenteno21
    Tito
    El Paso, TX
    Also FWIW I like the arkon phone holder better than the ram. Easier to work, and I personally thing it looks better. Here is a pic of both.
  20. Oct 20, 2018 at 5:41 PM
    #460
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Is the ball rotating or is the arm slipping on the ball? I have experienced neither. You should be able to tighten the ball until it doesn't rotate. If the arm is slipping, tighten it some more?
