Taco Garage - Dashtop Multi-Mount (DMM) - Securely mount ANYTHING to your dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jun 10, 2018.
  1. Jun 6, 2019 at 8:43 PM
    #1121
    2BigTaco
    2BigTaco Well-Known Member
    Eric
    So Cal
    '19 Tacoma TRD OR 4x4 DCSB in Cement
    I dont mind at all.
  2. Jun 7, 2019 at 7:56 AM
    #1122
    Txsrooster
    Txsrooster Well-Known Member
    I just ordered with the 10% off sale going on now, plus the 10% coupon for TW. Heck of a deal.
  3. Jun 7, 2019 at 8:15 AM
    #1123
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    What are y'all using to wire power up to mounts?
  4. Jun 9, 2019 at 8:23 PM
    #1124
    ATXJoshL
    ATXJoshL Well-Known Member
    Josh
    2018 Tacoma TRD Pro Black
    1-1/4” Spacers, Tires: Goodyear Wrangler Duratrac, hard bed cover, Fuelpax custom-mounted on bed rail.
    I bought 2 6ft lightning cables on Amazon. Ran them behind the console, behind the radio and out the DMM. I just plug them in a cigarette charger. Very clean, and I didn't have to do an hardwiring or major console disassembly. While the radio trim is off, just unbolt the radio (4 screws), rest it on the shifter. then I ran a stiff wire from the bottom at the front of the console on the passenger side and curved it up toward the radio. After a few tries, finally got it to come out the radio area. Taped the cables to it and fished it back through.
    Pyrotech likes this.
  5. Jun 10, 2019 at 12:52 PM
    #1125
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    How does this hold up to the weight of a full size iPad and iPhone XR for off road use? On your website, I assume the $42 large tablet holder kit is the one I want for my iPad? Lastly, with a full size iPad, how much is the forward view out the windshield blocked? In my mind, it appears this would block the passenger front corner view. Pics of a full size tablet mounted from the driver's seat would be great if anyone has them. Thanks.
  6. Jun 10, 2019 at 1:27 PM
    #1126
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    See below/here for mine with an iPhone XR, radio, and an iPad Mini 2 (not full size though). View is barely blocked and it does great offroad even on washboard trails. I used a double socket arm for the iPad but they also make double socket swivel arms and double socket arms with extensions that would allow you to extend it further and lower. The longer lever arm you have the more movement and loads you'll see on the iPad though.
    Thorian and Cwopinger[QUOTED] like this.
  7. Jun 10, 2019 at 1:43 PM
    #1127
    Cwopinger
    Blevin
    Florida
    Thanks! I had not seen that iPad mount when I was looking at the available options. I like the way the balls can be mounted off-center on that. That will work for me. Nice write up too.
    pc3coyote[QUOTED] likes this.
  8. Jun 14, 2019 at 4:01 AM
    #1128
    Thorian
    Thorian Well-Known Member
    Marco
    Los Angeles, CA
    2017 4x4 White Tacoma
    Kings 2.5 Front and Rear, Baja Kit UCAs, Dakar Medium Leaf Pack, SSO Slimline Bumper
    I’m looking to order this, but can’t decide between the magnetic or non magnetic kit. Anyone here have both? Any cons for the magnetic? I have an iPhone XS Max. Thanks
  9. Jun 14, 2019 at 5:37 AM
    #1129
    Thorian
    Marco
    Los Angeles, CA
    Well I just ordered the non magnet one, is everyone else using aftermarket mounts (ram)? Is it compatible?
  10. Jun 14, 2019 at 8:58 PM
    #1130
    ATXJoshL
    Josh
    I have both. I use the magnetic one for my iPhone 8, works amazing, I use the low profile mount for my iPad mini. I tried using the iPad mini on the magnet, and it held without a problem, but while you're driving, if it's not perfectly centered, it will slowly vibrate and turn slightly. I think it was is just a little too big for a single magnet, so I stuck to using it on the regular mount. I think with the XS, you would probably be fine with either. I much prefer the magnet if at all possible. It's so quick and easy.
    Thorian[QUOTED] likes this.
  11. Jun 14, 2019 at 9:00 PM
    #1131
    Thorian
    Marco
    Los Angeles, CA
    Dammit! Already went with the non magnet :(
    Thanks for your response though, I messaged freshmexicantaco and got no response...funny his customers were actually more helpful.
  12. Jun 14, 2019 at 9:01 PM
    #1132
    Thorian
    Marco
    Los Angeles, CA
    Shoutout to @Txsrooster for answering my questions
  13. Jun 14, 2019 at 9:04 PM
    #1133
    Thorian
    Marco
    Los Angeles, CA
    So for the magnet you can’t have a case on your phone?
  14. Jun 14, 2019 at 9:26 PM
    #1134
    ATXJoshL
    Josh
    He's usually very responsive, I'm sure he's just busy. I'm sure he'll respond. I talked to him quite a few times on here. If it hasn't shipped yet, I'm sure he'll let you trade it out.
    I have a thin case on mine, and I have the plate mounted to the case on the INSIDE. Sticks great. You can also stick the plate to the outside of the case, which would probably work even better.
  15. Jun 15, 2019 at 5:07 PM
    #1135
    HP11
    HP11 Well-Known Member
    NH
    2019 Cement Tacoma TRD Sport
    Yes you can. Just place the metal strip between the back of your phone and the case. The mag mount will now be magnetically attracted to your phone (through the case). I use this mount with my iPhone X and it works great.
  16. Jun 15, 2019 at 9:37 PM
    #1136
    Thorian
    Marco
    Los Angeles, CA
    Dammit I already ordered non magnet
  17. Jun 17, 2019 at 9:51 PM
    #1137
    Thorian
    Marco
    Los Angeles, CA
    Sooo just got mine in and my backing pieces are pretty bent...some more severe than others. Will this be an issue? 8D1C7065-B604-4FA8-8CD6-57A2121B64A0.jpg5D404136-94DE-4FE2-9BC8-EA71B0DF950E.jpg
  18. Jun 17, 2019 at 9:54 PM
    #1138
    ATXJoshL
    Josh
    No mine were the same way. They work great. The screws suck them up into place.
  19. Jun 17, 2019 at 9:55 PM
    #1139
    Thorian
    Marco
    Los Angeles, CA
    Thanks!
    ATXJoshL[QUOTED] likes this.
  20. Jun 18, 2019 at 2:09 AM
    #1140
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Same. Don't sweat it.
    Thorian likes this.
