TACO GARAGE - NEW A1 Machined billet aluminum Push to Start Buttons, now with blackout ring.
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 22, 2020.
  1. Feb 9, 2021 at 8:51 PM
    #201
    samer312
    samer312 Well-Known Member
    Sam
    Alexandria VA
    2020 Cement TRD OR
    Yours looks like you didn't push it all the way in.
  2. Feb 10, 2021 at 7:27 AM
    #202
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    This is not how its supposed to be, the button does go in more than this, we have to troubleshoot this. there is a chance that some of the plastic could have been scrapped off and is preventing the button from sliding all the way in. try pulling it out and checking for burrs
  3. Feb 10, 2021 at 7:29 AM
    #203
    FreshMexicanTaco
    AJ
    San Diego
    It definitely doesnt look pink, the pictures are deceiving depending on the camera and the screen you're seeing it in. the matte red is actually darker than the machined red.
  4. Feb 10, 2021 at 7:31 AM
    #204
    FreshMexicanTaco
    AJ
    San Diego
    Have you guys emailed us about the wrong button color? did anyone reply to those yet?
  5. Feb 10, 2021 at 7:42 AM
    #205
    barelfly
    barelfly Well-Known Member
    2019 Cavalry Blue Tacoma TRDOR, 2014 Iceberg FJC
    No - I Haven’t emailed. I am happy with the matte - I think the anodized may have been too blingy for my liking. So happy with the “accidental” mistake.
  6. Feb 10, 2021 at 8:35 AM
    #206
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    that scratch definitely looks like damage that happened before anodization. can't believe someone didnt catch that if there is a qc process in place.
    imo that should be replaced
  7. Feb 12, 2021 at 2:22 PM
    #207
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    @FreshMexicanTaco
    I got mine today. Trying to install it on a 2020 4Runner, but not having any luck. I can't get it all the way on. I feel like if I push any harder the whole button assembly will break away from the dash. It seems like it's hanging up on the snap features. Any thoughts?
  8. Feb 12, 2021 at 2:27 PM
    #208
    RoostrC0gburn
    Oregon
    did you compare to the stock button you pulled out?
  9. Feb 12, 2021 at 2:37 PM
    #209
    jowybyo
    Joe
    Baltimore, MD
    Yes, the inside dimensions of the center squarish (squarcle?) section is a little smaller than the stock button. About 0.25mm smaller in one direction and 0.50mm smaller in the other. But it seems like it's mostly the material thickness because the outside dimensions are pretty close. But the button indexes and snaps on the inside of that section.
  10. Feb 12, 2021 at 2:41 PM
    #210
    jowybyo
    Joe
    Baltimore, MD
    It seems like the TacoGarage button stays on with friction as opposed to snaps in the stock button. So maybe it makes sense to be undersized a touch. It kinda seems like the leading edge of the TG button is just hanging up on the stock detents. I'm thinking I can chamfer the leading edge a bit to help it ride home. But wanted to ask before I got grinding stuff up.
  11. Feb 17, 2021 at 11:43 AM
    #211
    FreshMexicanTaco
    AJ
    San Diego
    Hey hows it going, have you had any different luck since?
    Theres a few things that may cause this but one common one we've seen is that if the button is not inserted straight it can cause the plastic on the actual switch to scrape a bit and that in turn causes an extra tight fit. This is easily fixed by removing the button and cleaning any debris or burrs on both the button and the switch.
    Let me know if your still having problems
  12. Feb 17, 2021 at 11:44 AM
    #212
    FreshMexicanTaco
    AJ
    San Diego
    This could also be the case but it would mean that the detents are different than what we tested, the chamfer should help. Let us know how it works.
  13. Feb 26, 2021 at 2:54 PM
    #213
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    @FreshMexicanTaco I have pm'd you on several occasions for an update on my front grille camera bracket. Let me know where we are on that.
  14. Feb 26, 2021 at 5:24 PM
    #214
    TacomaLogic
    TacomaLogic Well-Known Member
    Joshua TX
    2021 Voodoo Blue Taco TRD OR 4x4
    Misc
    Got both in. Silver one fo the Taco and a anodized red one fo my 86. Tacoma one installed with red LED swap.
  15. Mar 8, 2021 at 10:04 AM
    #215
    NewShockerGuy
    NewShockerGuy Member
    Nigel
    DC
    FreshMexicanTaco,
    Are you the one making these or is another company making them? I ask because a bunch of us over at the Lexus group want to have one that is made with the F logo on it... I believe someone is trying to coordinate it but wanted to double check here since it appears the buttons are identical to the ones that people were inquiring about getting custom done. Same colors/shape, 3 holes in the bottom..etc.
    Thanks much,
    -Nigel
  16. Mar 8, 2021 at 7:57 PM
    #216
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I *think* you can test the dead battery thingy by pulling the battery out of your fob. I believe in the dead fob mode the truck energizes the fob with near field transceiver process. I think. :)
    <edit>
    Too far behind on this thread... the fob question has been answered multiple times.
  17. Mar 20, 2021 at 8:53 PM
    #217
    jowybyo
    Joe
    Baltimore, MD
    Just wanted to follow up on this. I used a Dremel to chamfer the leading edge and it slipped right on. :thumbsup:
  18. Apr 1, 2021 at 9:10 AM
    #218
    FreshMexicanTaco
    AJ
    San Diego
    Thank you for pointing that out before too, I'm glad it worked out but in order to avoid any future similar situations we did make some small changes.
    jowybyo[QUOTED] likes this.
  19. Apr 1, 2021 at 9:12 AM
    #219
    FreshMexicanTaco
    AJ
    San Diego
    Hey I know you posted this a while back I just havent been logging in as much as I'd like lately but have you been in touch with anyone about making these? I ask because we have been in talks with some folks from some lexus group(s)
  20. Apr 1, 2021 at 9:14 AM
    #220
    FreshMexicanTaco
    AJ
    San Diego
    Images should be working now!
