TACO GARAGE - NEW A1 Machined billet aluminum Push to Start Buttons, now with blackout ring.
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by FreshMexicanTaco, Dec 22, 2020.
  1. Dec 30, 2020 at 10:10 AM
    Spanky3412
    Spanky3412 Well-Known Member
    Dave
    Northern N.J.
    2020 Cement Offroad
    These look great will be ordering. Was thinking I do paintfill on golf clubs with Testers model paint I'm sure you could do the same on these just fill the letting by using a toothpick and wipe the face clean and let it dry. A lot of colors available.
    Bertw192 likes this.
  2. Dec 30, 2020 at 10:13 AM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    That should be a fairly easy process, some of the grooves are thicker than other so I guess it depends on which button you like but for the TRD for example it would be very easy...
    Spanky3412[QUOTED] and Bertw192 like this.
  3. Dec 30, 2020 at 8:57 PM
    Fullsendcf
    Fullsendcf Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Look legit! On my list for 2021 mods
  4. Jan 5, 2021 at 8:30 AM
    FreshMexicanTaco
    AJ
    San Diego
    We listened and we will be opffering these in anodized black or red finish as well. They should be in stock in about a week, I'll post some pictures
    xxTacocaTxx, BikTko and Notcris like this.
  5. Jan 5, 2021 at 8:31 AM
    FreshMexicanTaco
    AJ
    San Diego
    xxTacocaTxx, Spanky3412 and Bertw192 like this.
  6. Jan 6, 2021 at 12:19 PM
    FreshMexicanTaco
    AJ
    San Diego
  7. Jan 6, 2021 at 1:18 PM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Great job, I LOVE the aluminum in comparison to the plastic!!!! I will be ordering soon:thumbsup:
  8. Jan 6, 2021 at 3:21 PM
    Notcris
    Notcris Well-Known Member
    Cristian
    Georgia
    2021 4runner Lunar Rock Trd Pro 2004 Xtra xab red
    None
    There's no option to purchase it in red.
  9. Jan 6, 2021 at 3:24 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Do these fit the 4runner as well?
  10. Jan 6, 2021 at 3:39 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    See quote above
  11. Jan 6, 2021 at 6:12 PM
    jbehrens5898
    jbehrens5898 Well-Known Member
    Josh
    Huntington Beach, Ca
    2017 Gray TRD Off Road Long Box
    Fox 2.5 w/DSC REM 4.88 Icon Mini Pack OVTuned Caliraised LED's Bakflip MX4 WeatherTech's
    Would it be possible to get it in red without the 3 hole light passthrough? Or have the TRD be cut as the light passthrough? Regardless, these look awesome
  12. Jan 7, 2021 at 7:33 AM
    IMXPLRN
    IMXPLRN Well-Known Member
    Folsom, CA
    2003 Prerunner
    In no way am I trying to talk bad about these, but is there any way to get one of these with a better surface finish on the front than what is shown in the pictures? I've worked in manufacturing my whole life in one way or another, whether it was machining parts or designing machines and in my opinion a nice machined surface looks better.
  13. Jan 7, 2021 at 8:58 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You could easily sand it down. It's raw aluminum, so there's no finish to worry about... Hell, you could buff it to a mirror finish, if that's your deal.
  14. Jan 7, 2021 at 11:24 AM
    IMXPLRN
    Folsom, CA
    2003 Prerunner
    I'm well aware that it can be sanded and polished or whatever, but that wouldn't be a machined surface then.
    A 32-63 Ra machined surface with slight tool path lines would look badass.
  15. Jan 7, 2021 at 12:16 PM
    #35
    FreshMexicanTaco
    AJ
    San Diego
    YES! they actuallly fit any toyota with push start button. We've tested first hand on 4runner, tacoma, rav4, highlander and prius.
    It's possible to remove the 3 holes but its not possible to have the entire TRD be pass through, it is TECHNICALLY possible for it to work the logo would have to be smaller, the light behind it only shines through the very center of the button, it would only light up the R in TRD and a little bit of the T and D.
    That surface is machined, its a curved surface and that might be part of why it looks a bit different than what you're used to, that being said... we will keep it in mind although I have a feeling most people are going to opt for the anodized versions
  16. Jan 7, 2021 at 12:19 PM
    #36
    IMXPLRN
    Folsom, CA
    2003 Prerunner
    It's not obvious from the picture that it is a domed surface. So I'm assuming it's being milled instead of turned on a lathe. I guess I could always take a skim cut on the front surface on a lathe to clean it up.
  17. Jan 7, 2021 at 12:23 PM
    #37
    FreshMexicanTaco
    AJ
    San Diego
  18. Jan 7, 2021 at 12:28 PM
    #38
    FreshMexicanTaco
    AJ
    San Diego
    Yes it is a domed surface, you're right its not obvious and I didn't mention it before. we could put it on a lathe but then it would take two machines to do it, the back of the button is not something that can be done on a lathe and neither is the design in front so we just machined everything. Making it flat would have been easier but it doesn't look or feel as good and we wanted to make a quality product, after all, you touch this every time you start or stop the truck so it much be well made for it to work, and we hope it does
  19. Jan 7, 2021 at 12:49 PM
    #39
    FreshMexicanTaco
    AJ
    San Diego
  20. Jan 7, 2021 at 5:11 PM
    #40
    FreshMexicanTaco
    AJ
    San Diego
    Shiny colors pop more I like them better but the Matte finish feels very nice to the touch. which one do you guys like better?
    Tacotrd_17 likes this.
