TACO GARAGE - Stealth Power Port
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by TheTacoGarageServiceRep, Aug 23, 2022.
  1. Sep 7, 2022 at 7:16 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Yes they are there.
    You just have to notch your radio bezel to fit. 20 seconds with a Dremel style tool.
  2. Sep 8, 2022 at 9:11 AM
    TheTacoGarageServiceRep [OP] Well-Known Member
    Andy
    2019 TRD OR
    There's notches on the back side to accommodate for the cables so yes.
    FLAK-TAC[QUOTED] likes this.
  3. Sep 8, 2022 at 9:11 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    is the USB-C port fast charging?
  4. Sep 9, 2022 at 10:38 AM
    Andy
    2019 TRD OR
    Yes, it is fast charging.
    doublethebass[QUOTED] likes this.
  5. Sep 9, 2022 at 11:02 AM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    top notch, thanks
  6. Oct 25, 2022 at 11:34 AM
    jsackspot
    jsackspot Well-Known Member
    Any word on this?
  7. Feb 1, 2023 at 11:46 AM
    apriliaalex
    apriliaalex Well-Known Member
    Alex
    Hi guys. I just received mine. How is everyone tapping into the cigarette lighter? Unless there’s something I don’t know the power ends of the wires are useless.
  8. Feb 2, 2023 at 5:08 PM
    Jproz
    Jproz Well-Known Member
    Bay Area, CA
    2021 LR Pro
    I did something similar albeit under passenger dash and wired to a relay and powertray fuse box. I wanted mine to have enough power to charge a usb-c laptop if desired. Works like a dream.
  9. Feb 2, 2023 at 5:55 PM
    apriliaalex
    Alex
    Did you take any pics of how you wired it up?
  10. Feb 2, 2023 at 8:21 PM
    Jproz
    Bay Area, CA
    2021 LR Pro
    Which specific part? It’s pretty easy - battery -> fuse box-> relay triggered by ignition-> 12->24v converter - >PD/QC usb charger.
    https://www.instagram.com/p/CTQduU3vb2P/?igshid=MDJmNzVkMjY=
    https://www.instagram.com/p/CdOtfL0PJte/?igshid=MDJmNzVkMjY=
    https://www.instagram.com/p/CceZcplJYGT/?igshid=MDJmNzVkMjY=
    (I’m running two sockets - the second originally was wired to my ham radio but I’ve now hard wired that to always have power. And the second inline fuse is to protect that generic converter from over pulling)
  11. Feb 13, 2023 at 7:55 PM
    cacocker
    cacocker Occasional Smartass
    Corey
    Seattle
    2017 TRD OR DCLB MGM
    Mods: https://bit.ly/34WhzsW
    Before I start messing with wires and pulling the dash apart, are there installation and wiring instructions for this?
    I know where to mount it, but suggestions on wiring or a step by step would be helpful.
    TIA!
    jrgrieve likes this.
  12. Mar 18, 2023 at 2:22 PM
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    Looking for the answer to this question as well.
    Good way to splice into the cigarette lighter wiring
    anyone??
  13. Mar 19, 2023 at 11:05 AM
    apriliaalex
    Alex
    I still haven't gotten around to figuring out how I will install mine either. Wish there was an easy plan and play.
  14. Mar 19, 2023 at 12:49 PM
    wdissident
    wdissident Well-Known Member
    chris
    orange, cali
    2022 trd sport
    i havent bought this product. are you guys implying a harness for the cigarette lighter would be ideal for easy install and or DIY'ers? looks like a cool product.
    could always use a t harness from the head unit and tap power from the head unit without needing to chomp through factory wires. or using a light switch harness to tap from a switch in the center console. like this
    https://caliraisedled.com/products/...VoxB-OJ5867XulH65IIC2fbjFJmG9tbRoChlMQAvD_BwE
  15. Mar 19, 2023 at 12:53 PM
    #35
    wdissident
    chris
    orange, cali
    2022 trd sport
    The truck is pre-wired for trailer brake controller, so you could grab the hot wire from it if you dont plan on using it for towing.
  16. Mar 19, 2023 at 1:01 PM
    #36
    apriliaalex
    Alex
    Yeah, This device will be awesome once I get it wired. For some reason I thought I would just be able to grab power from the stock lighter because its right there. My guess is the device you shared would be lower voltage than what would be needed to run a MagSafe charger. The lighter socket can do it but the radio usb cannot. for some reason my 18 pro with technology package does not have any charge ports in the center console either. Either way I just want to safely send power to my magnetic cell power without splicing into wires. Some people are totally fine with splicing and I agree that there's nothing wrong with it when done properly, I just always try to avoid it before having to. I was hoping that there was a dongle I could use because there are so many people with tacoma accessories. At this point I think the easiest way is going to be straight tapping the fuse box.
  17. Mar 19, 2023 at 1:09 PM
    #37
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Please don’t use that to power anything other than a small switch LED. Thank you.
  18. Mar 19, 2023 at 1:23 PM
    #38
    wdissident
    chris
    orange, cali
    2022 trd sport
    ya morgans probably right.. im with you april im not a huge fan of splicing wires. much prefer a t harness. hopefully someone comes out with one soon for you guys. would probably help the sales of this unit as well. good luck!
  19. Mar 19, 2023 at 1:24 PM
    #39
    caribe makaira
    Caribbean, Puerto Rico
    upload_2023-3-19_16-24-22.jpgupload_2023-3-19_16-24-29.jpg Use heat shrink tubing to insulate exposed metal. Terminal is a piggyback. Needs to be "bent" a bit to have proper angle to fit.
    cmonjack, HisDad, byebyebhg and 3 others like this.
  20. Mar 19, 2023 at 1:26 PM
    #40
    wdissident
    chris
    orange, cali
    2022 trd sport
    this is sick^^^ heres everyones huckleberry
