Taco (gen 2) write up...350k crossed & jamming to 400k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chiloquin_Car_Care, Feb 6, 2019.
should I get a gen 3 or keep pushing the gen 2?
  1. keep it & go to 500k!
    303 vote(s)
    88.9%
  2. sell it/trade in & get a new one/start over!
    10 vote(s)
    2.9%
  3. keep it & get a new gen 3!
    28 vote(s)
    8.2%
  1. Apr 10, 2019 at 8:38 AM
    #101
    Chiloquin_Car_Care
    Chiloquin_Car_Care [OP] homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    maintenance update-
    at 307k I am ready for new front shocks (still got the factory originals running), occasionally when braking on rough road my taco starts bouncing
    & the rear brakes (factory original) are still good, but due for an overhaul
    I guess I will finally be getting my FIRST alignment after I do the front shocks
    307k miles with factory alignment....crazy, huh?
    Oldie2007 and crazy joker like this.
  2. Apr 10, 2019 at 9:16 AM
    #102
    Chiloquin_Car_Care
    Oregona
    interesting-
    "So the basic answer to the question does oil change affect performance is pretty easy. Old oil will reduce engine performance, lower its horsepower, reduce its mileage and eventually shorten its life. Be sure to get your oil change in accordance with the recommendations of your vehicle owner's manual. Dec 24, 2013"
    full write up-
    https://www.bellperformance.com/blog/does-oil-change-affect-performance
    more horsepower means a better 0-60mph time when I last checked
  3. Apr 24, 2019 at 5:13 AM
    #103
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Don't be surprised if your alignment cams are seized when you go to install the front shocks. That's the case with my truck. If they are stuck, you won't be able to lower the LCA down far enough to insert the new shock or to remove the old shock.
    I even have new coilovers ready to be installed but I want to have a pro fix the alignment cams first. My wife refuses to let me attempt to cut them out with a sawzall :rolleyes:
  4. Apr 24, 2019 at 5:37 AM
    #104
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Wives I tell ya!
    I've been watching this. Watching everyone give you a hard time about it too. I read the article and in my opinion, I don't think the difference will be noticeable. BUT I am an analyst by work so my brain works off of data. I'm very intrigued to see the numbers after a test is conducted. My guess would be in the 100's of a second difference.
    Plucky was his name likes this.
  5. Apr 25, 2019 at 5:01 PM
    #105
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Im impressed that you still have your factory rear brakes. Keep the the truck
  6. Apr 25, 2019 at 5:06 PM
    #106
    Chiloquin_Car_Care
    Oregona
    Im trying to make 325k with them...almost there :)
    thanks for your comment bud
    more impressive is the factory shocks up front....300k on shocks is unheard of
    if you drove my truck you would not believe/feel that the shocks are factory original with 300k+ miles
  7. May 5, 2019 at 3:01 PM
    #107
    Chiloquin_Car_Care
    Oregona
    in prep for the test, I did a trial run today
    Im roughly 500 miles from 310k (at which point I will do the real before & after testing)
    I repeatedly got right around 9 secs (ran the test 6 times)
    note- I had some stuff in the bed, which will not be there for the real test
    I will do 5 runs prior to oil change
    & 5 runs after
    I will average the results
    & the test will be done on the same road/starting point (for all 5 before & after tests)
    I anticipate the test happening in about 7-10 days
    Jaypown[QUOTED] likes this.
  8. May 5, 2019 at 5:41 PM
    #108
    Chiloquin_Car_Care
    Oregona
    current mileage
  9. May 5, 2019 at 10:01 PM
    #109
    Vrbas
    Vrbas Well-Known Member
    2013 4x4 DCSB 6speed
    All hail.
  10. May 5, 2019 at 10:13 PM
    #110
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I would gladly give you my Monroe replacement front assemblies! They have 2K miles. But not gonna drive from Texas to do it! I just put someone's 2016 front take offs (with some spacers) and the ride is so much better. The rumor is true, so grab someone's cheapo "I need better than stock"
  11. May 9, 2019 at 8:58 PM
    #111
    Chiloquin_Car_Care
    Oregona
    by this monday may 13th (maybe tuesday the latest)
    I will have conducted the testing on if an oil change improves 0-60 run time
    & post the results
    just crossed 309,800....couple hundred more miles to go
    I am also going to send my first oil sample to blackstone for analysis
    will be interesting to see the results on that
  12. May 9, 2019 at 8:59 PM
    #112
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
  13. May 13, 2019 at 10:27 AM
    #113
    Chiloquin_Car_Care
    Oregona
    as the oil drains, here are the pre-oil change times going from 0-60mph
    1. 02:401-10.926 (8.525 sec)
    2. 02:853-11:483 (8.63 sec)
    3. 02:919-11:539 (8.62 sec)
    4. 02:103-10:546 (8.443 sec)
    5. 02:644-11:110 (8.46 sec)
    average speed of all 5 - 8.535 seconds
    time go go fill the oil & do it again
    post oil change time test results coming up in about an hour
  14. May 13, 2019 at 11:32 AM
    #114
    Chiloquin_Car_Care
    Oregona
    post oil change results for 0-60mph
    not a big difference (1/10 of a second averaged)
    but on a track that could be win or lose, right?
    1. 02:634-11:235 (8.601 sec)
    2. 02:093-10:496 (8.403 sec)
    3. 02:116-10:667 (8.557 sec)
    4. 02:077-10:494 (8.417 sec)
    5. 01.837-10:154 (8.317 sec)
    I was able to pull off (1) 8.3 run on fresh oil, which did not happen on the 5000 mile old oil
    average of 5 - 8.459 sec
  15. May 28, 2019 at 6:19 PM
    #115
    Chiloquin_Car_Care
    Oregona
    2015WhiteOR likes this.
  16. May 28, 2019 at 6:30 PM
    #116
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  17. May 28, 2019 at 6:32 PM
    #117
    Chiloquin_Car_Care
    Oregona
    man, I love this truck!
  18. Jun 27, 2019 at 12:17 PM
    #118
    Chiloquin_Car_Care
    Oregona
    eherlihy likes this.
  19. Jun 27, 2019 at 12:33 PM
    #119
    TacomaSport86
  20. Jun 30, 2019 at 7:13 PM
    #120
    Chiloquin_Car_Care
    Oregona
    just turned 320k
    did the oil
    see yall at 325k
